Old Oct 10, 2012, 09:43 AM
DBono99 is offline
Find More Posts by DBono99
United States, NJ, Paramus
Joined Jun 2004
Lipo for my TX
Hi All I would like to know who in the US sells Lipo's for TX's?
I have (2) Futuba TXs that I would like to change over too Lipo's.
Thanks Dan
DBono99 is offline Find More Posts by DBono99
Old Oct 10, 2012, 09:46 AM
Ken Myers is offline
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
Dan,
You are going to hear it a lot, but Sanyo Eneloops are a much better choice. Do a search here on RC Groups for Eneloop for more info. Use what you want, but Eneloops, to me are a much better solution.
Ken
Here's a little something I wrote up for the November Midwest RC Society newsletter on this topic.
Li-Poly Use as Transmitter Batteries
Some folks have been using Li-Pos as transmitter batteries. That is probably not the BEST use for them, since they may require a voltage regulator, must be removed for charging and if a transmitter is accidentally left turned on, the battery will be ruined.
Sanyo Eneloop low self-discharge (LSD) cells are excellent for use in transmitters. They have a high capacity (2000mAh), hold their charge for weeks and can be charged with the transmitter's "wall wort" charger.
Eneloops are available at COSTCO or pre-made packs are available at No BS Batteries or Radical RC.
Ray'O' Vac call their version of LSD NiMH cells a Hybrid.
Ken Myers is offline Find More Posts by Ken Myers
Last edited by Ken Myers; Oct 10, 2012 at 09:49 AM. Reason: added note from Midwest RC Society Monitor Newsletter
Old Oct 10, 2012, 11:54 AM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Hi Ken,
Good advice for older legacy radios that use an 8 cell pack, but the newer radios that use a 6 cell Nimh pack are a different story, only the opening the battery compartment to access the balance tap is an issue to some.
I have the low voltage warning on my Futaba 8FG set to 7.4V, a bit higher than necessary for a 2S pack, but if I were to forget and leave the Tx on, at 5.5V, the radio will power itself down to protect the memory from being scrambled. The 2S Lipo made for the 8 & 12FG radios from Value Hobbies is 1/3rd the price of a new Sanyo pack of 2150mAh Nimh, no Enyloopers in the 4/5A size cell size as yet.
Of course the new Spektrum radios even have the Lipo charging capability in the radio wit an optional Lipo pack. Somehow, charging a 4000mAh Lipo inside the radio at a rate that makes unattended charging unavoidable doesn't give me a warm fuzzy feeling, but that's just me. I charge my 2500mAh Tx lipo at the field, on a charging table during lunch with one of my Cellpros, quick and safe
Ken, from your Avatar I'm sure you're familiar with the song "The times, they are a' changin"
Cheers,
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Oct 10, 2012, 11:47 PM
dgolding is offline
Find More Posts by dgolding
Lipoflyer
Joined Sep 2012
Ken, Pete.....very good, informative answers for Dan! Here's a sales pitch for Dan! I had the concerns that Ken raises 4 years ago when I wanted to convert my Tx's over to Lipo. So I designed a board that addresses the Lipo issues and is specifically designed to allow use of 3-cell Lipo in a 9.6V Transmitter! It keeps the maximum voltage to your Tx less than 12V on a fully charged pack, and when the pack reaches 9V it cuts the battery off so it does not ruin itself if you leave the Tx switch on accidentally all weekend! If you lave a TX switch on, the electronics still tries to "draw" current from the battery. By the way, it won't shut off your Tx during use, because your Low Voltage alarm will come on, and your LCD display will go blank long before the 3-cell pack gets down to 9V. I've sold a couple hundred of them so far and everyone loves them! The "dime-sized" board plugs in between the battery and your Tx. Search Li-Po Power Board on e-bay. I'll be selling those boards and a Smart Soft Switch (for safely using 2-cell Lipos in flight pack) at the 2012 Tucson Aerobatic Shoot Out next weekend!
Don
dgolding is offline Find More Posts by dgolding
Old Oct 11, 2012, 12:12 AM
dgolding is offline
Lipoflyer
Joined Sep 2012
Thanks Dan
Dan,
Sorry....none of us actually answered your original question!! Take a look at this link. There are others, too. Search for Transmitter Lipo Battery Pack and you will find more.
http://www.headsuprc.com/servlet/the...SMITTER/Detail
Don
Old Aug 15, 2013, 07:21 PM
DBono99 is offline
Joined Jun 2004
Eneloops
HI All I went with Sanyo Eneloops. I was at a show and some one had them for sale, at a price I could not refuse,... I purchased the 2200,I haven't used them yet, they were purchased in Nov.I will get around to putting a plug and charge them.
Thanks Dan
Question Thinking of trying the TX lipo for my Futaba 7C................ mtdoramike Batteries and Chargers 77 Jul 01, 2012 08:54 PM
Discussion Looking for a way to transmit video from my Sony Nex5n to my 900mhz video TX jasper7821 Aerial Photography 2 May 29, 2012 02:00 PM
Discussion Best HK charger for my purposes (3s lipos + TX ? TheNiceGuy Batteries and Chargers 32 Aug 10, 2011 02:21 AM
Discussion Is my LiPo okay for my Tx? CRAZYDAVE Batteries and Chargers 12 Mar 02, 2009 03:13 PM
Help! I want to set my TX Timer, for Lipo run time RCHSF Micro Helis 5 Mar 15, 2007 09:11 PM
