Old Nov 16, 2012, 07:16 PM
Dialfonzo is online now
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Originally Posted by danger_mouse View Post
Eric, what sized board cam fits up front with the optional ccd mount plate?
If i remember right it's 34mm mounting max but have slot for smaller
Yoy have a size in particular?
Dialfonzo is online now Find More Posts by Dialfonzo
Old Nov 16, 2012, 07:25 PM
danger_mouse is online now
Find More Posts by danger_mouse
danger_mouse's Avatar
Australia, QLD, Gatton
Joined Jan 2007
It is the PZ0420 from Security2000. I have trimmed the outer part, so 32mm across.
danger_mouse is online now Find More Posts by danger_mouse
Old Nov 16, 2012, 08:11 PM
jsflyrv is offline
Find More Posts by jsflyrv
Team Armattan
USA, OR, Hillsboro
Joined Feb 2011
I have the C20's on my 200mm quadrixette nano. Around 4 to 1 thrust ratio with 5x3x3 props. ~335grams thrust per motor. Uses 100mah per minute in flight. Supposed to be good for up to around 550 grams thrust with 7 inch props.
They go well. Just make sure the grubscrew securing the shaft to the bell is threadlocked. Had one motor where the shaft slipped. Wouldn't hurt to disassemble and grind a flat on the shaft.
Cool. What flight controller you running? Was it easy to tune? I found with my little overpowered quad it was real fussy on the PID tuning.
On this one I am running a Crius Multiwii SE no problem tuning so far.
Dialfonzo Mini Spyder (5 min 26 sec)
jsflyrv is offline Find More Posts by jsflyrv
Old Nov 16, 2012, 08:49 PM
Joined Jan 2007
Nice. Angry little thing when you open it up..
What happened around the 7-8 second mark?
Old Nov 16, 2012, 08:51 PM
DoctorAudio is offline
Find More Posts by DoctorAudio
Some call me the other guy!
DoctorAudio's Avatar
Milwaukie , Oregon
Joined Feb 2003
hahahah, it is a beast!
DoctorAudio is offline Find More Posts by DoctorAudio
Old Nov 16, 2012, 09:14 PM
jsflyrv is offline
Team Armattan
USA, OR, Hillsboro
Joined Feb 2011
called clumsy thumbs as I explained on YT I am running at 40% expo and 80% D/R and it is still mighty responsive as soon as I get out to the open field I will let it fly.
An oh that is probably a little less than 3/4 open throttle. Do not want to put it through a neighbours window.
Old Nov 16, 2012, 09:35 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
[]http://www.securitycamera2000.com/CCTV/Camera/PZ0420-2-600TVL-board-camera.jpg[/IMG]
There are 4 slot in the corner.
Each have a maximum of 34mm and a minimum i will look tomorrow.
But i am sure it will fit. Unless i will make you a custom one..
Old Nov 17, 2012, 07:17 AM
NaterPin is offline
Find More Posts by NaterPin
Joined Dec 2009
I am thinking of trying 5.5x4.5 speed props. They will be easier to balance. and maybe more durable in crash......"not that I crash, I am perfect"
NaterPin is offline Find More Posts by NaterPin
Old Nov 17, 2012, 08:10 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
CCD - Plate
I have made some minor modifications to the plate this morning.
The hole in the middle was a bit too small for mine because i want it close to the plate and there is a plastic casing that is bigger than the lens.
Here are the dimensions
Old Nov 17, 2012, 12:13 PM
NaterPin is offline
Joined Dec 2009
Mine will be here in two days. I am ready!!!
Old Nov 17, 2012, 03:36 PM
Milwaukie , Oregon
Joined Feb 2003
danger_mouse: remember you don't have to screw it in!
I am just going to put some doublesided foam on the front side and then use two bubber bands around the mount.
Old Nov 17, 2012, 04:40 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Will cut and assemble to show tomorrow
Old Nov 18, 2012, 10:26 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
Old Nov 18, 2012, 05:24 PM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
On a spyder made of wrongly cut parts....
Old Nov 21, 2012, 02:55 PM
NaterPin is offline
Joined Dec 2009
It came today!
It is easy to put together. You can put it together with a 4 month old on your lap
Discussion DiaLFonZo-Copter Crazy2Fly Quadcopter 340mm Dialfonzo Multirotor Talk 87 Feb 07, 2016 06:41 AM
Build Log Unrealistic's HEXorcism 600 - Luis & DiaLFonZo-Copter unrealistic Multirotor Talk 47 Oct 23, 2012 04:09 AM
For Sale DiaLFonZo-Copter TrinityHEX - ReList Dialfonzo Aircraft - Electric - Multirotor (FS/W) 3 Apr 27, 2012 02:44 PM
For Sale DiaLFonZo-Copter TrinityHEX - USED Dialfonzo Aircraft - Electric - Multirotor (FS/W) 7 Apr 20, 2012 11:34 AM
