Old Oct 10, 2012, 10:01 AM
alibongo is offline
Find More Posts by alibongo
alibongo's Avatar
United Kingdom, England, Dorset
Joined Apr 2010
400 equivalent
Hi, what would be a brushless equivalent of a 400 motor ( I am assuming the 400 refers to brushed, as it is a strange, quaint Czech plane called "Bird")? And then would a 30amp esc be okay with a 1100 battery?Thanks in advance.
alibongo is offline Find More Posts by alibongo
Old Oct 10, 2012, 12:40 PM
aurorae is offline
Find More Posts by aurorae
aurorae's Avatar
Joined Sep 2008
Any motor rated at about 60 grams is considered the equivalent of a 400 motor. The brushless will proivde better power to weight than the brushed though, but a little more power is usually a good thing.
Choosing an ESC and a battery also requires choosing a prop and knowing the KV of the motor. In general, a 30amp ESC and a 3 cell 1100 battery should be fine with a 400 size motor, as long as you don't try to put too big a prop on it.
A watt meter is recommended to make sure you aren't drawing more amps than the ESC can handle, or more watts than the motor can handle or the battery can provide.
Here's a couple:
http://www.headsuprc.com/servlet/the...tor-1.9/Detail
http://www.headsuprc.com/servlet/the...-Slofly/Detail
http://www.hobbypartz.com/86ma08-2215-1150kv.html
aurorae is offline Find More Posts by aurorae
Old Oct 10, 2012, 07:19 PM
twn Chen is offline
Find More Posts by twn Chen
Taiwan, 北市
Joined Dec 2010
400 sized outrunner brushless motor normally means the 2208 one, while 450 size is 2212 ones. Be reminded to check their specs to find out the best performance from their KV values, the props and Voltages used.
twn Chen is offline Find More Posts by twn Chen
For Sale Leadfeather Yak or equiv gear joebob Aircraft - Electric - Power Systems (FS/W) 1 Sep 10, 2012 08:05 PM
Found Power 46,rimfire 46,rimfire 55 or equiv Tamiya tony Aircraft - Electric - Power Systems (FS/W) 2 Feb 25, 2012 06:06 PM
Sold EMAX 4020/08 (~60 equiv) and 3526/04 (~40 equiv) The Don Aircraft - Electric - Power Systems (FS/W) 1 Dec 04, 2010 08:38 PM
HL Dynamic GLH 400 Equiv DaleM Sport Planes 0 Jul 15, 2003 12:17 PM
WTB HS81's or equiv and a hitec 555 or equiv...for a zagi reznikvova Aircraft - Electric - Airplanes (FS/W) 2 Dec 12, 2002 06:56 PM
