Old Oct 22, 2012, 03:08 PM
JeffEE is offline
Find More Posts by JeffEE
Deadstick
United States, MN, St Paul
Joined Nov 2004
Oh, here is the way the field looked in 1997.
JeffEE is offline Find More Posts by JeffEE
Old Oct 22, 2012, 11:55 PM
TexasClouds is offline
Find More Posts by TexasClouds
TexasClouds's Avatar
Joined Feb 2010
Originally Posted by JeffEE View Post
I have flown at the Wichita Falls field. It was a nice place in 97-98. Your build looks great, and as a fellow DVII flyer, I say bravo! Does Eddie Hill still fly from that field?
I fly at BVRC near Bryan. Never flown in wichita falls.
The upper wing strut wires have now been formed. I need to setup the LG wires and then fit to the fuselage. My wheels and pilot came in from Tower H.
I'm seriously considering the printed covering from AZ Models for the wing lozenges.
TexasClouds is offline Find More Posts by TexasClouds
Old Oct 23, 2012, 10:06 AM
Joined Feb 2010
I found a NIB Saito FA-40A for $100 delivered! That will be my engine and I'll go with the ssuggest 4oz tank.
Old Oct 23, 2012, 06:59 PM
splinterz25 is offline
Find More Posts by splinterz25
Jack of all master of none
splinterz25's Avatar
Baltimore MD USA
Joined Jan 2011
That's a great deal on the engine, good luck w/ your build
Bruce
splinterz25 is offline Find More Posts by splinterz25
Old Oct 26, 2012, 10:18 AM
Joined Feb 2010
The new engine came in yesterday and looks pretty sweet. This is my first new airplane engine, all of my others I get used. Size looks to be really nice. Pics below.
Old Oct 26, 2012, 09:26 PM
Joined Feb 2010
I finished bending the landing gear, drilled holes in the plywood formers for thread, then started securing the wires to the formers. I used a little thin ca to tack the braided fishing line in place. After this is done, I will have to line up the LG and wing struts then solder them together. I'll need to make a jig to make sure the top wing mounts are in the right place.
Pics Below.
Watching 'The Blue Max' right now, makes me want to lozenge the fuselage too!
Old Oct 29, 2012, 11:34 AM
Joined Feb 2010
The drawings show the leading edge of the wing to be kicked up a bit. Is that called the Angle of Indidence? Is this considered a 'positive angle'?
It looks like my wires gave the same effect to the top wing, look at these pictures with the level in place:
Old Oct 29, 2012, 11:58 AM
Joined Feb 2010
This is what I found about having the top wing angled up:
Biplanes are often set up with the forward wing at a positive incidence to the rearward wing. This allows the forward wing to stall first (kinda like washout). Once the forward wing stalls, the plane is effectively flying on the rearward wing. The cg is now also "effectively more forward" so the plane drops it's nose and flys on. If the plane is set up with the rearward wing being more positive, the cg "effectively moves back" and you've got a tail heavy airplane heading for a violent stall. - tpstorey
2004
Old Oct 30, 2012, 09:54 AM
Joined Feb 2010
F1 is installed as is the 1/2" balsa sheet for shaping the bottom of the nose cowl.
1/16" ply sheeting is secured in the LG area
Old Oct 31, 2012, 08:47 AM
Joined Feb 2010
Pilot was painted with Testors enamel paint (plastic modeling paint in the little jars). I need to find a flat clear coat that is nitro-proof.
My son says he looks too French...what do you think?
Old Oct 31, 2012, 08:54 AM
Baltimore MD USA
Joined Jan 2011
I think the pilot looks really nice... Here's a link for some clear flat fuel proof spray.
http://www3.towerhobbies.com/cgi-bin...&I=LXCZW4&P=ML
I hope this helps,
Bruce
Old Oct 31, 2012, 09:33 AM
Joined Feb 2010
I hope this helps,
Bruce
Thanks, I'll try that.
I repainted his eyes and face 3+ times. At one point he had a full beard. It was fun to paint, but best viewed from 3' or more.
Scarf is part of an old undershirt.
Old Nov 02, 2012, 10:26 AM
Joined Feb 2010
The Saito engine started with a few flicks of the chicken stick. From tank 1 it has started and idled nicely. I ran four 8oz tanks through it last night. I'm going to do one more running leaner prior to mounting inside the plane.
Pic:
Old Nov 03, 2012, 04:12 PM
Joined Feb 2010
tail skid and top decking has been installed. now onto the cowl.
pics:
Discussion Pre-maiden jitters, Fokker D-VII CNY_Dave Electric Plane Talk 28 Sep 16, 2012 09:01 PM
Found Flair SE-5A or Fokker D-VII kits LKruse Aircraft - Fuel - Airplanes (FS/W) 2 Aug 01, 2012 08:12 PM
Sold Fokker D-VII RTF LPU new york Area pulsery2k1 Aircraft - Electric - Airplanes (FS/W) 6 May 29, 2012 07:51 PM
Sold Fokker D VII (Hangar 9) ARF - 64 in. wing Segelfluger Aircraft - Electric - Airplanes (FS/W) 1 May 15, 2012 01:43 PM
Sold Fokker D-VII RTF LPU new york Area pulsery2k1 Aircraft - Electric - Airplanes (FS/W) 1 Apr 18, 2012 06:29 PM
