Old Oct 08, 2012, 09:54 PM
Joined Dec 2006
Only USD80.9 HOBBYWING EZRUN 13T 3000KV RC Model Brushless Motor & WP60 60A ESC Combo
Motor Specifications
Rotational Speed: 3000 KV
Motor Dimensions (Diameter x Length): 36mm x 50mm
Shaft Dimensions (Diameter x Length): 3.17mm x 15mm
Input Battery Types: NiCd/ Nimh/ Li-po Battery
Recommend Model: RC Model Car
ESC Specifications
Model: EZRUN-WP-60A
Dimension: 46mm(L) x 34mm(W) x 35mm(H)
Cont. / Burst Current: 60A / 390A
Resistance: 0.0007 ohm
Suitable Car: 1/10 Scale On-road / Off-road
Motor Type: Sensorless Brushless
Suitable Motor:
2S Lipo 6 cells NiMH
On-road: =>5.5T, Off-road =>9T, 3650 size motor
3S Lipo 9 cells NiMH
On-road: =>8.5T, Off-road: =>13T, 3650 size motor
Battery: 4-9 Cells NiMH or 2-3S Lipo
BEC: 6V/2A (Linear mode built-in BEC)
Weight (with all wires): 75g
ESC Features
Water-proof and dust-proof. The ESC can work under water for a short time.
(Please remove the cooling fan when running car in water, and after running .please make the ESC clean and then dry it to avoid the oxidation to copper connectors)
Specially designed for RC car and truck, with excellent start-up, acceleration and linearity features.
Compatible with sensorless brushless motor.
3 running modes suitable for different applications (“Forward with brake mode”, “Forward/Backward with brake” mode and “Rock crawler” mode).
4 steps of maximum reverse force adjustment.
Proportional ABS brake function with 4 steps of maximum brake force adjustment, 8 steps of drag-brake force adjustment and 4 steps of initial brake force adjustment.
9 start modes (“punch”) from “soft” to “Very aggressive” to be suitable for different chassis, tires and tracks.
Multiple protection features: Low voltage cut-off protection for Lipo or NiMH battery / Over-hest protection / Throttle signal loss protection / motor blocked protection.
8 steps of timing adjustment.
Several programming methods are supported such as: the “SET” button on the ESC, the LED Program Card, the advanced LCD Program Box , and the PC Software.
The firmware of esc can be online updated through and USB adapter on the advanced LCD Program Box.
Program Card Introduction
Thank you for interesting the program card for the brushless ESC (Electronic Speed Controller). The program card has a friendly user interface, so you can easily set programmable parameters of the ESC with this device. It is pocket- sized, so you can bring it to the racing field conveniently.
Program Card Specifications
Dimensions: 88mm x 58mm x 14mm
Net Weight: 40g
http://www.hobbyhot.com/HOBBYWING-EZ...mbo-ME158.html
szewang2805 is offline Find More Posts by szewang2805
Reply With Quote  (Disabled)
Cool Only USD67.9 HOBBYWING EZRUN WP SC8 Waterproof 120A Brushless ESC Speed Controller szewang2805 Hot Online Deals 1 Sep 25, 2012 05:45 PM
Discussion Hobbyhot:SKYRC TORO 1/8 RC Model Truck X8PT 2000KV Brushless Motor & 150A ESC Combo szewang2805 Hot Online Deals 0 Aug 16, 2012 11:59 PM
Sold 500 heli motor and esc combo! Hobbywing 60a/ Align 500L HD Hucker Aircraft - Electric - Helis (FS/W) 0 Jun 30, 2012 10:25 PM
Sold FS New Hobbywing 13T 3000kv Brushless Motor & New 1/8 Buggy Tires fastmax Cars - Cars and Parts (FS/W) 3 Mar 07, 2012 08:31 AM
