Old Oct 10, 2012, 02:28 AM
jofro is online now
Find More Posts by jofro
jofro
Joined Jan 2010
"MIRAGE 2000" - SM90/8S - back again - latest vid.
I never thought I end up with this 90mm foamy, never liked the model but for $129-on special, I thought it was a great deal to hot it up. J.
jofro is online now Find More Posts by jofro
Old Oct 10, 2012, 09:50 AM
tomme21 is online now
Find More Posts by tomme21
tom
tomme21's Avatar
USA, LA, Natchitoches
Joined Apr 2004
you will love this jet, great flier, slows down slow for great high alpha landings.
tomme21 is online now Find More Posts by tomme21
Old Oct 10, 2012, 11:48 AM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Where is it on special? Lee
capt soap is offline Find More Posts by capt soap
Old Oct 10, 2012, 11:56 AM
kremecheze is online now
Find More Posts by kremecheze
kremecheze's Avatar
United States, NY, Queens County
Joined Jun 2007
i think hk has em for 129$ but with shipping it comes out to like 175$ i want a 90mm mirage so bad..but i think i will pay a little more and order it from jepe with a lot of the mods already done
kremecheze is online now Find More Posts by kremecheze
Old Oct 10, 2012, 02:36 PM
gianni sanchez is offline
Find More Posts by gianni sanchez
Belgium, Walloon Region, Mons
Joined Jan 2012
hey there !wayyyyyyyyy much better the JEPE version!
nothing compare to the stock flyfly one , and the price at jepe is even less than those 129bucks here in europe
that worth the look
http://www.jepe.org/jepeshop/111-mirage-fast-foam
gianni sanchez is offline Find More Posts by gianni sanchez
Old Oct 10, 2012, 06:06 PM
flylow2011 is online now
Find More Posts by flylow2011
Joined Nov 2011
lovely mirage 2000 but jepe is ... out of stock for now :-(
but extremerc of australia will have the camouflaged version soon :-)
here is the video of this mirage 2000 with 10 blade CS 70mm fan, 6s power 2200 KV motor ... enjoy
Fly Fly mirage 70 mm changesun 10 blade fan Eflite bl-32 motor 6s 4500 45c nanotech (2 min 43 sec)
flylow2011 is online now Find More Posts by flylow2011
Old Oct 10, 2012, 09:12 PM
jofro is online now
jofro
Joined Jan 2010
6mm C/F wing tube fitted in support of landing gear formers, Elevon servos moved back for more precise controls and proper hinges installed, J.
Old Oct 11, 2012, 01:57 AM
jofro is online now
jofro
Joined Jan 2010
I made up 100mm long thrust tube sleeved over the shroud and tapered from 90 down to 76mm to get the best out of my power system, J.
Old Oct 12, 2012, 01:38 AM
jofro is online now
jofro
Joined Jan 2010
Too cold and windy for flying so bit more work done on Mirage, J.
Old Oct 13, 2012, 01:47 AM
jofro is online now
jofro
Joined Jan 2010
Hi Guys, the weather is going nuts, almost summer here but it's snowing all aver the country! The coldest October I ever remember, where is the "GLOBAL WARMING?"
Time to build models, J.
Old Oct 14, 2012, 02:39 AM
jofro is online now
jofro
Joined Jan 2010
Being stuck now, while waiting for some components to arrive. New accsess made up for ESC and reinforcing some parts of the fuse. Also checked up for the first time my CofG as fully loaded using 8 and 10S/4000 set of batteries, working all very well with my new larger battery base, J.
Old Oct 14, 2012, 04:43 PM
jofro is online now
jofro
Joined Jan 2010
760 grams, empty airframe, should be well over one to one power to weight ratio, J.
Old Oct 15, 2012, 05:07 PM
jofro is online now
jofro
Joined Jan 2010
Elevon controls are fully hooked up using good MG servos with minimal push rods length for precize movement. No idea who designed these huge Elevon moving tabs!? Half the size would be more then enough for this size of model. Reminds me more of the controls on my large 3D gassers.
Wing covers were badly warped, some surgery and light filler fixed that. Main landing gear is next, before I design my nose steering mechanism to get some positive angle of atack, J.
Old Oct 16, 2012, 01:20 AM
jofro is online now
jofro
Joined Jan 2010
Landing gear is fully complete, waiting for ESC to test few different power systems inside of the model before full completion, J.
Old Oct 17, 2012, 08:44 PM
jofro is online now
jofro
Joined Jan 2010
Finishing off the nose gear while using bits and pieces. With the heavy load of batteries in the nose I'm beefing it up, also fitting in the rear brace.. "Note" the foam cut out area behind the wheel, this is another weak spot that must be reinforced! With the hotted up models the wing could easilly rip out as there is no structual support in there, just a thin layer of foam. Currently taking bit of break from my built while prepearing my foamy monsters for the Jet Meet in QLD, J.
Build Log Megajets Mirage 2000 Build Guide superscott Foamies (Kits) 12 Jun 01, 2012 05:38 PM
Discussion mid air crash mirage 2000 40 pound turbine!! sherlockshah Jet Turbines 6 May 09, 2012 08:50 AM
For Sale NIB PNP Skyangel JAS39 Mirage 2000 FW190 T28 FMS 1400 & 800 warbirds www.hobbyb.com Aircraft - Electric - Airplanes (FS/W) 1 Apr 29, 2012 07:30 PM
Discussion amazing footage 40 pound turbine mirage 2000 Midair crash!!! sherlockshah Crash Discussion 21 Mar 29, 2012 10:10 AM
