Old Oct 10, 2012, 01:48 AM
mrexcel is offline
Find More Posts by mrexcel
mrexcel's Avatar
Joined Jul 2009
Gallery
The 2x Butterfly
This is my scratch built 2x Butterfly. Right now the airframe weigh 2.5 grams. I am planning to use a 6mm motor and 40mAh Lipo with 0.5g home made actuator.
The real Plantraco Micro Butterfly is also there as a reference.
Any suggestions will be most welcomed!
Cheers
mrexcel is offline Find More Posts by mrexcel
Old Oct 10, 2012, 12:38 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
Wasn't the micro butterfly already half size of the original balsa butterfly? So yours is a foam version of the old one? Or is the span different?
derk is offline Find More Posts by derk
Old Oct 10, 2012, 12:45 PM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
I didn't know there was a balsa butterfly. Mine the span is 8"
Old Oct 10, 2012, 03:31 PM
derk is offline
derk's Avatar
Joined Dec 2003
Here is the original balsa butterfly http://www.microflight.com/Butterfly-Livingroom-Flyer
Uses a 4mm gear drive and 30mah cell.
Looking at the old one, its span is 6.5 inches so yours is still larger and could handle the 6mm motor and 40mah cell.
Old Oct 10, 2012, 10:56 PM
mrexcel is offline
mrexcel's Avatar
Joined Jul 2009
Thank you Derk for the information.
Old Jan 12, 2013, 08:34 PM
rogenstein1983 is offline
Find More Posts by rogenstein1983
rogenstein1983's Avatar
Joined Feb 2012
That looks cool I've made a very similar plane as well as haveing a go at makeing my own micro butterfly which is good fun, your one should be a good livingroom flyer! do you have a side pic
rogenstein1983 is offline Find More Posts by rogenstein1983
Old Jan 12, 2013, 08:37 PM
Joined Feb 2012
Cheers
Hiya what rx are you going to use I like the deltang rx52 there perfect for lrf and real small stuff
For Sale Spektrum Receivers, 2x AR7000 and 2x AR6100e mahak213 Aircraft - General - Radio Equipment (FS/W) 9 May 28, 2012 08:18 AM
For Sale Thunder Power Lipos, 12s(2x 6s) 4400's, 10s(2x 5s) 4400's, 6s 2700's VERY FEW CYCLES paulpeffly Aircraft - Electric - Batteries & Chargers (FS/W) 0 Apr 06, 2012 03:27 PM
Sold Ultimate 2000w Charging Setup 2x 3010b's, 2x meanwell 1000w, pelican case paulpeffly Aircraft - Electric - Batteries & Chargers (FS/W) 2 Mar 23, 2012 05:37 PM
Sold Walkera 2801 Pro 8CH Transmitter + 2x 6CH Rx's, 2x BL motors omster Aircraft - General - Radio Equipment (FS/W) 0 Mar 10, 2012 07:16 AM
