This thread is privately moderated by bobepine, who may elect to delete unwanted replies.
Old Nov 03, 2012, 09:07 PM
Gavinxman is offline
Find More Posts by Gavinxman
Trader Rating: 3
Gavinxman's Avatar
Joined Aug 2011
Trader Rating: 3
Gavinxman is offline Find More Posts by Gavinxman
Old Nov 03, 2012, 09:08 PM
Creepy1 is offline
Find More Posts by Creepy1
Trader Rating: 29
Mother warned you about me!
Creepy1's Avatar
Canada, ON, Kapuskasing
Joined Mar 2012
Trader Rating: 29
Originally Posted by Gavinxman View Post
i got it to power up with dx5 but when it tries to lift off it goes back and down . i know prop are on right as these have a R after the number and they are on the CW and the props without the letter R are CCW . newbies what can you do lolololo OK SO I THINK I HAD THE THROTTLE HOLD OR AUTO ON AND I WENT INTO SENSOR TEST AMD IT LETS ME SEE WHATS WHAT , SO I TURNED IT OFF AND UP IT COMES BUT ITS NOT STABLE SO I GUESS I NEED TO GO OUTSIDE AND TRY AND SEE WHATS WHAT
Make sure motors are...
1 2
4 3
Make sure your props spin...
cw ccw
ccw cw
White wires on the board should all be pointed to the center with your black wires all to the edge of the board. Hope that helps.
Creepy1 is offline Find More Posts by Creepy1
Old Nov 03, 2012, 09:28 PM
bobepine is online now
Find More Posts by bobepine
Trader Rating: 194
bobepine's Avatar
Joined Jun 2011
Trader Rating: 194
1- reduce stick scaling to 25 on pitch and roll.
2- with rx bound, go into "receiver test" then move the sticks. The LCD will display which stick movement you are applying and the direction. Do not try to lift off until each stick movement is shown as correct.
3- escs are labeled. 1- cw 2- ccw 3- cw 4- ccw propeller.
Chris
bobepine is online now Find More Posts by bobepine
Site Sponsor
Latest blog entry: Armattan F1 Lineup Revealed
Old Nov 03, 2012, 09:49 PM
tech69x is offline
Find More Posts by tech69x
Trader Rating: 32
Custom quad builder
tech69x's Avatar
United States, CO, Boulder
Joined Apr 2012
Trader Rating: 32
I use a 9x with a quad did you bind the the tx to the rx
tech69x is offline Find More Posts by tech69x
Old Nov 03, 2012, 11:47 PM
Trader Rating: 194
bobepine's Avatar
Joined Jun 2011
Trader Rating: 194
OK. I'm at my computer for another 30 minutes or so if you need help.
Don't touch the ESC connection to the board. You saw it fly. All I did is remove my RX and shipped it to you, so it's still all good. Motor rotation is already checked and no need to look at that, either. The problem lies with one of the following three things:
1- Propellers configuration
2- RX connection to the KK2
3- Radio settings
You need to do a receiver test. With the quad bound to the radio, under "receiver test" the KK2 will tell you which stick you are moving and in which direction. For example, if you're moving the ailerons stick and the LCD tells you that you are moving the elevator, this means you have Aile and Elev channel mixed up. Also, if you move the ailerons left, and the LCD tells you that you are moving the ailerons right, this means you have to reverse the channel in your radio.
Also, if the board won't arm, it could be that the KK2 is not reading 0% throttle so you need to just lower the throttle value using the throttle trim. Set it to negative 1% and it should be enough.
If it flips on you after all the receiver test looks OK, you most likely have the wrong propeller configuration.
Oh, and as mentioned in the video, I do not program "auto level" because I don't use it and because it simply doesn't work well on the KK2. So make sure that when the board is in safe mode that you read "auto level: off" on the LCD display.
Hope this helps.
Best,
Chris
Site Sponsor
Old Nov 04, 2012, 12:38 AM
Trader Rating: 3
Gavinxman's Avatar
Joined Aug 2011
Trader Rating: 3
Old Nov 04, 2012, 12:55 AM
Trader Rating: 3
Gavinxman's Avatar
Joined Aug 2011
Trader Rating: 3
Old Nov 04, 2012, 01:25 AM
tech69x is offline
Trader Rating: 32
Custom quad builder
tech69x's Avatar
Joined Apr 2012
Trader Rating: 32
Are you using the frsky rx if so is the light red or green
Old Nov 04, 2012, 01:37 AM
Trader Rating: 3
Gavinxman's Avatar
Joined Aug 2011
Trader Rating: 3
Old Nov 04, 2012, 01:38 AM
shafter is offline
Find More Posts by shafter
Trader Rating: 1
Poland, Śląskie, Bielsko-Biala
Joined Jan 2012
Trader Rating: 1
Gavin
I'm flying using 9X + 9X RX and it's fine (except very poor range !)
Try this procedure and see if that helps for "46% throttle":
http://www.hacksmods.com/2012/08/fly...bration-howto/
Also try to find somebody to flash to radio to ER9X or order smarie parts board.
ER9X makes using 9X way way way eaiser and nicer for beginners !
shafter is offline Find More Posts by shafter
Old Nov 04, 2012, 01:41 AM
Trader Rating: 3
Gavinxman's Avatar
Joined Aug 2011
Trader Rating: 3
Old Nov 04, 2012, 01:46 AM
shafter is offline
Trader Rating: 1
Joined Jan 2012
Trader Rating: 1
Gavin i've edited link for you ^^
Old Nov 04, 2012, 01:55 AM
Trader Rating: 3
Gavinxman's Avatar
Joined Aug 2011
Trader Rating: 3
Old Nov 04, 2012, 09:22 AM
shafter is offline
Trader Rating: 1
Joined Jan 2012
Trader Rating: 1
Armattan onboard footage
Remeber that im ain't Chris
Armattan 339 + 808 16 keychain - lot's of jello and vibrations ;) (5 min 1 sec)
Old Nov 04, 2012, 09:30 AM
Bryan's Flyin is offline
Find More Posts by Bryan's Flyin
Trader Rating: 34
United States, MO
Joined Apr 2009
Trader Rating: 34
Very nice video and good job flying. What camera are you using? I almost got sea sick watching this!
Bryan's Flyin is offline Find More Posts by Bryan's Flyin
Discussion (Nearly) Indestructible EPP Trainer acetech09 Foamies (Scratchbuilt) 1 Jul 09, 2012 07:16 AM
Sold Micro Cessna ShokWaveRider Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 May 25, 2012 04:19 PM
Sold Micro Xtra 300 ShokWaveRider Aircraft - Electric - Airplanes (FS/W) 0 May 24, 2012 07:22 AM
Cool Indestructible Camera nonamerc Beginner Training Area (Aircraft-Electric) 11 Apr 22, 2012 09:34 AM
Mini-Review 1080p Video Review: Air Time RC Products Indestructible Skids with Extreme Testing SYMAWD Micro Helis 2 Mar 28, 2012 03:15 PM
