Old Dec 09, 2012, 01:53 PM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
3/4 will work well for you.
TomCrump is offline Find More Posts by TomCrump
Old Dec 09, 2012, 07:03 PM
TexasClouds is offline
Find More Posts by TexasClouds
TexasClouds's Avatar
Joined Feb 2010
engine area has been sealed, cockpit blackened, tail pieces covered. man, this solartex is the easiest covering I have ever worked with. the plastic backing is easy to remove, the adhesive doesn't try to stick to itself, and it shrinks nice and tight.
TexasClouds is offline Find More Posts by TexasClouds
Old Dec 09, 2012, 09:00 PM
splinterz25 is offline
Find More Posts by splinterz25
Jack of all master of none
splinterz25's Avatar
Baltimore MD USA
Joined Jan 2011
Nice work looks great I'll never use anything but Solartex on any plane I want to see the fabric's pattern on! looking forward to your finish keep up the good work.
Bruce
splinterz25 is offline Find More Posts by splinterz25
Old Dec 10, 2012, 03:28 PM
Joined Feb 2010
hey guys, i plan to fiberglass the nose with zpoxy, sand, prime with lustrekote primer, then paint yellow with lustrekote cub yellow.
should i also prime the solartex covering before painting yellow? the side fuselage and tail will all be solartex covered.
Old Dec 10, 2012, 05:34 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
As I stated in my PM, do not prime any open bay areas when using Solartex. If you want to prime sheeted areas, go ahead.
Old Dec 10, 2012, 08:22 PM
Baltimore MD USA
Joined Jan 2011
When I painted my Stinson w/ Solartex on it I used rust-oleum pro and the Solartex was white pre - primed. I've never had very good luck w/ LUSTREKOTE it tends to run easily and doesn't cover very well so you will have to do several coats. And like Tom says don't prime the open bays because it will crack w/ time. Good luck w/ the finish however you go.
Bruce
Old Dec 11, 2012, 10:31 PM
Joined Feb 2010
I think my wing struts are going to tilt the left wingtip higher than the right. If I heat up the top front solder joint I should be able to shift one up and one down to remedy.
Fuselage is covered, it took me a while but ended nicely. By the time this plane is finished it will be a leap of faith to take that first hop down the runway! I think if I built a second then it would be a faster build. Third would be a breeze. Ha!
Old Dec 12, 2012, 09:58 AM
Joined Feb 2010
any tips on trimming the cockpit area? it is about the size of a coke bottle in diameter and the sheeting is 1/16:
Old Dec 12, 2012, 10:41 AM
Baltimore MD USA
Joined Jan 2011
Don't cut it wrap sand paper around some thing similar in shape and sand to a line that you have drawn you can get a better finish that way.
Bruce
Old Dec 12, 2012, 11:02 AM
Joined Feb 2010
Bruce
i'm sorry, but i meant like a leather looking rim around it.
Old Dec 12, 2012, 12:10 PM
TomCrump is offline
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Sig has foam cockpit combing that trhey use on their 1/4 Spacealker II. I wrapped it in cloth and then installed it.
Maybe you could order some from them.
Old Dec 14, 2012, 05:27 AM
Dillion is offline
Find More Posts by Dillion
Balsa Dust and CA Fumes
Dillion's Avatar
United States, PA, West Chester
Joined Oct 2007
Auto Body shops have leather trim which might work. I used it on Bristol
Dillion is offline Find More Posts by Dillion
Old Dec 28, 2012, 09:22 AM
Joined Feb 2010
After adding the LE and sheeting, you can see the wing taper better. Still need to join the halves and finish tips.
Old Dec 30, 2012, 09:13 PM
cbarnes0061 is offline
Find More Posts by cbarnes0061
Flying Low
cbarnes0061's Avatar
United States, VA, Petersburg
Joined Mar 2012
Looking good
cbarnes0061 is offline Find More Posts by cbarnes0061
Discussion Pre-maiden jitters, Fokker D-VII CNY_Dave Electric Plane Talk 28 Sep 16, 2012 09:01 PM
Found Flair SE-5A or Fokker D-VII kits LKruse Aircraft - Fuel - Airplanes (FS/W) 2 Aug 01, 2012 08:12 PM
Sold Fokker D-VII RTF LPU new york Area pulsery2k1 Aircraft - Electric - Airplanes (FS/W) 6 May 29, 2012 07:51 PM
Sold Fokker D VII (Hangar 9) ARF - 64 in. wing Segelfluger Aircraft - Electric - Airplanes (FS/W) 1 May 15, 2012 01:43 PM
Sold Fokker D-VII RTF LPU new york Area pulsery2k1 Aircraft - Electric - Airplanes (FS/W) 1 Apr 18, 2012 06:29 PM
