Old Oct 10, 2012, 05:08 PM
flyboyken is offline
Find More Posts by flyboyken
Ken Stuhr
Seattle, WA
Joined Aug 2005
AEO Problem
I ordered and received the AEO ADF30-100 PLUS 8000KV. In testing, I cannot get it to run beyond a very low throttle setting.
I have tried ESCs at 12A, 18A and 25A with the same result.
I have tried 3-3 cell battery packs at 1500, 2100, and 2600 (all 25-25+C)mAh capacity, all with the same result.
The result is that the unit will start, but with advancing throttle, it cuts off. The current when this happens varies between about 3A and 7A, but if it peaks higher, I can't tell.
Do I need a special hi-freq ESC for this? Is my result a hardware fault or operator error?
flyboyken is offline Find More Posts by flyboyken
Old Oct 10, 2012, 10:00 PM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
You will need an ESC that will handle a higher rpm outrunner, not all escs will do that. Hobbywing and turnigy plush are two that will work. Program the ESC for low timing and you should be OK.
Joe 1320 is offline Find More Posts by Joe 1320
Old Oct 11, 2012, 11:25 AM
Ken Stuhr
Seattle, WA
Joined Aug 2005
OK-thanks Joe
Old Oct 12, 2012, 01:09 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Not personally seen a hobbywing on HK site for some time.
Did discover that an esc with an "atmel' chip seems to deal with high outrunner rpms though.
Plush...ones in red heat shrink..did !
Clear shrink versions currently use a silab(?) chip . No idea if it's better or worse at this, although some claim it a degrade.. but that's just words until proven..
Not all that easy to deduce from brochure babble which esc's actually currently use a capable chip though.
Mystery / HK blue series still do (did?)
Dunno if that helps in selecting ?
Bare is offline Find More Posts by Bare
Old Oct 13, 2012, 11:17 PM
KCinNC is offline
Find More Posts by KCinNC
that's gonna leave a scar
KCinNC's Avatar
United States, NC, Mooresville
Joined Aug 2007
HobbyPartz carries the Hobbywing esc's....i have ordered 3 from them. work perfect. even the Turnigy program card i have works on them
http://www.hobbypartz.com/platinum.html
KCinNC is offline Find More Posts by KCinNC
Question Aeo edf with ammo 10/11500kv nadine Micro EDF Jets and Power Systems 7 Sep 23, 2012 12:38 AM
Discussion AEO-RC CR23L Contra-Rotating Motors (Semi Heavy Lift?) gitit20 Multirotor Talk 3 Jul 06, 2012 09:38 PM
Sold XP-7A and AEO converter SYMAWD Aircraft - Electric - Helis (FS/W) 0 Jul 01, 2012 10:07 PM
Sold New head tracker aeo x-gyro 1000 TBello FPV Equipment (FS/W) 2 Apr 29, 2012 09:58 AM
Discussion AEO brushless problem... HELP!!!!! jbeauvil001 Micro Helis 8 Apr 08, 2009 07:22 PM
