Old Oct 09, 2012, 11:33 PM
mindystorm is offline
Find More Posts by mindystorm
Canada, BC, Richmond
Joined Aug 2012
Arb?
Ok, on my tg9, there is a glider mode. Instead of the normal thr (throttle) on the display list, there is an arb
mindystorm is offline Find More Posts by mindystorm
Old Oct 10, 2012, 04:07 AM
SimonChambers is offline
Find More Posts by SimonChambers
Radio? Screwdriver!
United Kingdom, England, Bristol
Joined Aug 2011
airbreak?
SimonChambers is offline Find More Posts by SimonChambers
Old Oct 10, 2012, 04:04 PM
Joined Aug 2012
Originally Posted by SimonChambers View Post
airbreak?
Wait...so if I move the throttle higher there will be more of an airbrake?
Old Oct 10, 2012, 05:10 PM
Radio? Screwdriver!
Joined Aug 2011
I'm not a glider guider, but I believe if you reduce the throttle the airbrake will be deployed more. I.e. low throttle = low speed.
However I'm sure someone more knowledgeable on gliders will chime in.
Si.
Old Oct 11, 2012, 06:24 AM
dickw is offline
Find More Posts by dickw
Grow old disgracefully!
dickw's Avatar
Luton, UK
Joined May 2006
If your glider has airbrakes - yes.
On many gliders the airbrake is used in a mixer to the aileron and/or flap servos to provide an airbrake function (ailerons up a lot and flaps down a lot).
The direction you move the stick to get the brakes to work depends on your personal preference as it is reversible in most Tx.
Dick
dickw is offline Find More Posts by dickw
FS - ARB GWS E-Starter Sac., CA only sierra-gold Aircraft - Electric - Airplanes (FS/W) 2 Feb 28, 2005 11:47 AM
