Old Oct 08, 2012, 09:08 PM
Joined Mar 2010
Will an 11V 3s Lipo Fry This Motor?
It's brushed from a 1/10 Scale RadioShack Hummer H2
as seen here
Hummer H2 Radio Shack 2006 (0 min 34 sec)
When I use a 3s 11v it's hella fast!
The default battery is 7.2V
It gets really hot with 3s and I've only used it for three minutes just to test, but is there a chance that the big motor will fry If I fully use the 3s?
Mecky is offline Find More Posts by Mecky
Old Oct 08, 2012, 10:51 PM
bashing on vancouver island
veggieslinger's Avatar
Joined Sep 2008
it will eventually fry. if the motor mount is plastic, (which i bet it is) you run the risk of warping the motor mount because of too much heat. it is risky to say the least.
veggieslinger is offline Find More Posts by veggieslinger
Old Oct 09, 2012, 01:09 PM
wparsons's Avatar
Canada, ON, Markham
Joined Aug 2008
You also have to consider the potential for damage to the circuit board... it wasn't designed for that much voltage or amperage.
wparsons is offline Find More Posts by wparsons
Old Oct 11, 2012, 03:33 PM
Obeying the law of gravity
Jeremy Kamutzki's Avatar
Canada, ON, Cambridge
Joined Jul 2011
yup... you would be better off with a 2s lipo, which is still able to provide alot more current than the stock nimh/nicd
Jeremy Kamutzki is offline Find More Posts by Jeremy Kamutzki
Discussion Can THIS motor work with THIS plane? If not-can you show me an ARF that will work? zdsweet Electric Plane Talk 2 Jul 24, 2009 09:44 PM
Found 3s 11v 3000-3400 lipo 20c dave3913 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Apr 15, 2007 04:38 PM
Question 9v motor 11v lipo will it work? Desert flier Batteries and Chargers 8 Feb 24, 2006 07:10 PM
Will I Fry My TP2100-3S? HavingFun2002 Batteries and Chargers 7 Apr 30, 2004 03:58 PM
