Old Oct 09, 2012, 02:01 PM
jodymichael is offline
Find More Posts by jodymichael
Joined Sep 2012
Duraplane Missing Aluminum channel Help
I'm not sure this is the right forum.. bur here goes.. I just Received a DuraPlane 40 kit from a forum member that Is missing the Aluminum channel ... Does any one know its dimensions? gauge and where the holes are drilled.. any help would be greatly appreciated...
THANKS.. Mike
jodymichael is offline Find More Posts by jodymichael
Old Oct 09, 2012, 04:39 PM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Welcome to RCG
i'm looking at the instruction manuals (dura1111, dura1130, dura1140) for clues about the channel.
Appears that the inside measurements are 3/4" wide, 1/2 inches deep, and mounts open side up.
looking for more info
Head to tail length is 44 inches
rick.benjamin is offline Find More Posts by rick.benjamin
Old Oct 09, 2012, 04:48 PM
Reduce the drama...
USA, OR, Damascus
Joined Apr 2004
Found a shop that still has an accessory kit
http://www.flyhobbies.com/duraplanefuselage40.htm
Old Oct 09, 2012, 07:33 PM
Joined Sep 2012
Thanks for the replies.. Yes I can guess at the dimensions,, But I really wanted someone that has one measure it... and on the website they really don't have them.. it will not let you check out .. Thanks....
Still Looking.. Mike
Old Oct 10, 2012, 05:14 PM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
rick. dimensions are correct , and overall length on mine is 31"
Outside width is .9"
Height is .566"
wall thickness is .65-.68"
Now for the holes starting at one end with the 2 smaller holes. All 4 of them are in the bottom centered. The 2 small ones are close to an end.
1/8" hole .61" from an end
1/8" hole 5.11" from same end
From the opposite end
.17" hole that is 4.85"
.17 hole that is 12.16" from same end
That means the two center holes (one large and one small) are about 13-7/8 " apart.
gulio is offline Find More Posts by gulio
Old Oct 11, 2012, 07:58 AM
Hemikiller is offline
Find More Posts by Hemikiller
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
...and make sure you use a stout engine on this bird. I'd recommend a ball bearing 46 like the TT46Pro, OS 46AX or similar. A bushing 40 (40LA) will fly it, but it's nothing spectacular.
FWIW, the Duraplane is not a good trainer per-se, but is the best plane to teach yourself on. I beat the living be-geezus out of mine and it still flew as well as a Duraplane flies. Gave it to a fellow member and he trained his wife on it.
Hemikiller is offline Find More Posts by Hemikiller
Old Oct 11, 2012, 10:19 AM
Joined Sep 2012
Thanks Gulio... just what I needed... on how it flys .. i used to fly one years ago.. it was kinda hard to keep up with.. but I am going to try to lighten it up a bit by using coroplast in the wing and tail feathers I have built some S.P.A.D's in the past..and enlarging the flying surfaces .and cut holes in the fuse to lighten it up somewhat... to have better wing loading...its just nostalgia
Thanks Mike
Old Oct 11, 2012, 01:08 PM
Joined Sep 2012
Gulio... went out and bought the aluminum channel.. but one more thing before I cut this up.. the 44" of the fuse length .. how is that measured? i measured from where the engine mount meets with the PVC fuse.. if measured out as above it measured out at around 37 " to the end of the channel at the tail..is this correct... is your DuraPlane the trainer 40? with the the ailerons... thanks .. mike
Old Oct 11, 2012, 04:41 PM
gulio is offline
That's a funny word
NE Ohio
Joined Apr 2003
No idea how it is measured. Mine is the trainer 40 and the manual does talk about building the wooden ailerons and requiring a 4 channel radio. So mine does have ailerons , but it is still in the box and has a wing corner broken off. I think it's new old stock and I got it cheap. It may be missing other items, you want the whole kit? cheap.
Old Oct 11, 2012, 06:36 PM
Joined Sep 2012
Depends
Whats Cheap?
PM me
Discussion Missing two fan unit aluminum collar from two Concept X kits wsame Nitro Planes 5 Mar 20, 2012 03:41 PM
Wanted Duraplane Kit FlyingKiwi22 Aircraft - Electric - Airplanes (FS/W) 2 Mar 09, 2012 08:14 PM
Discussion 2801 pro missing channel? pistolsnipe Radios 8 Mar 03, 2012 02:43 AM
Discussion 2801 pro missing channel? pistolsnipe Simulators 8 Mar 02, 2012 08:26 AM
Duraplane 40 wing on a Duraplane 20 Model? kctrading SPAD - Simple Plastic Airplane Designs 0 Mar 28, 2005 09:03 PM
