This thread is privately moderated by MadLab, who may elect to delete unwanted replies.
Old Oct 09, 2012, 08:59 PM
MadLab is offline
Find More Posts by MadLab
United States, IL, Chicago
Joined Oct 2011
FPV Antenna Tracking
We have been working with the Crius AIO Pro board and the APM Mission Planner while doing some FPV flights and videos. In the process of our work we decided we needed to come up with a good Antenna Tracking solution so we could worry a little bit less about losing connection with our video transmitter while in flight.
After some careful thought and research we decided the Antenna tracking system would need to have the following requirements.
  • 360 degree pan rotation.
  • At least 40 degree downward tilt, and 90 degree upward tilt
  • Mountable on a Tripod
  • Have its own power supply
  • Be compatible with the APM Mission Planner
  • Capable of switching antenna plates to support different setups
  • Tilt upgradable to dual servos
The pan features a gear box with 7:1 reduction in order to achieve a smooth 360 degrees of rotation on the pan, and be able to support enough weight for all the antennas and anything else we want to add. The tilt uses a standard metal gear 15kg servo that is mounted in side the tilt panels.
After some time of researching the internet and messing around with APM we got the antenna tracking system to work pretty well. Below are some pictures of the system itself. We will hopefully get some videos of it in action and up tomorrow weather providing.
Anything you think we should add to make it more compatible or upgradable? let us know.
You can check out more about it at our website
MadLab is offline Find More Posts by MadLab
Old Oct 14, 2012, 05:08 PM
zachbayne is offline
Find More Posts by zachbayne
Joined Dec 2010
I am very interested in this, It looks beautiful.
zachbayne is offline Find More Posts by zachbayne
For Sale Complete FPV setup with tracking station antenna tripod, case and monitor blade thrasher FPV Equipment (FS/W) 13 Jun 10, 2012 10:00 AM
Build Log My home made FPV system: OSD+diversity+telemetry+tracking antenna+autopilot+IMU+PC Zbig FPV Talk 102 Sep 25, 2011 01:15 AM
Discussion Home made FPV parts..camera pod..antenna tracking..:D DavorVZ FPV Talk 6 Sep 04, 2010 06:06 AM
