This thread is privately moderated by mcashatt, who may elect to delete unwanted replies.
Old Oct 10, 2012, 11:14 AM
mcashatt is offline
Find More Posts by mcashatt
Trader Rating: 47
mcashatt's Avatar
United States, AZ, Gilbert
Joined May 2012
Trader Rating: 47
Sold
SOLD--MWC Multiwii MEGA 2560-NIB!!!
**SOLD--More coming next week**
BRAND NEW!!!
MWC Multiwii MEGA 2560 Flight Control Board
Supports Octocopters!
Supports Care Free, Auto Level and altitude hold.
-With additional GPS module supports Position hold and Return to home.
- Support all MWC Firmware,High extend capacity
- Small size,Standard 45x45mm mounting holes
- 6 input channels for standard receiver and PPM SUM receiver and extra 2 channels for Gimbal control.
- Up to 8-axis motor output
- support Y3,Y4,+4,X4,6,X6,Y6,8,X8 Flying Mode
- 3 Servo output for camera
- 8 Ch PPM input
- 3 status LED
- 4x serial port,support GPS function
- On board USB Board,doen't need FTDI module
- Full servo signal output,support most ESC
- Adopts Chip:1x Atmega 2560 25k flash,9DOF+Barometer(ITG 3205/BMA180/HMC5883+BMP085
- A I2C socket for extend sensor,I2C LCD/OLED display or CRIUS I2c-GPS NAV board
- Separate 3.3V and 5V LDO voltage regulator
Flight mode
- Acro
- Level
- Alt Hold
- Head Lock
- Optional mode
- HeadFree (CareFree)
- GPS Hold (Need GPS receiver)
- GPS Return to home position (Need GPS receiver)
NOTE: I will gladly solder on header pins at no extra charge if you prefer it that way.
Price is $75/each and that includes free shipping from the US to anywhere in the US via USPS Priority mail.
All payment through PayPal.
mcashatt is offline Find More Posts by mcashatt
Old Oct 10, 2012, 11:22 AM
AcroFPV is offline
Find More Posts by AcroFPV
Trader Rating: 44
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
Trader Rating: 44
Damn I just gave HobbyKing some money for one of these.
AcroFPV is offline Find More Posts by AcroFPV
Old Oct 10, 2012, 12:10 PM
kd4wen is offline
Find More Posts by kd4wen
Trader Rating: 0
Just a yard bird
kd4wen's Avatar
United States, TN, Springfield
Joined Mar 2007
Trader Rating: 0
What GPS units work on this board?
kd4wen is offline Find More Posts by kd4wen
Old Oct 10, 2012, 12:37 PM
mcashatt is offline
Trader Rating: 47
mcashatt's Avatar
Joined May 2012
Trader Rating: 47
THe FC is basically, an Arduino Mega, so any GPS compatible with that. At work now but will look into gathering more info and providing links to compatible units during my lunch break.
Old Oct 10, 2012, 12:53 PM
AcroFPV is offline
Trader Rating: 44
we dont NEED roads!
AcroFPV's Avatar
Joined Aug 2012
Trader Rating: 44
From: http://code.google.com/p/megapirateng/wiki/configcode
Supported GPS protocols
in APM_Config.h #define GPS_PROTOCOL
GPS_PROTOCOL_NONE - without GPS
GPS_PROTOCOL_NMEA
GPS_PROTOCOL_SIRF
GPS_PROTOCOL_UBLOX
GPS_PROTOCOL_IMU
GPS_PROTOCOL_MTK
GPS_PROTOCOL_HIL
GPS_PROTOCOL_MTK16
GPS_PROTOCOL_UBLOX_I2C - AllInOne2 UBLOX GPS connected via i2c
GPS_PROTOCOL_AUTO - auto select (not recommend)
for change port speed: #define SERIAL2_BAUD 38400
This is for the MegaPirate firmware. I am sure the same would apply for MultiWii... but who would want to run MultiWii on this anyway??
Old Oct 10, 2012, 02:13 PM
Bryan's Flyin is offline
Find More Posts by Bryan's Flyin
Trader Rating: 34
United States, MO
Joined Apr 2009
Trader Rating: 34
Is this the same board that Terri Wang is selling with the X250? If not, what is the difference may I ask?
Bryan's Flyin is offline Find More Posts by Bryan's Flyin
Old Oct 10, 2012, 02:18 PM
mcashatt is offline
Trader Rating: 47
mcashatt's Avatar
Joined May 2012
Trader Rating: 47
Hey Bryan,
No--this is not the same, but close. The X250 has an on board MWC with accelerometer, gyro, and barometer and runs on an Atmel 328 chip.
This board has all of the same sensors, but runs on a Atmel Mega chip which is a bit newer, bigger, and has more pins.
The extra pins allow you to hook up an octocopter or V8 and also provide more pins for accessories line camera gimbal servos, GPS, etc. Note, however, that the GPS uses Tx/Rx pins and that would be the same for the X250.
To sum it all up: this one has more pins which means, as a matter of opinion, you have more potential uses.
Hope that helps.
Discussion Spider board- MWC mega 2560 (now we confirm to support MPNG and MWC both) jy0933 Multirotor Electronics 182 Nov 22, 2014 09:46 PM
For Sale X250 MWC Quadcopter new MWC Mega with gps, diy kit terriwang Aircraft - Electric - Multirotor (FS/W) 32 Jan 02, 2013 03:17 PM
For Sale Mega 2560 mwc + 10dof brettwal Aircraft - Electric - Multirotor (FS/W) 0 Aug 16, 2012 09:33 PM
Sold Two ArduPilot Mega 2560 Flight Controllers plus GPS, plus mags - ONE LEFT@\! wingspinner Aircraft - Electric - Multirotor (FS/W) 7 Jun 07, 2012 02:20 AM
For Sale Mwc fc, mega 2560 10dof mt0846 Aircraft - Electric - Multirotor (FS/W) 2 May 26, 2012 01:14 AM
