This thread is privately moderated by IrisAerial, who may elect to delete unwanted replies.
Old Oct 10, 2012, 04:29 PM
IrisAerial is offline
Find More Posts by IrisAerial
Trader Rating: 0
Joined Oct 2012
Trader Rating: 0
For Sale
Zephyr 2 with EZUHF and 2.4 vtx. ARF
I've never flown nor applied power to plane as i dont want to decrease the value of the plane. I purchased this to use for filming golf courses but I realize it is too fast and dangerous in that tight of an environment. I have the bay cut out to work with the Sony Nex5n. A gopro would also fit in the bay perfectly in the width of the nex lens cutout. The 4000 was just for image. Was designed to fly 1 5300 4s. Works best weight wise with Nex5n. Can fly 2 4000's with gopro in standard bay.
Includes:
Ritewing esc/motor
cam folding prop/hub
EZ UHF OSD,RX,TX
best antennas you can get for non-tracker setup.
2.4Ghz lawmate vtx with vrx
600 RMRC Fpv cam
Voltage/line filter
CC BEC 10amp
HS645MG servos
5db helical antenna/clover
Red bottom/yellow top.
This has taken over a month to build. everything soldered/heat shrunk/braided/done right.
$1300
IrisAerial is offline Find More Posts by IrisAerial
Old Oct 10, 2012, 04:48 PM
TomFlyer is offline
Find More Posts by TomFlyer
Trader Rating: 30
United States, OR, Tualatin
Joined Apr 2005
Trader Rating: 30
You may want to partner up with some one with a bigger plane that can fly slower, be more stable and be safer. Something like a Simba Pike Perfect which is close to a 3 meter wing span plane with an electric fuse and motor with a special foam pod for the camera attached to the bottom with skids for safe and soft landings.
TomFlyer is offline Find More Posts by TomFlyer
Old Oct 10, 2012, 07:05 PM
Trader Rating: 0
Joined Oct 2012
Trader Rating: 0
I really need to stick with helis for what I am doing. Even a larger wing wouldnt fly slow enough to navigate tight courses. These are designed for large open spaces. The weight is only a few ounces heavier with the nex as I am using 1 5300 mah battery instead of my 2 4000 and gopro. From what I hear these things like flying heavy.
Discussion How to disable 2.4 on 8FG for use with EZUHF? bovick FPV Talk 7 Aug 21, 2012 08:45 PM
Sold Zephyr II ARFS, 2 to choose from ronrob61 Aircraft - Electric - Airplanes (FS/W) 2 Jul 19, 2012 09:47 AM
For Sale 2.4 200mw VTX 4 chanel $35 crashtested FPV Equipment (FS/W) 0 Apr 28, 2012 09:18 PM
Help! 2.4 GHz VTx interfering with 72Mhz Rx? bamabaxter FPV Talk 5 Sep 27, 2011 11:53 PM
Found $1800 for TBS Zephyr w/ ezUHF swshouse Aircraft - Electric - Airplanes (FS/W) 0 Jul 04, 2011 05:57 PM
