Old Oct 09, 2012, 12:22 PM
racer1 is offline
Find More Posts by racer1
5kW Club
racer1's Avatar
United States, AZ, Tucson
Joined Feb 2007
Help!
BVM F-16 Retract Set
I am looking for a BVM F-16 Nose gear assembly with the retract. This retract lays flat when retracted.
I am guessing a Yellow Aircraft or Jet Legend would work also. If need be I can get the whole set if somebody has them.
I am open to any suggestions.
Thanks Clay
racer1 is offline Find More Posts by racer1
Old Oct 09, 2012, 12:46 PM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
Did you call BVM? The Sabre twist and turn unit should be the same, either the mechanical unit or the newer Air Blue type.
Chris True is offline Find More Posts by Chris True
Old Oct 09, 2012, 12:47 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
http://shopbvmjets.com/zencart/index...roducts_id=215
Full page-
http://shopbvmjets.com/zencart/index...ex&cPath=52_51
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Oct 09, 2012, 01:26 PM
Gibb is offline
Find More Posts by Gibb
Livonia, Mi
Joined May 2010
The old BVM mechanical gear is the only one that fits in this plane. The air blue front retract does not fit sine the air cycliner sits too tall and will hit the intake.
Gibb is offline Find More Posts by Gibb
Old Oct 09, 2012, 01:41 PM
racer1 is offline
5kW Club
racer1's Avatar
Joined Feb 2007
That is correct there is not a lot of room in front for the gear. It really was not mechanical it is air driven.
Old Oct 09, 2012, 02:02 PM
Gibb is offline
Livonia, Mi
Joined May 2010
Sorry, yes, the air cylinder sits rear of the retract and uses a long pushrod to engage the retract arm. I hate to say it....this is the biggest problem with the two F16s that i have built. Almost seems like it would be better to form an intake with a hump ala the YAC and use the air blue gear.
Jim
Old Oct 09, 2012, 02:04 PM
Joined Dec 1996
Then get the mechanical twist-n-turn nose + a 3/4" diameter cylinder.
You remote mount the cyclynder further back where there is room and link it to the mechanical nose with a 3/16" diameter soft brass tube soldered to the end of the shaft on one side andgrind the head of a 4-40 socket head screw so it fits inside the brass tube, solder that in and screw on a clevis. All of BVM's gear was done this way before they came out with the dedicated airdriven units with the integrated cylinders. The cylinder mounts to the airframe with a metal bracket and clevis pin which you probably need seperately also.
Old Oct 09, 2012, 02:07 PM
Joined Dec 1996
Looks something like this, F-16 wil be a little different but not much
Old Oct 09, 2012, 02:11 PM
Joined Dec 1996
More of the retract in this view
Old Oct 09, 2012, 02:20 PM
racer1 is offline
5kW Club
racer1's Avatar
Joined Feb 2007
I will shoot a picture tonight.
I have seen this style of retract on a Yellow F-16 and a Jet legend F-16 also.
Old Oct 09, 2012, 02:29 PM
MaHö is offline
Find More Posts by MaHö
MaHö's Avatar
Germany, BW, Stuttgart
Joined Dec 2001
Hi!
You have to take this.
http://shopbvmjets.com/zencart/index...roducts_id=635
BUT with much mod on the steering you can also use the really scale YA F16 nose retract.
regards Martin
MaHö is offline Find More Posts by MaHö
Old Oct 09, 2012, 04:18 PM
SCALECRAFT is offline
Find More Posts by SCALECRAFT
Joined Apr 2004
Originally Posted by MaHö View Post
Hi!
regards Martin
The nose gear of the one you have pictured is the exact early BVM F-16 unit.
Steve
SCALECRAFT is offline Find More Posts by SCALECRAFT
Old Oct 09, 2012, 04:39 PM
Joined Apr 2004
A few pics of my BVM F-16 nose gear. I also have a Yel F-16. The Yel is a larger unit. This is why Yel needs the hump in the intake. Both very good designs for each models specific application.
The rotating plastic unit shown above will work. The pic of the one on the table is the original early BVM F-16 unit.
The strut on the my BVM F-16 is a Robart.
steve
Old Oct 09, 2012, 04:58 PM
RTaylor is offline
Find More Posts by RTaylor
Red Bluff CA
Joined Sep 2001
I have an early version of that retract for BVM F 16. I think the newer version had more metal. If you want a pic let me know.
Randall
RTaylor is offline Find More Posts by RTaylor
Old Oct 09, 2012, 07:47 PM
samdimaio is online now
Find More Posts by samdimaio
Joined Sep 2008
BVM F-16 nose gear
have new correct BVM F-16 retract unit, latest rev. with the metal rotating parts and used correct BVM nose gear strut (no wheel) $125.00 plus shipping
samdimaio is online now Find More Posts by samdimaio
For Sale BVM F-100/F-4 Nose Retract bvmflier Aircraft - Fuel - Jets (FS/W) 0 Jan 28, 2012 04:34 PM
Wanted WANTED A SET of E-Flite 120 retracts for a Byron F-16 mechengineer03 Aircraft - Electric - Jets (FS/W) 1 Nov 14, 2010 10:30 PM
Sold NIB BVM F-16 Fighting Falcon w/ Retracts Tempest Aircraft - Electric - Jets (FS/W) 5 Jan 08, 2007 11:27 PM
Help! BVM F-16 main landing gear retracts kats Fuel Jet Talk 1 Dec 02, 2006 02:03 AM
WTB: BVM F-16 Retractable Nose Gear gromitvt10 Aircraft - Fuel - Airplanes (FS/W) 0 Mar 18, 2004 01:27 PM
