Old Oct 09, 2012, 10:00 AM
floridabiker is offline
Find More Posts by floridabiker
Retired Flyer
United States, FL, Boynton Beach
Joined Nov 2011
Build Log
Building an H-Quad
Here is a H-Quad that I just finished for aerial photography. For testing purpose's I installed a free flight controller to check stability. Now that stability checks out, I will install a Naza controller. I have recently purchased the new Sony HDR-AS-10 action cam and it works flawlessly on this frame. There is no rolling shutter, jello effect or vibration at all.
Here are some photo's of completed frame, also the sony cam mounting.
Indoor first flight test can be seen on my youtube channel.
H-Quad Ver. 2 with Aluminum Arms (1 min 26 sec)
floridabiker is offline Find More Posts by floridabiker
Old Oct 09, 2012, 11:32 AM
magic_marty is offline
Find More Posts by magic_marty
<Marty>
United States, KY, Springfield
Joined Jul 2011
looks great....i am getting ready to build my first tri-copter and using 1100kv motors and the F30 HK esc's (waiting on shipping)....wondering what size props you are using cause i can't figure out the best size to use...
thanks...
magic_marty is offline Find More Posts by magic_marty
Old Oct 09, 2012, 11:35 AM
FlyingRodent is offline
Find More Posts by FlyingRodent
United States, OH, Columbus
Joined Jan 2011
http://www.youtube.com/watch?v=FolLfBmajUU&feature=plcp
Love these H frames. Easier to build than quads I am thinking.
Quick question. Why did you put a motor mount on the arms? I thought the arms were strong enough or..?
FlyingRodent is offline Find More Posts by FlyingRodent
Old Oct 09, 2012, 01:34 PM
Retired Flyer
Joined Nov 2011
I'm using 10 4.5 props, they give plenty of lift.
Old Oct 09, 2012, 01:41 PM
Retired Flyer
Joined Nov 2011
I used the motor mounts because I think it gives the motor a flatter area to bolt up to. The tubes being hollow I also cut short pieces of hardwood and press fit them between the 2 mounting bolts so the tube would not crush when tightened.
Old Oct 09, 2012, 01:57 PM
eyesonsky is offline
Find More Posts by eyesonsky
eyesonsky's Avatar
Switzerland
Joined Jul 2010
One more QuadH on the air
Nice one.
We are more to choose this form of quad like here http://www.rcgroups.com/forums/showthread.php?t=1727528
eyesonsky is offline Find More Posts by eyesonsky
Old Dec 03, 2012, 05:13 AM
Great_Dane is offline
Find More Posts by Great_Dane
Woof!
Denmark, Region Zealand, Roskilde
Joined Oct 2012
Overall a pretty nice work - thanks for sharing here.
I'm not entirely sure, but are you, kind of, enclosing the ESCs in packing foam, to stop them from rattling around ?
If so, I would maybe worry a bit about cooling - are they warm after tests/flights?
Great_Dane is offline Find More Posts by Great_Dane
Old Dec 03, 2012, 09:26 AM
Retired Flyer
Joined Nov 2011
No the ESC's are located on each end which is open to air flow, the foam starts past the front esc and stops just before the back one. The esc's are held in place with double sided tape, no problem with over heating.
Old Apr 16, 2013, 01:46 PM
The Flying Farmer is offline
Find More Posts by The Flying Farmer
^Its what I do^ - FPVholic
The Flying Farmer's Avatar
United States, NY, Walker Valley
Joined Nov 2007
Nice Hquad
I would still be concerned about overheating, even with the sides of the frame open. I like mine to be in the propwash on the top or side of the arms. Our escs were designed with air cooling in mind. Just keep an eye on them.
Looks like a real clean quad! Im building my third quad in a few minutes.
The Flying Farmer is offline Find More Posts by The Flying Farmer
Help! Is this an ESC / Motor issue? (First Quad build) TEDious Multirotor Talk 4 Mar 20, 2013 11:59 AM
Discussion Quad-quad copter manned flight controlled by an RC radio larryross Foamies (Scratchbuilt) 3 Apr 27, 2012 09:14 PM
Question Suggestions for an old timer build using an FS20 or 26. mrcosmo Vintage & Old-Timer Designs 31 Apr 14, 2012 08:45 AM
Discussion I'm building an new AP Quad with Askman mount midiman007 Multirotor Talk 20 Feb 29, 2012 11:12 PM
