Old Oct 10, 2012, 10:04 AM
captscotty is offline
Find More Posts by captscotty
captscotty's Avatar
United States, FL, Destin
Flying a Scale Cub/ mixing rud-ail?
Hello
I'm flying a 1/6 Maxford USA Piper L-4 and think I need to mix some rudder to aileron, just not sure how to. The plane wants to adverse yaw if flying on the slow side and is fine at faster than scale speed. I'm using a Futaba 6EXA computer radio so programming mix is an option, I'm just not sure if I use rudder to aileron or vise versa and what percentage? I'm guessing maybe 30%+ to start but anybody have any ideas?
thanks
Scotty
captscotty is offline Find More Posts by captscotty
Old Oct 10, 2012, 10:16 AM
edwin1 is offline
Find More Posts by edwin1
United States, TX, Leander
Joined Sep 2003
I would suggest not doing it. A cub needs to be flown with coordinated turns, ie:lead with rudder, control wing bank with ailerons, and elevator to hold it level. In my opinion, if you mix you'll have trouble with side slipping and general cross stick flying. Which is a lot of fun in a cub.
Edwin
PS - Nice looking cub. Should be fun.
edwin1 is offline Find More Posts by edwin1
Old Oct 10, 2012, 10:41 AM
captscotty's Avatar
Thanks!!
I have about 5-6 flights on it since this pic but haven't flown since last February so I was just hoping to make it a little easier to get back on the sticks ie: mainly right stick flying. I do a lot of throttle management just don't use much rudder except knife edge and stall turns....
scotty
Old Oct 10, 2012, 10:52 AM
edwin1 is offline
Joined Sep 2003
Its a good plane for learning the rudder. Practice doing figure 8's with wings flat. Cross stick flying can be a lot of fun. Side slipping can be used to loose altitude without gaining speed. And nothing looks finer than a cub side slipping down to the runway center line.
Edwin
Old Oct 10, 2012, 10:56 AM
edwin1 is offline
Joined Sep 2003
Also forgot to mention, using rudder on landings can make a bad landing approach a non-event. Too many pilots use ailerons to line up with the runway which causes problems. When you're low and slow and your wings go to high banks, you loose lift at a time you cant afford to. Use the rudder to line up and ailerons to keep the wings level when slow. It will help landing just about any plane.
Edwin
Old Oct 10, 2012, 12:22 PM
captscotty's Avatar
You're absolutely right!!
Thanks Edwin1
You know, I've been a Sport flyer for almost 10 years and really have'nt improved, I just like basic aerobatics, scale 50's type stuff but if I'm going to get any better I gotta learn the rudder. That IS why I got the Cub and you just talked me out of cheatin myself by using mixing......Thank You!!
Scotty
Old Oct 10, 2012, 03:15 PM
scaleman57 is online now
Find More Posts by scaleman57
United States, NJ, Upper Pittsgrove
Joined Mar 2011
I mix rudder 25% it will give you cordinated turns. Most cub flyers will want to use the rudder stick but I cheat, Cubs are great training platforms Ihave been flying them for 30 years and have flomn with and without mix, I preferto use the mix on rudder.
scaleman57 is online now Find More Posts by scaleman57
Old Oct 10, 2012, 07:52 PM
no1isnormal is offline
Find More Posts by no1isnormal
United States, FL, Edgewater
Joined Nov 2010
I would also suggest setting up some aileron differential. If not done already. The upward travel should be more than the downward travel. This will help immensely with the adverse yaw condition.
no1isnormal is offline Find More Posts by no1isnormal
Old Oct 10, 2012, 09:27 PM
captscotty's Avatar
oohh yeeaaaah!
I learned from the beginning about differential and always set my ailerons to move more up than down. I was lucky to get training from a long time pattern contestant (prolly 25-30 yrs) that holds clinics every now and again. He suggested I mix rud to ail but I'm just asking for other opinions.....
"preciat the advice"
scotty
Old Oct 10, 2012, 09:36 PM
Thermalin is offline
Find More Posts by Thermalin
I'm a pilot, 100 yrs too late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
I have a cub... what fun is it if you take the fun out of it. Learn to use the rudder independently / by itself... you'll be a much better pilot. Mixing certainly has its place, though I perfer not to use it for example with elevator and flaps, etc. I prefer to fly the plane myself learning skills as I progress.
Thermalin is offline Find More Posts by Thermalin
Old Oct 11, 2012, 07:50 AM
ARUP is offline
Find More Posts by ARUP
Joined Mar 2010
+1 Thermalin. Besides, the full scale Cub didn't have 'mixing'!
ARUP is offline Find More Posts by ARUP
Old Oct 11, 2012, 09:26 AM
edwin1 is offline
Joined Sep 2003
Years back another instructor and I would do a demo for the students by having a cross stick contest. To see who could fly the full length of the runway with the most crab and wings the most level with our cubs. Mine was a world models 1/5 and I forget what his was (CG?). He beat me with about a 45deg. Really something to see that. Another fun thing to do is what we called tip toe through the tulips. On a touch and go, land left wheel, then right wheel, then go around. Its harder than it sounds. Cant do any of that without rudder.
Edwin
Old Oct 13, 2012, 05:22 AM
Lifer is offline
Find More Posts by Lifer
Kansas City
Joined Apr 2010
Mixing rudder and aileron is a great idea on any plane with a flat-bottom airfoil. Differential is also necessary to avoid adverse yaw. Finally, neither of the methods has anything to do with rudder in the turns, as you need to HOLD rudder input throughout the turn, NOT just at the point you initiate the roll prior to the turn. If possible, find the local general aviation airport and find a Cub pilot and talk to him/her.
Lifer is offline Find More Posts by Lifer
Old Oct 13, 2012, 08:19 AM
us185damiani is offline
Find More Posts by us185damiani
www.****enageair.org
us185damiani's Avatar
United States, PA, Watsontown
Joined Mar 2006
Mixing only works for the initial roll in. normal turns to maintain coordination rudder into the turn then opposite aileron to prevent roll coupling from over banking the airplane. Same way you do it in a real one.
us185damiani is offline Find More Posts by us185damiani
Old Oct 13, 2012, 08:26 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Two things:
- You actually want an aileron to rudder mix, aileron is the master and rudder is the slave.
- The amount you need is usually quite small, less than 10%.
It is not cheating, nor will it prevent you from cross controlling if you want to.
It simply makes flying the model easier since you are not in it to feel the adverse yaw when it happens. If you give 20% aileron it will amount to 2% rudder. No one is that good on the sticks.
Differential will also help, but nothing wrong with a bit of aileron to rudder mix if it works.
Put it on a switch and try it both ways. When you get the percent right you won't notice anything but that the model flies smoothly.
What transmitter are you using? Adding a mix is usually very easy.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Discussion Ail to Rud Mixes on landing/ takeoff Billymac Scale Sailplanes 40 Nov 03, 2009 07:45 PM
Discussion Mix Rud /Elev and Rud Ail in Delta Mode ?????? NX-687 Radios 1 Sep 27, 2009 10:16 PM
Discussion EVO programming for DLG (Ail/Rud mix) Kai@UCSB Hand Launch 9 Dec 22, 2006 10:21 PM
ail/rud mixing help needed w/ flash 5X Mike C Beginner Training Area (Aircraft-Electric) 4 Jul 19, 2002 07:01 AM
48"+, EPP, ail/elev/rud/ speed 500, 8 cell super FUN-FLY Arf-that's what I want Balin Foamies (Kits) 0 Jul 22, 2001 10:46 AM
