Old Oct 09, 2012, 06:50 AM
Trellian is offline
Find More Posts by Trellian
Joined Sep 2011
CC BEC Pro - Incorrect Output Voltage?
I recently bought a CC BEC Pro, and after a few flights with unexplained loss of control (leading to crashes), I did some more investigation.
It turns out that the BEC is actually only putting out 4.3V (with no load!), not the 5.1V that is set to.
So what was happening is that the receiver and mixers were browning out and rebooting.
I experimented a bit, and no matter what voltage I program for, the output voltage is exactly 0.8V less than that, basically from no load to 4 standard servos. I'm running from a 4s 5300mAH pack,
Yes, I have used three different multimeters, because I didn't believe the first one.
Has anyone else seen this? Can someone measure the actual output on their own unit?
The problem is, if I set the output voltage to say 6.3V to compensate, what guarantee do I have that one day the BEC will not suddenly decide to get the voltage right, and fry whatever equipment it is connected to?
Trellian is offline Find More Posts by Trellian
Old Oct 09, 2012, 07:41 AM
Clintstone is online now
Find More Posts by Clintstone
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
You need to contact the repair department @ Castle...
The output control is sort of done in banks... if you are having trouble with the 5.1 output it will be messed up in the entire range...
I never trust any bec voltage until I hook up a meter and test the voltage myself... yes I know you should not have to do this but I test voltage before I ever hook up to my electronics... I do the same thing with all regulators and Becs.
Contact the repair Department and they can get you squared away.
Repairs repairs@castlecreations.com
Phone
(913) 390-6939
*Option 1 - Technical Support
*Option 2 - Repairs
*Option 3 - Sales / Orders
Office Hours: Monday - Friday from 9AM to 5PM CST.
Clintstone is online now Find More Posts by Clintstone
Old Oct 09, 2012, 08:29 AM
Trellian is offline
Joined Sep 2011
Thanks! I will do that asap. The fast response is much appreciated!
Old Oct 09, 2012, 10:17 AM
Trellian is offline
Joined Sep 2011
I just called CC, and spoke with Dan. They sound really organised and capable, and have the ability to hook up a unit right there while you are on the phone.
Great service, thank you Dan!
Old Oct 09, 2012, 10:49 AM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
Awesome... Our Team In KS are great !!!
Sold SOLD CC BEC Pro 20 Amp BEC 6-12s jcaywood Aircraft - Electric - Power Systems (FS/W) 0 Sep 23, 2012 01:01 PM
Discussion What is the Minimum Input Voltage for a CC BEC Pro? Alan Hahn Castle Creations 2 Mar 22, 2012 02:41 PM
Discussion elogger no voltageS output to BEC/Engine See Eagle Tree Systems 1 Mar 04, 2012 05:04 AM
Discussion CC BEC Pro Default Output Voltage norstaroption Electric Heli Talk 1 Oct 25, 2010 06:55 PM
Discussion CC BEC Output Voltage icrashrc Castle Creations 8 Aug 03, 2008 10:45 PM
