Old Oct 09, 2012, 04:20 PM
Paul@SCC is offline
Find More Posts by Paul@SCC
Chalfont St Giles, Bucks, UK
Joined Jan 2007
Vulcan multiframe 1200mm Octo.
A big thumbs up to Alex at UAVshop.co.uk
Hit the buy now on Saturday eve, shipped Monday and received before 1pm today. Great service.
On opening the box everything was packed very well. The arms have a nice finish and the carbon plates are thick, strong and shiny.
I must say I am over the moon with the quality of this bit of kit.
Although this kit is the 1200 octo with long legs, it can be anything I want. Quad, hexa or Tri.
I bought the 1200 octo for a heavy lift project, but if that does not work out I will probably cut it down to a 800/900 hexa. This is made easy by having the arms pre drilled.
It really is a very versatile multicopter kit.
A few pics straight out of the box.
Edit:
The kit comes with only two of the smaller discs in the pic below. The other two were put in by mistake.
Center plates are drilled for all configurations.
I don't have motors and esc's yet, but I will start to put it together this week and report back.
Cheers
Paul
Stabilised gimbal project.
Bench test with tilt.
My Project 4 (1 min 8 sec)
Roll test.
Roll Stabilisation (0 min 48 sec)
1st flight test with roll only.
My Project 8 (1 min 3 sec)
More on board testing with roll.
My Project 9 (2 min 16 sec)
We have now put together a gimbal which has roll and tilt. Pan is coming.
My Project 11 (1 min 56 sec)
Roll and tilt test.
trim.eSQSis (1 min 40 sec)
Roll and tilt in the air.
trim.BMtXfV (1 min 35 sec)
Pan test.
Pan axis. (0 min 56 sec)
Paul@SCC is offline Find More Posts by Paul@SCC
Old Oct 09, 2012, 07:29 PM
rukie is offline
Find More Posts by rukie
rukie's Avatar
Philippines, Central Luzon, Marilao
Joined Jun 2008
Wow nice... Looking forward to the build pics... What fc are you planning to use? Im planning a build in the not so far future and im considering this frame. Super heavylift and the anti vibration features are pretty attractive. Hope you can confirm it.
rukie is offline Find More Posts by rukie
Old Oct 09, 2012, 11:10 PM
Michael64 is offline
Find More Posts by Michael64
United States, TX, Thrall
Joined Feb 2010
Here is picture of my Vulcan I am flying. Its 880mm motor to motor. Running 13x6.5 props.
Michael64
Michael64 is offline Find More Posts by Michael64
Old Oct 09, 2012, 11:55 PM
rukie is offline
rukie's Avatar
Joined Jun 2008
@micheal how is it? Im really interested on how they manage to remove vibrations from the motor.
Old Oct 09, 2012, 11:57 PM
gitit20 is offline
Find More Posts by gitit20
gitit20's Avatar
Joined May 2012
WOW that's a nice frame how much did this set you back? big too
gitit20 is offline Find More Posts by gitit20
Old Oct 10, 2012, 12:53 AM
Andre6553 is offline
Find More Posts by Andre6553
Vulcan skyhook multirotor
Andre6553's Avatar
South Africa, GP, Pretoria
Joined Feb 2011
Hi i have started a thread for general discussions about these frames.
I also got one off these and buzy build a 1200mm vulcan hexa frame.
Here is the thread http://www.rcgroups.com/forums/showthread.php?t=1748778
Andre6553 is offline Find More Posts by Andre6553
Old Oct 10, 2012, 06:53 AM
Paul@SCC is offline
Joined Jan 2007
Hi. I will be using a DJI wkm
The octo kit costs 318. I tink they are available in the states, not sure of the cost.
Nice to see a thread started on the Vulcan airframes. I think these will become very popular in time.
Old Oct 10, 2012, 10:11 AM
robone is offline
Find More Posts by robone
South Africa, GP, Johannesburg
Joined Sep 2010
Michael64
That's a nice looking Hexa. I built myself a 650 Hexa to carry my YS-X6. Using MT2814-11 motors and 11x4.7 props.
