Old Oct 10, 2012, 09:40 AM
8thelephant is offline
Find More Posts by 8thelephant
Soaring Fanatic!
Joined Dec 2008
Remote power switch....
I'm just getting into night flying and planning to build my next foamy with a remote switch.
Are there any other options than the RC-Lights #5090 : Remote Power Switch?
http://www.rc-lights.com/products/RCL5090.html
The plan is to embed 4-6 SMD 5050 strips into a foam wing and then be able to turn them on/off without opening the ship.
Any suggestions would be greatly appreciated :-)
-8th
8thelephant is offline Find More Posts by 8thelephant
Old Oct 10, 2012, 10:06 PM
Soaring Fanatic!
Joined Dec 2008
Cool suggestions. The Dimension Engineering Pico looks perfect
Thanks a bunch,
-8th
Old Oct 11, 2012, 06:46 AM
electrotor is offline
Find More Posts by electrotor
Bonnie Scotland
Joined Jun 2004
Bear in mind that the two HobbyKing switches and the Pico switch, whilst they can handle more current than the rc-lights switch, will not supply power to the LEDs. They merely switch on or off a separate power supply. If you are going to be using less than 300mA the rc-lights switch would be simpler and much lighter.
electrotor is offline Find More Posts by electrotor
Old Oct 30, 2012, 11:07 PM
mike_m2 is offline
Find More Posts by mike_m2
mmerry2 on Youtube
mike_m2's Avatar
United States, MD
Joined Nov 2010
If you want to make your own switch, just take apart an old servo and add 2 resistors, then follow this wiring diagram:
http://fromemodelflyingclub.files.wo...witch-leds.pdf
mike_m2 is offline Find More Posts by mike_m2
Sold New - Multi-Remote Receiver operated on/off Switch whatasteele FPV Equipment (FS/W) 3 May 07, 2012 02:55 PM
Sold New - Multi-Remote Receiver operated on/off Switch whatasteele Aircraft - General - Radio Equipment (FS/W) 3 May 07, 2012 12:46 AM
Discussion need some help with a remote kill switch for human powered flight Kevin Graehl Radios 13 Dec 04, 2008 01:45 AM
Discussion need help designing a remote kill switch for human powered flight Kevin Graehl DIY Electronics 0 Nov 04, 2008 07:04 PM
Help! R/c Remote Power Switch bitusbates DIY Electronics 14 Sep 18, 2008 10:53 AM
