Old Dec 02, 2012, 08:03 PM
TexasClouds is offline
Find More Posts by TexasClouds
TexasClouds's Avatar
Joined Feb 2010
aluminum .020" side panels cut easily with some old scissors. 80 grit made quick work of the lower cowl shaping.
the build article suggests I dope on some tissue paper to seal the balsa cowl. any tips or suggestions would be appreciated. i bought some aerogloss clear, which i believe is the correct stuff.
pics:
TexasClouds is offline Find More Posts by TexasClouds
Old Dec 03, 2012, 03:29 PM
TomCrump is online now
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
Nice work, TC !
The nose area looks like it will be interesting to get covered. As I said in my PM, I would use fiberglass cloth to seal it up. In the PM I suggested using dope, but maybe epoxy finishing resin would be a better choice.
TomCrump is online now Find More Posts by TomCrump
Old Dec 03, 2012, 04:22 PM
Dillion is offline
Find More Posts by Dillion
Balsa Dust and CA Fumes
Dillion's Avatar
United States, PA, West Chester
Joined Oct 2007
Nice Job
Texas, This is Dylon. Very nice build. It's moving along nicely. Have you started the wing at all? I'll book mark this follow the build. Good Job.
Dillion is offline Find More Posts by Dillion
Old Dec 03, 2012, 04:29 PM
Joined Feb 2010
Originally Posted by TomCrump View Post
Nice work, TC !
Yeah, the nose itself has been a lengthly task.
Can you point me towards a particular brand so I'm looking for the correct stuff?
edit: it looks like Z-Poxy might be what you are talking about. that sounds stronger than doped tissue. I've heard these like to nose-over.
No wing action just yet. I'll start it after I square away my three servos and tail linkages.
Old Dec 03, 2012, 06:21 PM
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
z-poxy is what I use. For a smaller area, like this, 30 minute epoxy, thiinnned with denatured alcohol, would work. It may be a little harder to sand, though.
Old Dec 03, 2012, 10:15 PM
Joined Feb 2010
Zpoxy, fiberglass cloth, 4 cans of paint, two glow plugs, and $85 later I'm set for covering the fuselage and sealing the engine compartment. Yikes!
Old Dec 05, 2012, 03:18 PM
Joined Feb 2010
Here is a whimsical color scheme I cooked up...in the event I chicken out of lozenge camo wings:
Old Dec 05, 2012, 03:32 PM
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Here's an unusual scheme, although it is scale, for a DVIII.
Old Dec 05, 2012, 03:52 PM
Joined Feb 2010
Hmmm, if I only build a top wing with my fuselage...would it be a D-7.5?
Old Dec 06, 2012, 07:01 AM
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Dvii.v ?
Old Dec 06, 2012, 10:26 AM
Joined Feb 2010
Fuselage To-Do list:
Cut/Glue Louvers for side panels, cut hole for exhaust
Add grill inset to the cowl air inlet
Hinge tail feathers + make control arms
Mount Servos and pushrods
Cut hole in cockpit for switch, paint cockpit deck black
Build landing gear mini wing cover in lozenge later
Build Machine guns + paint
Seal dummy engine, guns, pilot with dull clear lustrecoat
Paint wheels yellow
Add basswood to the wire struts, sand profile, cover. Seal the wood near exhaust.
Cover fuselage, fiberglass nose area, prime nose area, paint the lot yellow
Seal internal engine/fuel tank area
Add cross to the rudder/fin.
Old Dec 06, 2012, 11:46 PM
Dillion is offline
Dillion's Avatar
Joined Oct 2007
Like the colors
Texas, I like to see you put an original color scheme to the plane. The one you drew would be very personal. I like it
Old Dec 09, 2012, 08:08 AM
ARFs Are Me
TomCrump's Avatar
Joined Dec 2005
Nice work ! I especially like the louvers.
What weight glass cloth did you purchase ?
Old Dec 09, 2012, 12:18 PM
Joined Feb 2010
Thx, 3/4 oz was the lightest avail.
Discussion Pre-maiden jitters, Fokker D-VII CNY_Dave Electric Plane Talk 28 Sep 16, 2012 09:01 PM
Found Flair SE-5A or Fokker D-VII kits LKruse Aircraft - Fuel - Airplanes (FS/W) 2 Aug 01, 2012 08:12 PM
Sold Fokker D-VII RTF LPU new york Area pulsery2k1 Aircraft - Electric - Airplanes (FS/W) 6 May 29, 2012 07:51 PM
Sold Fokker D VII (Hangar 9) ARF - 64 in. wing Segelfluger Aircraft - Electric - Airplanes (FS/W) 1 May 15, 2012 01:43 PM
Sold Fokker D-VII RTF LPU new york Area pulsery2k1 Aircraft - Electric - Airplanes (FS/W) 1 Apr 18, 2012 06:29 PM
