This thread is privately moderated by bzfrank, who may elect to delete unwanted replies.
Old Oct 09, 2012, 09:32 PM
bzfrank is offline
Find More Posts by bzfrank
4.2V of pure Kraut power
bzfrank's Avatar
Germany
Joined Nov 2006
Flag towing
Towing a flag is fun and can be done quite easily. It works exactly like towing a banner but requires less power and can be done by smaller planes (depending on the flag size of course). The following works for me:
Above images my biplane (loosely based on an Udet Flamingo) with 1.80m wingspan towing a 90x60cm flag. Also a 120x90cm one works fine with this setup.
This scheme describes how to attach the flag. It also works for a banner.
For takeoff place the flag flat on the ground, straighten the line and slowly increase speed. It will move to an upright position once in the air automatically.
Attach the line to the tow release, which should be located about 10-20% of the fuselage length behind the GC. Now for the important part: Be sure the line runs below the elevator! In the air the flag is always below the airplane, so the line will otherwise press on your elevator and that can ruin a perfectly good day. Also don't fly too fast, the flag will add quite some drag and will flutter at higher speeds, beside it does not look good.
Its possible to land with the flag attached but it is safer to release it before landing. If it stucks somehow in the ground it can damage your plane.
I strongly recommend to put a tow release in your airplane, so you can drop it off anytime. Also as a percaution do not fly over populated aeras or people. When the flag comes off it drop from the sky rather fast.
bzfrank is offline Find More Posts by bzfrank
Old Oct 09, 2012, 11:43 PM
Manudepron is offline
Find More Posts by Manudepron
Manudepron's Avatar
Belgium, Walloon Region, Namur
Joined Apr 2010
Thank you: I thought recently to tow a banner but didn't knew how to.....
Manudepron is offline Find More Posts by Manudepron
Old Oct 13, 2012, 09:42 AM
gabrielisrael is offline
Find More Posts by gabrielisrael
Got the Slickness
gabrielisrael's Avatar
Seattle, WA
Joined Jul 2010
very creative and looks fun!
thanks for sharing....
gabrielisrael is offline Find More Posts by gabrielisrael
Sold PA25 Pawnee 96"-Tow Plane or Banner Tow unclegeorge Aircraft - Fuel - Airplanes (FS/W) 5 Jun 04, 2012 06:40 PM
Found Tow Plane tow hook Woodbender Aircraft - Sailplanes (FS/W) 0 Apr 15, 2012 09:50 PM
Help! Towing a flag/banner xlr82v2 Fuel Plane Talk 18 Oct 24, 2008 12:45 PM
Discussion Towing a Flag xlr82v2 Flight Accessories 8 Sep 03, 2008 11:05 AM
Successful flag towing at the fireworks show!! eBird Parkflyers 15 Jul 04, 2003 10:47 PM
