Old Jan 23, 2013, 07:25 PM
cap10jaf is offline
Find More Posts by cap10jaf
cap10jaf's Avatar
United States, FL, Casselberry
Joined Jun 2006
Originally Posted by Doushiyou12 View Post
Rich,
As always thanks for your info.
I didn't spent too much time on my radios. I just pluged them in for "airframe clearing"purposes. I will check out the setting further.
Thanks again.
Looking great!
I'm not sure what your wiring set-up is, but this little Turnigy 3 channel controller works great for my trike servoless retract system:
http://www.hobbyking.com/hobbyking/s...idProduct=8863
Be advised you need a male to male servo lead to connect this to your receiver.
GD
cap10jaf is offline Find More Posts by cap10jaf
Old Jan 23, 2013, 08:11 PM
WAGliderGuy is online now
Find More Posts by WAGliderGuy
Airliner Builder
WAGliderGuy's Avatar
United States, WA, Seattle
Joined Feb 2010
Vid of the main retract test
http://m.youtube.com/watch?v=Gwy8aMNEfi4
No sure why the delay
Looking good! I got the same delay while using the E-Flite Y-harness (the small ones with tiny guage wires) and got a boost when switching to more beefier ones. Every once and awhile I still get a delay though
Keep up the great work!
Ethan
WAGliderGuy is online now Find More Posts by WAGliderGuy
Old Jan 29, 2013, 09:27 PM
Doushiyou12 is offline
Find More Posts by Doushiyou12
Doushiyou12's Avatar
Joined Feb 2010
Thanks for advise guys.
Ok some updates. Rear section is finished and installed to the fuse. Nose section is ready to be installed but will keep it off until last min.
I'm still working in the main landing gears.
Flaps are linked up as well.
Next is to hook up the engine pylons and motors along with running the ESC's,
I'm not sure what I was thinking prior to starting this big bird.
Doushiyou12 is offline Find More Posts by Doushiyou12
Old Jan 29, 2013, 11:18 PM
demondriver is offline
Find More Posts by demondriver
Up-Out-&-Gone
demondriver's Avatar
United States, SC, Charleston
Joined Mar 2007
O.K. get out your camera . . . . . PLEASE!
demondriver is offline Find More Posts by demondriver
Latest blog entry: Foam Safe Spray paint!
Old Jan 29, 2013, 11:28 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
ditto.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Jan 31, 2013, 09:35 AM
Joined Feb 2010
fuse is done minor sanding here and there. Wings are finished pylons are on.
I just put this big bird on the scale. she is at 2.5 lbs. All it needs are the motors, wheels, esc's and lipos.
-she is at 79in in length 84 including the tail. seriously what was i thinking
help.
how should the angle of the motors go?
face a bit down ?
level with fuse?
Old Jan 31, 2013, 11:50 AM
SergeyK is offline
Find More Posts by SergeyK
SergeyK's Avatar
United States, NY, Kings
Joined Feb 2006
help.
face a bit down ?
level with fuse?
I suspect you need to point them a little down. If you think about it - if you hold the plane at its exact CG and apply power, since the engines are below the CG, they would create a torque rotating the nose up.
SergeyK is offline Find More Posts by SergeyK
Old Jan 31, 2013, 01:06 PM
Up-Out-&-Gone
Joined Mar 2007
Doushi, Sergey is right the #2 engine on the DC-10 is angled a tad up and the two wing engines seem to be level with the fuse, I personally try and match what is on the real thing that way your airliner will behave a tad more predictably.
By the way she looks FANTASTIC BRO!
Old Jan 31, 2013, 01:12 PM
SergeyK is offline
SergeyK's Avatar
Joined Feb 2006
Ah, but then in this case I'm actually wrong and my logic does not work. Because according to my logic you'd need to angle all 3 engined down, not up.
Old Jan 31, 2013, 01:21 PM
clsink1128 is offline
Find More Posts by clsink1128
clsink1128
clsink1128's Avatar
United States, IA, Burlington
Joined Aug 2011
what would happen if the engines were angled a tad up
clsink1128 is offline Find More Posts by clsink1128
Old Jan 31, 2013, 01:38 PM
Joined Feb 2010
Don't forget my horizontal stabs are a few degrees downward as well
jmpdgs is offline
Find More Posts by jmpdgs
A Global Force For Good
jmpdgs's Avatar
USA, OH, Cincinnati
Joined Jun 2009
Hi Doush:
Your fuse looks great, very clean work, I wish mine were as precise.
In answer to your question on placement, and angle I think you'll find this short paper useful. The most relevant info will be in the last section.
Hope this helps.
Joe
jmpdgs is offline Find More Posts by jmpdgs
Old Feb 01, 2013, 01:10 AM
Joined Jan 2009
there's also the logic that says that your thrust angle should match your datum/waterline and that your incidence angle(s), or lack of should also match your thrust/datum lines. of course, good decalage would dictate that the angle of incidence of the wing should not be the same as the horizontal tail so that you will have positive stability.
Old Feb 28, 2013, 05:24 PM
Joined Feb 2010
Minor update
Fuse semi painted. Fuse is 632g. I changed my mind about transporting bird. I modified the the wing box to make it a one piece wing. I will pass my target of 3.5lbs.
Old Feb 28, 2013, 05:39 PM
Up-Out-&-Gone
Joined Mar 2007
Minor update
Looking great Doushi! How much over 3.5lbs have you gone Sir?
Mini-HowTo New Life above 3.5kw for the Haoye 90mm-7blade...New Motor Building Info on Pg1 7/14 Knife Liddle Electric Ducted Fan Jet Talk 244 May 04, 2013 02:06 PM
Sold New E-Flite F-4 with All new items to build MikeATL Aircraft - Electric - Jets (FS/W) 1 Sep 08, 2012 02:48 PM
Discussion New build and new to multirotors jfcmn Multirotor Talk 1 Mar 30, 2012 01:48 PM
