Latest blog entry: tgz
![]() I might try it again today! |
Philippines
Joined Jul 2012
My next order is probably going to be carbon fiber tail booms. Is that a good idea? Or will it just transfer the energy to the main frame and tail rotor? I'm building a flybarless so no flybars, tho the comment about main gears is a bit disconcerting. Most of the mass and kinetic energy is in the propellers so the main gear shouldn't be carrying any load if the motor was turned off o_0 |
what felt different specifically inverted, from sim to real life? I ask because I'm yet to try an inverted hover in real life, other than going inverted for a sec when I was high up, and even then my gy48v gyro didn't hold (I have a spartan ds760 now). I have been practicing inverted hover on phoenix though, and progressing.
The main shaft will more often than not bend in a crash. Hope this helps. BD |
Hong Kong
Joined Jan 2010
If you can do a sustained inverted hover on a SIM, you can do it in real life. That is if you can get the heli into an inverted position safely in the first place. This is where real life really differs from the SIM. The gyro may not hold as well in real life, the flip rate, power, and pitch settings may be different. Also you have the influence of the wind. Therefore transitions to inverted, whether through a front, back or side flip often looks very haphazard compared to a SIM. It took me hundreds of transitions in all directions to do it safely in real life.
A SIM can really get you so far. I really would recommend a submicro CP to bash around. The Blade Nano CPX is the heli at the moment, being very 3D capable indoors and outdoors. The Walkera MIni CP is more stable and suitable for beginners. I don't recommend the mCPX or the Genius CP because their stock motors are weak and that cause problems for beginners. |
| Thread Tools | |
| Discussion Went to my local shop today... | RJP3579 | Beginner Training Area (Heli-Electric) | 9 | Apr 14, 2012 03:44 AM |
| Discussion Crashed the plane. What went wrong?! | kenzietech | Beginner Training Area (Aircraft-Electric) | 19 | Apr 04, 2012 02:11 PM |
| Discussion "Ultrafly Cessna" went one way and wing went the other | 2MuchAir | Electric Plane Talk | 10 | Apr 15, 2006 12:58 AM |
