Old Oct 10, 2012, 04:01 PM
gazoid is offline
Find More Posts by gazoid
Joined Oct 2012
Possible transmitter/receiver problem
Hi,
I recently bought my first RC boat and all was working fine.
After a few weeks use i had a problem where in mid use contact between boat/handset was lost.
After the boat was recovered i discovered there was a leak and nothing was working.
I stripped the boat and left to dry. It now works fine apart from the range between handset and boat is about 6ft!
Does this sound like a faulty/water damaged transmitter if so are they easy to change?
gazoid is offline Find More Posts by gazoid
Old Oct 10, 2012, 07:45 PM
bgnome is offline
Find More Posts by bgnome
made of fire and pop rocks
bgnome's Avatar
Richmond Virginia
Joined Oct 2009
in short?
yes
it would be helpful to know what boat and equipment you have. the fact that it's working at all is actually a good sign and what has mostly likly happened is that there is a short somewhere on the reciver board caused be the water exposure and it drying off leaving a minieral deposit between traces, or a resistor or diode shorted out and failed.
bgnome is offline Find More Posts by bgnome
Old Oct 10, 2012, 08:44 PM
Apismelifera is offline
Find More Posts by Apismelifera
1/2 a bubble off
Apismelifera's Avatar
United States, NY, Schenectady
Joined Mar 2011
At this point you have nothing to loose by taking the receiver out and cleaning it. Take it out of the case. If it has a removable crystal that is plugged into a socket, then unplug the crystal.
1) Rinse the receiver, crystal, and case off under the faucet, a gentle stream is all that is required. Cold or slightly warm. While under the tap brush it with a clean paint brush or soft tooth brush to loosen and remove any dirt and dried mineral deposits. Do not scrub real hard. Be gentle. After the bath. You can shake it to remove most of the water on it. Does not need to be totally dry.
2) Clean the receiver in a dish or bowl with some 90% or better isopropyl rubbing alcohol. The alcohol will further remove dirt and other contaminates. The alcohol will also absorb any remaining water on the receiver board. Did the alcohol in the bowl get really dirty during the cleaning process? If it did, you can repeat step 2 with some fresh alcohol.
3) You can speed the drying process with a hair dryer on the no heat setting, you only need the moving air stream to dry the alcohol.
Let it sit out unasembeled in a warm spot all night. In the morning put it all back together and try it.
Apismelifera is offline Find More Posts by Apismelifera
Old Oct 11, 2012, 04:35 AM
mfr02 is offline
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
The boat electronics getting wet will do nothing to the transmitter. If the receiver is a separate unit from the ESC and steering servo, it is probably a replaceable unit if it does not respond to Apismelifera's procedure in #3. If all of the electronics is one unit, then it becomes a complete replacement project.
It helps if we know what band it works in.
mfr02 is offline Find More Posts by mfr02
Old Oct 11, 2012, 05:41 PM
SUGAR COATED is offline
Find More Posts by SUGAR COATED
Joined Aug 2012
Low voltage on either the receiver or transmitter or both, can cause the short range. Again, it is helpful to know what radio/ system you are using. A non conductive contact cleaner(spray can) also works to clean the board. (Radio Shack or?)
Mount your receiver so it can only get wet if the boat sinks (you get the idea)
Much Luck
sc
SUGAR COATED is offline Find More Posts by SUGAR COATED
Discussion Bowerz's FPV escapades (newbie problems and possibly solutions) Bowerz FPV Talk 7 Oct 15, 2012 04:43 AM
Discussion Possible Power Supply Problems erikc641 Power Systems 6 Aug 21, 2012 05:59 PM
Discussion Could this be possible, 2 dsm2 receivers bound on 1 transmitter at same time new1200 Trader Talk 8 Mar 11, 2012 10:13 AM
Discussion possible to use air receiver with ground transmitter kennyc Beginner Training Area (Aircraft-Electric) 5 Feb 15, 2011 07:21 PM
Discussion Possible Futaba R156F 6CH micro receiver problem... Whistler71 Mini Helis 0 Sep 11, 2007 12:24 AM
