Old Oct 08, 2012, 11:11 PM
daalma is offline
Find More Posts by daalma
Joined Oct 2012
pz p47
first of im a major rookie. can anyone tell me what would it take to put a turnigy g15 810kv in my pz p47. i have the motor and a plush 60 amp esc already. i have flaps and retracts so a bit of extra weight, thanks
daalma is offline Find More Posts by daalma
Old Oct 08, 2012, 11:31 PM
erikc641 is offline
Find More Posts by erikc641
United States, NM, Las Cruces
Joined Jul 2012
First off I will tell you that the stock motor is a 15 size 950 kv motor so the one you are talking about will struggle unless you do strictly 4 cell. I found the stock setup to be sluggish. I recommend the power 25 1250 motor and the 60A speed control and the xtra 300 10.5x9 prop. Tell us a little more about the rest of your setup (prop, battery)
erikc641 is offline Find More Posts by erikc641
Old Oct 08, 2012, 11:34 PM
erikc641 is offline
Joined Jul 2012
and your not going to be able to push that motor hard enough to really justify the 60a esc. My setup is the Power 25 1250kv motor, eflite 60a esc, 10.5x9 prop and i have the flaps and retracts. On 3s it pulls 550w at 42A and 4s it pulls 815w at 54A. It has a ton of power and takes off in about 4 feet.
Old Oct 08, 2012, 11:35 PM
erikc641 is offline
Joined Jul 2012
I also have the CC BEC installed
Old Oct 09, 2012, 12:13 AM
daalma is offline
Joined Oct 2012
thanks erikc
thanks for the info. im going to take your advise and go with the 25 . there is a motor mount on ebay, ill order that and a power 25. i think the bec is a good idea since im running 4 servos and retracts. i have a parkbec i can use. i would like to put a hobby lobby 4 blade on it. cant beat that look. thanks again
Old Oct 09, 2012, 12:15 AM
erikc641 is offline
Joined Jul 2012
just so you know, i use the stock motor mount and it fits perfectly. I just mixed a little epoxy and put a thin layer on the mount to stiffen it up a little.
Old Oct 09, 2012, 12:18 AM
erikc641 is offline
Joined Jul 2012
with that motor, I use the 11x7, 11x8 11x7 3 blade, 10x6 4 blade 10x7 4 blade, 10x10, 8x8, 9x9, 10x7. All have awesome performance. The 10x10 or 10.5x9 are my favorites. The 8x8 or 9x9 (4s 2200's 40C) have crazy speed (in excess of 100mph) but the plane lacks thrust and is hard to get off the ground on the our grass field.
Old Oct 09, 2012, 12:26 AM
daalma is offline
Joined Oct 2012
yeah i hear ya but im in no hurry. the weather is terrible right now so no hurry. for twenty bucks to the door what the hell . thnx ttyl
Old Oct 09, 2012, 11:26 AM
Gohmer is offline
Find More Posts by Gohmer
Owatonna MN 55060
Joined Sep 2005
How about unlimited vertical? Unlimited vertical is awesome too. Maybe excess of 100mph vertical?
Gohmer is offline Find More Posts by Gohmer
Old Oct 09, 2012, 12:46 PM
erikc641 is offline
Joined Jul 2012
it will go out of sight with no sign of slowing down (even on 3s). I do a loop, come out of it go straight up into another loop, go straight up, into another and so on. I even do that with inside loops upside down.
Old Oct 09, 2012, 12:47 PM
erikc641 is offline
Joined Jul 2012
this is all done at about 4000ft elevation
Old Oct 09, 2012, 01:21 PM
Gohmer is offline
Owatonna MN 55060
Joined Sep 2005
How many inside loops upside down can you do after it goes out of sight?
Old Oct 10, 2012, 12:43 PM
papabatman is offline
Find More Posts by papabatman
Shut up and fly
papabatman's Avatar
United States, CO, Dacono
Joined Jun 2008
here is the place for the best info on your bird
http://www.rcgroups.com/forums/showthread.php?t=1325884
papabatman is offline Find More Posts by papabatman
For Sale Stock PZ P47 motor/ aluminum mount fnlrun Aircraft - Electric - Power Systems (FS/W) 1 Oct 11, 2012 12:41 PM
For Sale WTS PZ P47, Durafly F4U and P51, AF F6F, BlitzRC P51, and micro PZ F4U and P51 in W APIT Aircraft - Electric - Airplanes (FS/W) 13 Aug 31, 2012 02:48 PM
Discussion Can the pz p47 be a trainer? jmillski Electric Warbirds 4 Jun 12, 2012 07:20 PM
Sold LPU used PZ P47 (ARF)- weathered paint scheme - $100 pilotuku Aircraft - Electric - Airplanes (FS/W) 9 Apr 17, 2012 09:20 AM
Discussion Can you use the PZ F4u 3 blade prop on the PZ P47? tehlump Electric Warbirds 2 Jan 20, 2011 01:29 PM
