Old Oct 09, 2012, 02:43 PM
itsme2 is offline
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
Hobby King Props - Any Good?
Are Hobby King Props any good or is it better to stick with APC? If I decide to order from HK which one of their brands is best?
Thank you!
itsme2 is offline Find More Posts by itsme2
Old Oct 09, 2012, 03:29 PM
Seamus O'Leprosy is offline
Find More Posts by Seamus O'Leprosy
Seamus O'Leprosy's Avatar
Ireland, County Meath, Meath
Joined Oct 2008
I have used the HK APC (style) props before and can can that the are very similar to the APC
props. Balance is also usually spot on.
Its the cheap shipping from HK that usually keeps me shopping there.
Seamus O'Leprosy is offline Find More Posts by Seamus O'Leprosy
Old Oct 09, 2012, 08:47 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Nothing Magic OR outstanding about APC props in my experiences.
Except High price and breakage every time they touch grass.
HK "copies' are Fine and actually a bit Less! brittle.
Great choice If they make the size you need :-)
Bare is offline Find More Posts by Bare
Old Oct 09, 2012, 08:57 PM
flashburn is offline
Find More Posts by flashburn
Joined Sep 2008
I use the light electric wood series 11" and up for 3D
the APC style 11" to 13". Above 13" on 3D setups they cavitate when you punch the throttle just like real APC props do
and the slow fly props on foam ships both outdoor and indoor
All work plus cost much less than name brand props.
Balance is average some are almost perfect some need work, molding flash on the APC style tends to be a bit heavy so expect to do a bit more clean up there.
The slow fly props are a great buy @ under $3.00 for five.
Hub holes on all but the slow fly props are small so order drills or the proper size reamer.
flashburn is offline Find More Posts by flashburn
Old Oct 10, 2012, 07:03 AM
flypaper 2 is offline
Find More Posts by flypaper 2
I use foam to hold my hotglue
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
I use the GWS props from HK. They come at about $5.00 for 6 props. The local HS wants $3.00 ea. for the same GWS props.
Gord.
flypaper 2 is offline Find More Posts by flypaper 2
Old Oct 10, 2012, 11:11 AM
Zebi2 is offline
Find More Posts by Zebi2
Finland
Joined Jun 2012
I have HK's SF 10x3.8 props and they aren't in balance. They're useless if you don't have prop balancing tool.
On the other hand they are very cheap.
Does anyone know are those HK's APC-e props usually balanced or unbalanced?
Zebi2 is offline Find More Posts by Zebi2
Discussion Hobby King mini J3 Cub - Any Good? rcmaverick Electric Plane Talk 2 Apr 15, 2012 07:00 AM
Discussion HK EDF64 Brushless Power System 3500kv & 45A ESC from Hobby King. Any Good? jimm1962 Electric Ducted Fan Jet Talk 5 Oct 15, 2010 04:02 AM
Discussion Hobby King 70 mm fan, any good? jimm1962 Electric Ducted Fan Jet Talk 1 Jun 15, 2010 09:49 PM
Discussion Hobby King 2.4ghz set - any good? Leni Pocky Radios 5 Mar 04, 2010 04:13 PM
Discussion CA glue from Hobby King - any good? AvB Sailplane Talk 1 Jan 20, 2009 10:29 AM
