Old Oct 21, 2012, 07:46 PM
Yeaman is offline
Find More Posts by Yeaman
Not watchin from the sideline
Yeaman's Avatar
United States, OH
Joined Nov 2011
Originally Posted by Knoll53 View Post
Here's a CG check at 2 different wing sweep configurations. Quick work in Rhino 3D.
Version 2 will have a shorter nose and a longer tail, which looks better at the moment.
Wow. Thats one crazy looking wing, making it perform well will be interesting.
Yeaman is offline Find More Posts by Yeaman
Old Oct 22, 2012, 06:31 AM
Edwinzea is offline
Find More Posts by Edwinzea
the answer 42 is
Switzerland, AG, Lenzburg
Joined Jan 2006
Kent that is ZetZyyyy
EZ
Edwinzea is offline Find More Posts by Edwinzea
Old Oct 23, 2012, 04:17 AM
Edwinzea is offline
the answer 42 is
Joined Jan 2006
BTW do not be afraid to the pointy tips http://static.rcgroups.net/forums/at...4-DSCF3297.jpg
Mine flew quiet well until I manage to land it on a pole :P
EZ
Old Dec 12, 2012, 10:58 PM
Joel K. Scholz is offline
Find More Posts by Joel K. Scholz
Joel K. Scholz's Avatar
Kingsland, Texas USA
Joined Aug 2000
I recently built a Kestrel that had slightly forward sweep. The main problem I ran into was balance. It required more lead than I wanted to use. I finally cut the wing in half and added rear sweep to allow the cg to be moved back. I can forsee this model possibly running into the same difficulty.
Joel K. Scholz is offline Find More Posts by Joel K. Scholz
Old Dec 12, 2012, 11:04 PM
Joined Aug 2000
A few photos
Old Dec 13, 2012, 10:06 AM
Knoll53 is offline
Find More Posts by Knoll53
less is more
Knoll53's Avatar
United States, CA, Marina
Joined Sep 2006
That is one big ass Kestrel ! Nice work Joel. Do you have a build log or video of this bird???
Having weight in the nose is not a problem for me, but I DID modify the sweep in post #41 to reduce the nose lead. I find slightly higher wing loadings (15 oz/s.f.) to be beneficial. When the wind comes up, you want to be able to penetrate. I can easily thermal my Plank 101 at 17 oz/s.f.
Kent
Knoll53 is offline Find More Posts by Knoll53
Old Dec 13, 2012, 12:21 PM
Joined Aug 2000
Here is the build:http://www.rcgroups.com/forums/showthread.php?t=1727632
Old Dec 13, 2012, 07:17 PM
sloper10 is offline
Find More Posts by sloper10
United States, TN, Nashville
Joined Oct 2012
I really enjoy this forum but sometimes you cause my head to hurt....keep up the good work...
sloper10 is offline Find More Posts by sloper10
Old Dec 31, 2012, 08:43 AM
xlcrlee is offline
Find More Posts by xlcrlee
Joined Apr 2006
pteroflügel
Nice design!
Try the following, the result of mucho real-world testing: you'll like it ....
Lee
xlcrlee is offline Find More Posts by xlcrlee
Old Dec 25, 2013, 09:10 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
I'll probably keep tweaking this and that for another 445 days, but a potentially pitch neutral flap next to the inboard elevon, might prove useful.
Crow is available for landings and a rudder effect should be possible to help with turns. This one is intended to be a floater.
Kent
Old Feb 06, 2014, 09:47 PM
guitarcher is offline
Find More Posts by guitarcher
Living on the Dark Side.
guitarcher's Avatar
Australia, QLD, Maryborough
Joined Jan 2013
http://thermik-board.de/viewtopic.php?f=27&t=1259
Have you seen this one Kent?
guitarcher is offline Find More Posts by guitarcher
Old Feb 07, 2014, 11:27 AM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Cool ! Thanks for the link. No I hadn't seen it. What a great design and execution. Those tail feathers look quite delicate. I see that his control system is similar to mine......that's encouraging.
The head and neck design is brilliant. It must be quite a sight in the air. Couldn't find video of it though. I see that the Alula has morphed into a motor.
Kent
Old Feb 07, 2014, 11:44 AM
HerkS is offline
Find More Posts by HerkS
Herk
HerkS's Avatar
Virginia USA
Joined Jun 2007
Looks like this guy has built several - very similar
https://www.youtube.com/user/rmarston/videos
HerkS is offline Find More Posts by HerkS
Old Feb 07, 2014, 01:00 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Thanks Herk. Looks like those tail feathers are strong enough!
Kent
Old Feb 22, 2015, 04:00 PM
Knoll53 is offline
less is more
Knoll53's Avatar
Joined Sep 2006
Since this is primarily a plank, there will be no pitch neutral flaps............don't know what I was thinking. Crow will be possible
The extended elevon is looking attractive now. Control inputs for a tight turn should provide for significant washout, hopefully reducing tip stall.
Also thinking of some dihedral, maybe 3 degrees.
Discussion [Winged Planet] Stunning bird and from-bird video footage ! [BBC] alainphoto Aerial Photography 3 Oct 21, 2012 01:12 AM
Help! Building curvy fuselages? adamtc Vintage & Old-Timer Designs 48 Feb 26, 2008 05:03 PM
Sold 15-turn 24-gauge 22.7mm CDROM w/Curvies $15 Shipped timocharis Aircraft - Electric - Power Systems (FS/W) 2 Feb 28, 2007 10:55 PM
Discussion Curvy Covering Monokote vdubin64 Fuel Plane Talk 5 Dec 18, 2006 03:04 AM
Question Curvy surfaces, and blended systems. Wing Zero Modeling Science 6 Dec 26, 2005 03:34 PM
