Old Oct 08, 2012, 09:41 PM
dondi is offline
Find More Posts by dondi
Engine mounting via tape or rubber bands?
Hello,
Iím a novice scratch builder. Iíve built 4 or 5 flyable foamies at this point. My flying skills are novice as well.
Following a bad crash Iíve often noted that the engine/firewall has either torn off or the firewall/fuselage junction has been badly damaged.
Iím currently building a delta wing pusher and while working on the CG had just taped the engine/firewall to the rear fuselage mounting point temporarily .
With not much tape it felt surprisingly secure.
That caused me to wonder if anybody ever used tape as the only attachment method.
Also: What about ďrubber bandingĒ the motor to the fuselage similar to the way a wing might be mounted?
I thought that either technique might provide a bit of give the next time I make more of an impact while landing than I had intended, ha, ha.
Is there any experience using either technique?
Thanks!
Don.
dondi is offline Find More Posts by dondi
Old Oct 08, 2012, 09:56 PM
rcbif is offline
Find More Posts by rcbif
Do a Barrel Roll!
rcbif's Avatar
United States, OH, Medina
Joined Jun 2005
It's all about distributing force. The more area the motor mount is distributed over, the less likely it will be to damage the surrounding foam. You can increase your motors surface mount area using thin plywood, or a material stronger than the foam you use.
It's hard to see, but here is my delta. The motor is mounted to the end of a simple stick mount, and that is attached to a 2inx4in 1/8in piece of plywood glued to the main foam airframe. Very unlikely to come off in a crash.
rcbif is offline Find More Posts by rcbif
Old Oct 08, 2012, 10:12 PM
OutcastZeroOne is online now
Find More Posts by OutcastZeroOne
"Fly, yes... Land, No"
OutcastZeroOne's Avatar
United States, CA, Santa Cruz
Joined May 2005
properly securing a motor mount can have as much to do with the design of the aircraft as the shape and size of the mount. rcbif shows a good example for a stick mount motor, but for a plate mount here are a couple of examples.
The first picture I show a mount i made for one of my Funbats that was simply glued right to the front of the nose. But I had to make sure that it was fully secured to all edges of the foam behind it. For the flat plates of foam behind it I had multiple layers to make sure it didnt rip free. I also made a version with "fingers" that went backwards into the fuselage and glued to in the inside of the fuse to get as much grip as possible.
The next few show a pusher style aircraft Im working on. There are no flat pieces of foam attaching the mounts, only edges. The advantage of this is I dont have to worry about a simple piece of foam coming lose and my motor flying off.
OutcastZeroOne is online now Find More Posts by OutcastZeroOne
Old Oct 08, 2012, 11:27 PM
Whiskers is online now
Find More Posts by Whiskers
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
I've seen methods of rubber-band motor mounting and I suppose they would have a bit of 'give' which limit damage in a *hard landing.*
The best thing is not to crash, and with a bit of practice that's easier done than said.
Whiskers is online now Find More Posts by Whiskers
Old Oct 09, 2012, 07:21 AM
Spamman127 is offline
Find More Posts by Spamman127
United States, OH, Troy
When I was starting out, I used a shock mount for my motors. I would take 4 toothpicks and glue them into the airframe so that the motor mound fit on. Then I would take a dowel and put it horizontally behind the motor. Grab 2 rubberbands and loop them around the motor in a way that won't rub and allows little slop. This method would not save a propeller, but I never bent a motor shaft with this setup.
Spamman127 is offline Find More Posts by Spamman127
Old Oct 09, 2012, 11:11 AM
bz1mcr is offline
Find More Posts by bz1mcr
AKA Don
United States, FL, Naples
Joined Dec 2002
Dave Powers of RCPowers on youtube used to promote rubber banding motors on his 3D type planes.
bz1mcr is offline Find More Posts by bz1mcr
Old Oct 09, 2012, 02:22 PM
Thechittyfather is offline
Find More Posts by Thechittyfather
Damn this gets addictive.
Thechittyfather's Avatar
United Kingdom
Joined Oct 2011
I had the same issue. As mentioned above, spreading the load is probably your best bet. In the end if you get the mount right you will probably just get ripping around that area instead.
Each of my builds had a stronger mount than the one before untill I suddenly realised I'd quit crashing bad enough to do any damage.
1/16 ply makes for good way to spread the load well and the stick mounts available on line also have plenty surface area.
I would be concerned with brushless motors on a 'flexable' mounts. If the torque causes the motor to twist in the opposite direction it could interrupt the rythumn of the three phases. I've had it happen when testing motor/prop combos where the motor has not been fixed to something solid enough. You can hear them 'missfiring'.
Thechittyfather is offline Find More Posts by Thechittyfather
Old Oct 10, 2012, 03:16 PM
dondi is offline
Many thanks for the feedback.
I think the best solution to my problem is just don't crash!
Discussion what is the point using gimbal with vib damper when you mount with rubber band? jy0933 Multirotor Talk 4 Aug 21, 2012 03:56 AM
Discussion BOLT ON WING MOUNTING (converting from rubber band) Wylie Shaw Sailplane Talk 15 Aug 17, 2012 04:24 PM
For Sale Zenoah Gas Motor Engine Mount and Rubber Motor Mounts for your gas boat Rondog Boats (FS/W) 0 Jun 17, 2012 10:19 PM
Question "Portable" motor rubber band wing mounted 'pod' wanted rcairplains Electric Sailplanes 4 Sep 25, 2008 02:04 PM
Terry rubber band wing mount pics William A Foamies (Kits) 1 Jan 04, 2002 12:34 AM
