Old Oct 09, 2012, 01:52 PM
flyinhigh025 is offline
Find More Posts by flyinhigh025
How can we stop winter?
flyinhigh025's Avatar
Frederick, CO
Joined Sep 2005
Extreme Flight 48" Vanquish Set-Up Help.
Hi All!
I just ordered a new Extreme Flight 48" Vanquish. I have been flying giant scale IMAC off and on over the last few years and decided I wanted to "dabble" a little into pattern flying. With the cold Colorado winter rapidly coming in I thought it would be fun to have a little pattern ship that can quickly go with me to the park or local club for some precision flying. If I in fact like the pattern flying I might just get a 2M version in the spring.
I have a couple quick questions, if anyone would like to throw in a few suggestions I would appreciate it.
1) ESC Braking. (I'm running the Castle ICE Lite 50) Should I use soft, hard, or other braking for best results?
2) Can I get better down-line braking from a larger propeller, 13" vs 12"?
I'm all ears to any other suggestions, thanks!
My Vanquish set-up:
1) Castle ICE 50 Lite
2) Futaba R6106 HFC High Speed RX
3) Futaba S3156 Digital Servos
4) 4S 35C 2600Mah packs
5) Motrofly 2820-750/13x6.5 APCe -or- EF 28141-820/12x6 APCe
-Jeff
flyinhigh025 is offline Find More Posts by flyinhigh025
Old Oct 10, 2012, 08:26 AM
RCBRUSKI65 is offline
Find More Posts by RCBRUSKI65
United States, MI, Saginaw Charter Township
Joined Feb 2007
Try 30% braking, sometimes if you go more you might get an engine squeal. I fly mine with a 13x6.5 and get pretty good braking. You may even try a 13x7 Xoar.
RCBRUSKI65 is offline Find More Posts by RCBRUSKI65
Old Oct 10, 2012, 08:44 AM
Frederick, CO
Joined Sep 2005
Thanks for the input I appreciate it. I will give it a go.
Old Oct 10, 2012, 07:05 PM
Anthonyr is offline
Find More Posts by Anthonyr
United States, NY, Ossining
Joined Aug 2003
I have the same plane but slightly different set up. Similar batteries with an 800kv Fury, 12*8 prop and an older CC Phoenix 45. It is set for immediate brake with no delay. Thanks to the programming card I was able to get to 60% brake. Unfortunately, it does require some trial and error but is worth the time.
A higher diameter low pitch prop will give the best brakes but you will want at least 6" of pitch. I enjoyed the 13*6.5 on a lower voltage set up but too much power is usually just enough!
Check NSRCA.us for sequences and pattern pilots in your district.
Good luck!
Anthonyr is offline Find More Posts by Anthonyr
Old Oct 11, 2012, 08:46 AM
Frederick, CO
Joined Sep 2005
Thanks for the helpful input! I'm looking forward to working on a sequence or two.
Article Extreme Flight 48" Vanquish Review matchlessaero 3D Flying 71 Jan 03, 2016 08:39 PM
Discussion Extreme Flight Vanquish MK II - 48" version - A couple of questions viva_peru F3A Pattern 8 Oct 06, 2012 05:41 PM
For Sale 48" Extreme Flight Vanquish Vref Aircraft - Electric - Airplanes (FS/W) 4 May 09, 2012 09:24 AM
For Sale Extreme Flight 48" Edge Wing Set, Canopy & Cowl $65 Shipped Conus bcucoach2 Aircraft - Electric - Airplanes (FS/W) 1 Mar 06, 2012 08:32 AM
Wanted Extreme flight Vanquish 48" Aero12 Aircraft - Electric - Airplanes (FS/W) 2 Mar 13, 2010 10:32 AM
