Old Nov 11, 2012, 07:38 PM
NaterPin is offline
Find More Posts by NaterPin
Joined Dec 2009
I am thinking about running the Lipo on top.
NaterPin is offline Find More Posts by NaterPin
Old Nov 13, 2012, 02:10 AM
jsflyrv is offline
Find More Posts by jsflyrv
Team Armattan
USA, OR, Hillsboro
Joined Feb 2011
Originally Posted by NaterPin View Post
On the very top plate, there is one standoff in the front and two in the back. What is the space between the back two?
Aprox 35 MM
jsflyrv is offline Find More Posts by jsflyrv
Old Nov 13, 2012, 07:46 AM
NaterPin is offline
Joined Dec 2009
That is great thank you jsflyrv
Old Nov 13, 2012, 07:49 AM
Dialfonzo is online now
Find More Posts by Dialfonzo
DiaLFonZo - UAV/Drone
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
If it's what you need...
Dialfonzo is online now Find More Posts by Dialfonzo
Old Nov 13, 2012, 08:04 AM
NaterPin is offline
Joined Dec 2009
Yep, thank you.
Old Nov 15, 2012, 10:07 PM
jsflyrv is offline
Team Armattan
USA, OR, Hillsboro
Joined Feb 2011
Hotrod MiniSpyder
I just finished my second Dialfonzo Mini Spyder, on this one I did a few minor mods such as installing AXN-2208-2150 motors and use 20AMP Hobby Wing ESC. To do this I had to modify the side arm braces to allow for the witdh of the ESC and put some spacers under the motor mounts to get the bells above the top of the arms. I also wanted to mount the battery between the top and bottom frame which is only 15MM. to do this I cut the top frame off at the battery mount area and raised it up to allow a battery of up to 25MM to fit this area.
Old Nov 15, 2012, 10:48 PM
NaterPin is offline
Joined Dec 2009
Cool,
But, I have not even got my first one yet. I am a little jealous.
I have these waiting for it. http://www.hobbyking.com/hobbyking/s...ner_Motor.html
But I might try these later:
http://www.hobbyking.com/hobbyking/s...er_2050kv.html
Old Nov 15, 2012, 11:24 PM
jsflyrv is offline
Team Armattan
USA, OR, Hillsboro
Joined Feb 2011
Cool,
I have these wait for it. http://www.hobbyking.com/hobbyking/s...ner_Motor.html
Nater, I got two of them because Eric does quality work, He cut the first one and was not happy with it so he cut me another one, I told him I would take the first one also, that is how I ended up with two. IMO these things are first class. I love flying them.
Old Nov 16, 2012, 12:43 AM
jsflyrv is offline
Team Armattan
USA, OR, Hillsboro
Joined Feb 2011
Dialfonzo MiniSpyder leagal for night flight:)
Night time Dialfonzo Mini Spyder (0 min 37 sec)
Old Nov 16, 2012, 05:47 AM
Dialfonzo's Avatar
Canada, QC
Joined Oct 2007
That' a hack..
Could you have mounted the arms plate upside down (mounting part on top) and mount the motor mount inside the frame ?
Old Nov 16, 2012, 06:26 AM
danger_mouse is offline
Find More Posts by danger_mouse
danger_mouse's Avatar
Australia, QLD, Gatton
Joined Jan 2007
LOL, 44gram motors in this thing. I bet she's a rocket. How is your CG with the battery hanging out the back?
danger_mouse is offline Find More Posts by danger_mouse
Old Nov 16, 2012, 12:52 PM
jsflyrv is offline
Team Armattan
USA, OR, Hillsboro
Joined Feb 2011
Originally Posted by Dialfonzo View Post
That' a hack..
No Hack, just the way i planned it. I eventually want to use clear plexi or similar spacer and drill a small hole and mount a LED LIGHT in the clear spacer which will light up the whole mount. Plus the frame mount holes will not fit this motor mount base.
I love these minis I hope you sell a lot of them Eric.
Old Nov 16, 2012, 12:56 PM
jsflyrv is offline
Team Armattan
USA, OR, Hillsboro
Joined Feb 2011
On this Mini I cant tell the difference between battery mounted on the bottom center from where it is at now in flight. The CG moved back maybe 20mm from center of the FC board
Old Nov 16, 2012, 05:35 PM
Joined Jan 2007
I have the C20's on my 200mm quadrixette nano. Around 4 to 1 thrust ratio with 5x3x3 props. ~335grams thrust per motor. Uses 100mah per minute in flight. Supposed to be good for up to around 550 grams thrust with 7 inch props.
They go well. Just make sure the grubscrew securing the shaft to the bell is threadlocked. Had one motor where the shaft slipped. Wouldn't hurt to disassemble and grind a flat on the shaft.
Cool. What flight controller you running? Was it easy to tune? I found with my little overpowered quad it was real fussy on the PID tuning.
Old Nov 16, 2012, 06:51 PM
Joined Jan 2007
Eric, what sized board cam fits up front with the optional ccd mount plate?
Discussion DiaLFonZo-Copter Crazy2Fly Quadcopter 340mm Dialfonzo Multirotor Talk 87 Feb 07, 2016 06:41 AM
Build Log Unrealistic's HEXorcism 600 - Luis & DiaLFonZo-Copter unrealistic Multirotor Talk 47 Oct 23, 2012 04:09 AM
For Sale DiaLFonZo-Copter TrinityHEX - ReList Dialfonzo Aircraft - Electric - Multirotor (FS/W) 3 Apr 27, 2012 02:44 PM
For Sale DiaLFonZo-Copter TrinityHEX - USED Dialfonzo Aircraft - Electric - Multirotor (FS/W) 7 Apr 20, 2012 11:34 AM
