Old Feb 25, 2013, 06:18 PM
steve9996 is offline
Find More Posts by steve9996
Joined Dec 2012
My maiden flight plus 1 day! A bit breezy but couldn't wait any longer!
Vulcan Y6 UAV Maiden Flight (2 min 59 sec)
steve9996 is offline Find More Posts by steve9996
Old Feb 26, 2013, 03:31 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
That's a big old beast! Well done on the maiden. GPS is under the dome?
Bill Glover is offline Find More Posts by Bill Glover
Old Feb 26, 2013, 04:37 AM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
Steve....I really like where you positioned your gopro. Makes it a lot easier to see where you are flying when using it for FPV
The Vulcan Y6 and together with the YS-X6 make a good team. Not flying mine at the moment as my YS-X6 is in China getting upgraded to the -P version
Rob
robone is offline Find More Posts by robone
Old Feb 26, 2013, 04:46 AM
Joined Nov 2000
Keeps the GoPro a good distance from the GPS too - can interfere otherwise.
Old Feb 26, 2013, 10:06 AM
Joined Dec 2012
Bill, it is a big beast that's for sure! Yours and mine are complete opposite ends of the spectrum! I am going to convert to X8 just for the redundancy. I'm also going to upgrade the PDB when I do that. I'm waiting for Alex for his new ones to arrive. I'm also going to do your hole through the boom trick and shorten the booms a tad. Yes the GPS is under the dome.
@robone Mmmm I just plonked the GP there for the purposes of showing the y6 and the maiden flight. I thought the vibration were really low considering the GP is quite high and adhered with DS foam tape. It is that 3M super strong sticky stuff. Maybe I should have thought twice before I stuck it there a bit close to a prop!
Old Feb 26, 2013, 11:20 AM
Joined Nov 2000
If you've got enough spare thrust a Y6 should fly OK on 5 motors. Probably wouldn't do the GoPro much good though
Old Feb 26, 2013, 12:30 PM
Joined Dec 2012
Really, even when loaded? I am looking to put a 3 axis CS gimbal underneath with a Dslr.
Old Feb 26, 2013, 12:34 PM
topgearuk is offline
Find More Posts by topgearuk
topgearuk's Avatar
United Kingdom, London
Joined Dec 2003
Rob
I had to double check then, I thought I was following the XAircraft thread all over again, when reading this!! Lol
Hope you've been doing plenty of flying??
topgearuk is offline Find More Posts by topgearuk
Old Feb 26, 2013, 02:02 PM
robone is offline
Joined Sep 2010
Do they still exist Actually it does have a familiar sound to it.
Old Feb 27, 2013, 06:12 AM
Joined Nov 2000
I think it depends on the AUW and how much thrust you have available. If I feel brave enough I may try unplugging a motor lead on mine next time I'm at the field!
Old Mar 02, 2013, 07:51 AM
Paul@SCC is offline
Find More Posts by Paul@SCC
Chalfont St Giles, Bucks, UK
Joined Jan 2007
http://player.vimeo.com/video/60470054
Hi Steve. Good to see your maiden went well.
Paul@SCC is offline Find More Posts by Paul@SCC
Old Mar 02, 2013, 12:07 PM
Joined Dec 2012
Thanks Paul. Can I ask how did you do your power distribution? You did a wiring harness but I am unsure how to size the cables.
Old Mar 02, 2013, 02:01 PM
Joined Nov 2000
I'm using a low-powered vtx and wanted a location for it where the signal wasn't potentially going to be blocked by booms/legs/centre plates. Couldn't find anywhere on the frame I was happy with, so today I added a simple CF rod mount ... secured by a collet glued to the top plate:
Old Mar 03, 2013, 03:07 AM
Paul@SCC is offline
Joined Jan 2007
Hi Steve. I'm not sure of the exact AWG. I would say they are the same as the wires that come out of the 40a plush esc's
I see a couple of vids on your Vimeo channel that were made in Slough. Are you in the Bucks/Berks area. ?
Cheers
Paul
Old Mar 03, 2013, 05:52 AM
Joined Nov 2000
Got some 8000 mAh packs for my Y6 last week - 28% left after 10 mins in the air, which I'm very happy with. The gains are pretty much sorted now, generally I'm very pleased with it. Touching the camera while it's hovering I can feel no vibration whatsoever. The frame itself is very good, and the gimbal is filtering out anything that's left
Discussion Vulcan multiframe skyhook series Andre6553 Scratchbuilt Multirotors 4 Oct 09, 2012 11:38 PM
Discussion VULCAN Multiframe SkyHook Octo 1200mm tormodnt Multirotor Talk 14 Oct 06, 2012 06:21 AM
Build Log 80" WS Depron Vulcan B2 Electriflier Foamies (Scratchbuilt) 8 Jun 10, 2012 01:48 PM