Flies well. Must start taking some more pics and some videos. The thing I like about these frames is you can attach so many items on the arms, easily.
robone is offline Find More Posts by robone
Old Oct 10, 2012, 03:30 PM
Andre6553's Avatar
Joined Feb 2011
Rob why did you choose the + config and not the x any reason why?
Old Oct 10, 2012, 04:51 PM
Paul@SCC is offline
Joined Jan 2007
Hi guys.
Today I received 4 x 3515 400kv motors, which were kindly sent to me by FPVmodels for reviewing. I'm not going to be able to test them until I get my props which are out of stock at the moment.
For now I will just get them mounted on four arms and make the frame up as a quad. Not sure what the performance will be like with the low kv in this configuration. I may just go ahead and buy four more as the motors look and feel like good quality gear.
The T motor comes with four mounting screws, but they are not needed as the V frame comes with hex head screws. Edit: it has come to my attention that the screws in the pic do not come with the frame only kit. I believe they are supplied if you buy a kit that comes with motors.
I mounted the motor to the plate and then threaded the wires through the arm. I then put the 40mm bolts through the arm with two 10mm washers on top, 7mm washers on bottom then added the nylocks. Pliers and 2.5mm Allen key used.
All this info is available with better instructions on-line
Old Oct 11, 2012, 10:12 AM
robone is offline
Joined Sep 2010
Not really. I have my Gopro hard mounted below the battery and either way, the landing gear or arms would not have got in the way. If I had been using anything larger than a 650, I would have gone the X route.
Plus, I only wanted to use 3 legs where as if I would have gone the X route, and if I had wanted some symmetry, I would have needed 4 legs.
Old Oct 11, 2012, 10:29 AM
UAV.Pilot is offline
Find More Posts by UAV.Pilot
Joined Sep 2012
Sweet Kit...
Subscribed
UAV.Pilot is offline Find More Posts by UAV.Pilot
Old Oct 11, 2012, 10:32 AM
dtm360 is online now
Find More Posts by dtm360
Hong Kong
Joined Sep 2004
Very nice looking frame, not bad price neither! Looking forward to seeing some more detailed pics.
BTW, how thick are those main frame carbon plates?
dtm360 is online now Find More Posts by dtm360
Old Oct 11, 2012, 12:40 PM
Paul@SCC is offline
Joined Jan 2007
Originally Posted by UAV.Pilot View Post
Sweet Kit...
Subscribed
Hi UAV
It is a sweet kit. Just hope it performs well in the air, from the vids I have seen, it seems to be OK.
Hi dtm.
The motor plates are 3 mm
The main frame plates are 2mm
The arms are. Depth 30mm. Width 15mm. Length 498mm
That gives 116cm at motor centres.
Cheers
Paul
Old Oct 11, 2012, 03:10 PM
Paul@SCC is offline
Joined Jan 2007
Had a couple of hours free today so decided to put the frame together. Everything fitted well. The build of the frame is very easy. I should of taken pics when building but I was having too much fun.
Following the online manual makes it very clear on what pre drilled holes to use.
You get four landing legs in the kit. I have opted for the I octo config which means you put a landing leg either side of the forward arm and one on the rear arm.
If you go for a V octo config you will end up using four legs, but with a wider field of view between the landing gear. I may opt for that style.
For a fixed style landing gear I do find them very adaptable.
This thing is huge
The arms have pre drilled holes along the length of the arm. So you can attach the legs where you like, as long as you do not run out of holes.
The four pillars are screwed to the plate before you attach arms. Top plate has 30mm pillars made from aluminium. Bottom plate has 10mm pillars made from plastic.
Cheers
Paul
Discussion Vulcan multiframe skyhook series Andre6553 Scratchbuilt Multirotors 4 Oct 10, 2012 12:38 AM
Discussion VULCAN Multiframe SkyHook Octo 1200mm tormodnt Multirotor Talk 14 Oct 06, 2012 07:21 AM
Build Log 80" WS Depron Vulcan B2 Electriflier Foamies (Scratchbuilt) 8 Jun 10, 2012 02:48 PM
