United States, SC, Mt Pleasant
Joined Nov 2003
Frank,
Contact Red at "red@tgworks.com" and check out his blog http://www.rcgroups.com/forums/member.php?u=99628 James |
http://www.rcgroups.com/forums/showthread.php?t=1453871
This software runs the big clock from Red. Adrian has used a TV before as well to run the clock off the HDMI out of an android device. |
Latest blog entry: Swith in battery chemistry for all my...
Clocks From Two Lefties Timing
Frank,
I'd be happy to field your questions about our clocks. Bruce and I bought 3 of these big (10 inch tall characters) clocks and have spent this year programming them and getting them ready to meet the strict requirements of HLG contest timing. My initial foray into digital clocks was documented in this thread (http://www.rcgroups.com/forums/showthread.php?t=1115636). Unfortunately, these clocks form Louisiana weren't as bright as we really needed for outdoor timing, so last year when we found these big clocks available from China we got pretty excited. You can see some pictures of the current system in my blog http://www.rcgroups.com/forums/member.php?u=99628 So far the clocks have made it to several SASS contests, The Bruce, The NATS, Blue Skies over Utah, The 2012 TS in Denver (aka dust mitigation testing), and recently at the ECHLGF in NC. We've programmed the clocks to work with an RS232 connection to a laptop that runs a visual basic program that reads the .m3u files out of Oleg's F3K Score software. It plays the sounds out through the computer sound card and sends signals to the clocks through an RS232 connection. In parallel (as mentioned above) Adrian and I worked out some programming so that his F3K Master software would also control the software. F3K Master runs on an Android phone or tablet and sends sounds out of the device's 1/8 stereo jack and sends signals to the clocks through a bluetooth connection. Both systems have the exact same functionality, it's really a preference on how the CD wants to run his/her contest. The Blue Skies and the TS used the Android interface and the rest used the PC Laptop interface. Now answering your questions directly: 1. Where can they be purchased? Bruce and I would be happy to work with you to order your own set of clocks. We also will be renting the systems next year if that works better for you. Please IM me or email me (red@tgworks.com) for details. 2. Do they work with certain software? Windows Laptop (F3K_MP3) or Android (F3K Master) 3. How do they tie in with the F3K software to keep the window audio in synch with the display? Each software has its own programming scheme... but they both send signals to the clock that are synchronized with the sound files. I talk a lot about this in the thread above, and the scheme is similar to what Adrian is using, but I actually pursued a different scheme for the new clocks. 4. Are they a custom build project or can the be purchased from a retailer? We purchased the clocks from a Chinese wholesaler, and then the programming and interface was custom. We'd like to work with the HLG community to get more clocks imported and working, please email me for further information. Perhaps through a big group order this winter? 5. how much are they? Please contact me directly about this as well, there are several options available. 6. What is used to mount them? Price? We ordered speaker stands from eBay at 4 for $86. We then had to do some custom welding to mate them to the brackets the clocks came with. 7. What are their power requirements? The clocks can come with 120 VAC or 12 VDC. The ones we ordered were 12 VDC so they could run off of winch batteries at the field. In normal operation they pull about 1 amp, although the label on the clock says 60W, which would be ~5 amps at 12 VDC... In practice, a winch battery will run 2 clocks for a day of contest. Thanks, Adam |
Latest blog entry: Seattle HLG Clinic June 16th
New LED Clock Order
For those interested in getting a set of LED clocks like the ones used at the JEM our the US Team Selects, Two Lefties Timing is putting together an order from China. Please IM me or send me an email if you are interested and I'll send you information on pricing and such.
Thanks, Red red@tgworks.com |
Decision time
If you are interested in One of these LED clocks, please contact me ASAP, if your haven't already. Thanks,
Red |
Thanks Frank, no I was opening it to anyone who's interested in a clock.
Red |
| Thread Tools | |
| Help! Noob to HLG and DLG, need info on starting | porcia83 | Hand Launch | 14 | Aug 02, 2012 04:08 PM |
| For Sale Large Bug DLG, Los Angeles, LPU | Briskaop | Aircraft - Sailplanes (FS/W) | 3 | Apr 16, 2012 03:58 PM |
| Discussion Considering DLG...need info, please! | bmwbob | Sailplane Talk | 1 | Mar 08, 2008 10:40 AM |
| Need more info about the PCM DLG! | pitch black | Hand Launch | 1 | Jan 22, 2005 09:28 AM |
