Old Feb 13, 2013, 12:39 PM
Caterpilar is offline
Find More Posts by Caterpilar
Belgium
Joined Oct 2012
Here is the Video Tom
My RC digger's first day digging in the sand... (19 min 9 sec)
Caterpilar is offline Find More Posts by Caterpilar
Old Feb 15, 2013, 03:27 AM
Belgium
Joined Oct 2012
Track testing in the sand (0 min 51 sec)
More digging (1 min 47 sec)
Old Feb 15, 2013, 09:15 AM
DeadTom is offline
Find More Posts by DeadTom
Team of ONE....or...Team Me
DeadTom's Avatar
Reno, Nevada
Joined Oct 2006
That is way too cool, I also like the conveyor.
I can see that you are having alot of fun
DeadTom is offline Find More Posts by DeadTom
Old Feb 25, 2013, 01:23 AM
Belgium
Joined Oct 2012
yes i am having a lot of fun with it
Old Mar 08, 2013, 04:11 AM
Belgium
Joined Oct 2012
i have been moving so much sand with my excavator that my early Bruder conveyor belt gave up working (due to the poor conversion). when I converted it I reused all the bruder plastic parts and mounted a sprocket on the the plastic roller that moves the belt.
So I fixed that now, using following parts:
- M8 socket bolt, 8mm bearing, M3 bolt and 2 nuts (they fit into the M8 socket head) and I kept my sprocket which has a 6mm hole which I reduced to 3mm.
I drilled a 2.8mm hole in the M8 bolt and threaded the hole
as you can see the M3 nuts fit perfectly in the M8 bolt
this is the old plastic part that I was taking about which I now discarded
The sprocket will sit like this in the M8 socket head
and this will serve as the new strong axle to drive the belt:
As the M8 bolt will not go all the way through, I have drilled a 4mm hole in the other side of the plastic roller that drives the belt to fit a 4mm steel axle in the hole. I drilled a 2,8mm hole in the 4mm axle and threaded it:
I place a 3mm screw in the axle to fix it to the plastic roller
Now, another problem I had before, when using the conveyor, was sand in the chain. I fixed that by making a simple alu cover and fixed it to the body of the conveyor and to one of the free holes in the mounting straight-edge of the RB35
it works now like a charm
Old Mar 08, 2013, 05:58 AM
Belgium
Joined Oct 2012
loading up the modified conveyor. Very happy with changes made to it!
Using the modified conveyor belt (3 min 16 sec)
Old Mar 13, 2013, 11:25 AM
Belgium
Joined Oct 2012
I have a Fendt tracktor which may come in handy to transport my excavator. I thought I would do something with it. So I started the conversion:
For the motor's I am using a PVC tube. Perhaps I should make it in Aluminum....
Old Mar 14, 2013, 03:07 PM
Belgium
Joined Oct 2012
I got the wheels of the axis today and prepared them so I can fill them up with black silicone tomorrow. I will use the M12 size bolts to connect the wheels to the RB35 motors
both Front and rear wheels will be filled with black silicone so there won't be any dirt that can get into the wheels later on while driving the tractor around.
Old Mar 15, 2013, 02:05 PM
Belgium
Joined Oct 2012
I have filled my wheels with a heavy duty black all fix adhesive silicone...
they are quiet heavy now (not as heavy as with led)
when the silicone is dry, I will paint the grey PVC tubing red to make it look better.
I also drilled all the holes for the LED's
and I mounted the flashlights onto the plastic support so they will fit nicely back in place
I have ordered the motors, speed controller and servo's. waiting for the delivery now. Meanwhile I have time to play around with the excavator
Old May 03, 2013, 11:27 PM
AMANSTEPH is offline
Find More Posts by AMANSTEPH
Joined May 2013
Hi great build. I have looked at all the photos and saw that you were selling kits. Are you still doing this and if so how much are you selling them for.
AMANSTEPH is offline Find More Posts by AMANSTEPH
Old May 04, 2013, 12:25 AM
Belgium
Joined Oct 2012
Yes I do. I will send you a PM with the price.
Old Jul 26, 2013, 06:55 PM
rson123 is offline
Find More Posts by rson123
Rson
Very cool...
PM or email me price details please rson123@yahoo.com (USA)
rson123 is offline Find More Posts by rson123
Old Jul 27, 2013, 05:35 AM
Commandernh is offline
Find More Posts by Commandernh
NH Armored Assault R/C Club
Commandernh's Avatar
Joined Jan 2013
Design Software
Nice project. I'm curious as to the design software you used. I use Solidworks,Pro E and Autocad for my design work. Very interesting the use of plates to achieve thickness. This is the method I use to produce specialized tooling for our Press Brakes. www.omnimetalsco.com .
CommanderNH
www.rctanksnh.com
Commandernh is offline Find More Posts by Commandernh
Old Aug 19, 2013, 05:58 PM
Mudmaker is offline
Find More Posts by Mudmaker
Joined Aug 2013
Man I like it
If your still selling these kits could you pm me. Anyone buy these kits and have theirs built yet?
Mudmaker is offline Find More Posts by Mudmaker
Old Aug 25, 2013, 06:52 PM
ninjaviper is offline
Find More Posts by ninjaviper
Joined Aug 2013
how much are you selling the kit for?
ninjaviper is offline Find More Posts by ninjaviper
Build Log Hobbyking Sniper pushy Cat - Build Blog Boostoman Pusher Prop Jet Models 9 Aug 03, 2013 09:17 PM
Build Log New RC Cat Design & Build, 450mm long Rhizome Racing Boats - Electric 16 Jun 08, 2012 03:49 AM
Build Log where do i post rc construction equipment? (bruder excavator rc conversion build) igotit Car Talk 20 Jan 19, 2012 02:45 PM
Discussion Excavator Construction Vehicle Electric RTR RC Tractor 1/12 swoo1998 Trader Talk 1 Jan 19, 2010 03:58 AM
