Pretty much everything you need to know here.
http://www.rcgroups.com/forums/showthread.php?t=1136470 |
Joined Sep 2012
Hi Tommy2178xxx,
I found this HK tutorial after learning more about motors, I wish I read i sooner: http://www.hobbyking.com/hobbyking/store/ebasic.asp. 600g thrust for a 250g airplane sounds way overpowered. I’ve read that anything with ~150% thrust to weight is a very respectable 3D flier. So you could get away with 375g of thrust if your goal was to make it really overpowered. Anything else is probably just gratuitous vertical acceleration Yee Haw! My lady and I just set up a similar thrust-to-weight ratio on a slow stick and it's a blast. I’ve got a low KV motor with a large prop and at WOT it goes the same speed in any direction but it’s not very fast. If you want to go fast, I’d recommend a higher KV setup. It’ll probably look more natural for a T-28 to scream around and have a more reasonably sized prop. I don't know if you already know this stuff, I'm just learning it myself. Sounds cool BTW, you should totaly post pics and video! |
Lenox, Michigan
Joined Nov 2005
Less weight = better flying plane.
I always base my motor decision on thrust and weight. Lots of websites like www.headsuprc.com have detailed information on what kind of thrust and amps each prop size puts out. I always go with better than 1:1 thrust to weight and I am safe. But i really like to be in the 1.5 or 2:1 region. |
| Thread Tools | |
| Discussion power to weight ratio of war birds | mikes68charger | Fuel Warbirds | 1 | Apr 13, 2012 09:08 PM |
| Discussion Weight Question | Woodford | Video Piloting (FPV/RPV) | 4 | Apr 07, 2012 10:02 AM |
| Discussion Wanderer glider weight question | Riodiler1 | Thermal | 8 | Apr 05, 2012 12:08 PM |
| Question Design Questions - power and speed versus weight | Yehya | Indoor and Micro Models | 9 | May 17, 2008 09:08 PM |
| Question Servo Power/Weight Question for new build | Cmiller | Electric Sailplanes | 8 | Jun 05, 2007 10:12 PM |
