Old Oct 10, 2012, 04:34 PM
jofro is offline
Find More Posts by jofro
Joined Jan 2010
Originally Posted by Vince Herman View Post
I look at that picture and can't help saying "Flight con, I can't hold it! She's breaking up, she's break-"
No flight con, it was for real, all caught on video. J.
jofro is offline Find More Posts by jofro
Old Oct 10, 2012, 04:48 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
If only I had a car big enough to hold that...
acetech09 is offline Find More Posts by acetech09
Old Oct 10, 2012, 10:45 PM
Wingman26 is offline
Find More Posts by Wingman26
Wingman26's Avatar
Oklahoma
Joined Aug 2008
You would think they would have gotten a more powerful transmitter, or at least a power booster for the one they had. All the money they spent and they really weren't that well prepared, slow chase plane, stock off the shelf RC system.
Wingman26 is offline Find More Posts by Wingman26
Old Oct 11, 2012, 09:07 PM
slowjett is offline
Find More Posts by slowjett
-NEFPV-
United States, MA, Sturbridge
Joined Jun 2008
Originally Posted by acetech09 View Post
Well, the guy was holding a futaba Tx as the plane went down...
Lockout!
slowjett is offline Find More Posts by slowjett
Old Oct 11, 2012, 09:09 PM
acetech09's Avatar
Joined Apr 2012
No - that happens only if you use Spektrum
(sarcasm - been spektrum user for years, no issues)
Old Oct 11, 2012, 09:18 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Originally Posted by SLCPilot View Post
I did NOT see the program, but suspect the descent was mearly autopilot controlled. With "heading hold" for lateral navigation and "-1000fpm" for vertical navigation it would be fairly easy to guide a plane to a desired spot. It would be MUCH simpler than setting up a 727 for remote control with a budget.
Cheers!
SLCPilot
You might think that, but that is not how they did it....
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Oct 12, 2012, 12:58 AM
Usta Bee is offline
Find More Posts by Usta Bee
Closed Account
Joined Jul 2004
Don't forget this too:
http://www.airforce-magazine.com/Mag...10bombers.aspx
Usta Bee is offline Find More Posts by Usta Bee
Old Oct 12, 2012, 07:51 AM
DKChris is offline
Find More Posts by DKChris
Danish? Don't U eat that??
DKChris's Avatar
Denmark
A little data:
Span 9,6m
Chord 1,6m
Winge area 15m2 or 1504 dm2
Wing load 16,6g/dm2
Fuse length 7,2m
Stab span 300cm and chord 80cm
Materials: Mainly thin pine stripwood for fuse edges and wing spar caps, a lot of styrofoam and about a mile of 2" packing tape.
Calculated stallspeed 17km/h
AUW: not stated, but calculated from wing area/load just below 25kg.
First maiden flight ended in a crash induced by too little wing incidence, that broke the front end of the fuse apart - a new fuse was manufactured in a matter of a couple of hours, resulting in this second maiden flight. Construction, maiden, rebuild and remaiden all occurred within a 3 day meet.....
DKChris is offline Find More Posts by DKChris
Old Oct 12, 2012, 03:48 PM
Big Nuts 181 is offline
Find More Posts by Big Nuts 181
Big Nuts 181's Avatar
Joined Jul 2004
bloody great acheivement
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Old Oct 12, 2012, 04:26 PM
Irish Steve is offline
Find More Posts by Irish Steve
Irish Steve's Avatar
Ireland, Meath, Ashbourne
Joined Jul 2010
OK, re the 727, as I watched the program last night. It was radio controlled, the radio took over and the crew left, which was the plan. What wasn't in the plan was the chase plane going unservicable with a fuel pump failure, which left them between a rock and a hard place, as their permit from the Mexican Government for the crash test was very close to expiring, they'd not been able to fly on the planned day due to high winds making the parachute side of it too dangerous, so they had to use the 337 chase plane, which was marginal performance speed wise, or not fly the crash test, as there was no way to repair the faster chase plane in time, and no further delay option.
Having watched it, the scientists will be learning subtle facts for a long time to come, and we may or may not get to hear about them, what we saw on the programme last night was the raw facts, and some of the specifics of what happened to the test dummies, things like that, but the finer details will only come out with time and detailed analysis of the end results, which hopefully will lead to safer aircraft in the longer term.
In some respects, it's a pity they couldn't use a more modern twin low wing with wing mounted engines, as the impact forces would probably have been very different, if for no other reason than that the mass of thing like engines is in a completely different location, and would have acted very differently. If nothing else, the fire crew would not have been needed to kill an engine on a 737/320 type aircraft, the crash would have seen to that,
Another aspect is that the way the nose section failed would possibly have been different due to the different crash profile, while the main gear should have failed in a similar manner, and the engines are held on to the wing by "fuse pins", the manner in which they failed would have been different because of the greater distribution of the weight over a larger area, and there would have been a higher possibility of fire from the wing due to the location of the engines.
It just would not have been safe however for the crew to bail out in the way they did from the 727, the modern aircraft don't have a tail mounted stairway in the same way, so that exit route would not have been available to them.
In theory, yes, it would be completely possible to use the automation of the aircraft to produce a controlled flight into terrain, joking apart, several crews over the last 25 years have proved that with devastating consequences. Getting it into the air however would not be so easy, the automation is not set up to do that on commercial types, but the changes to do it for a special project would not be that complex for a limited scope mission such as this one.
Maybe that's for the next time, there's still plenty to learn from the detailed results of this test crash exercise.
Irish Steve is offline Find More Posts by Irish Steve
Old Oct 13, 2012, 11:23 PM
Wingman26's Avatar
Oklahoma
Joined Aug 2008
The chase plane they brought with them was the Cessna, very poor planning since it just wasn't fast enough. They came up with a Marchetti after they were in Mexico, they didn't really say if they found it locally or brought it down after they found out the Cessna wasn't cutting it. They said the Marchetti was a turbine engine, it clearly wasn't a turbo prop, I'm pretty sure it was a turbo charged and that's where the confusion came in, it almost killed the project when the fuel pump failed.
I thought they should have had the gear up for the landing, the nose gear would dig in on the desert floor, which it did, then the front of the fuselage broke off and went under the fuselage, I was really surprised when the main gear broke off, then was thrown up over and IN FRONT of the wings, I didn't expect that!
Old Oct 13, 2012, 11:50 PM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
A Mooney would of been a better choice.
Another 3 Knots could make the difference.
That and using 72Mhz.
In the end I believe it was a success. The goal was to crash the plane at 2000'/Min and they got 1500'?Min.
There was substantial damage and this gave a real world result.
1320fastback is offline Find More Posts by 1320fastback
Old Oct 14, 2012, 09:10 AM
aero550 is offline
Find More Posts by aero550
United States, OH, Tipp City
Joined Oct 2011
The Marchetti was indeed a turboprop.
aero550 is offline Find More Posts by aero550
Old Oct 19, 2012, 10:12 AM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
Thought it was the piston version at first, but went back and looked and it was an SF.260TP, the turbine version.
Discussion worlds largest foamy? or close? scottdearinger Foamies (Scratchbuilt) 34 Jun 10, 2012 07:40 PM
Discussion Come see the worlds largest gas-powered foamy emailbanter Giant Scale Airplanes 5 Apr 28, 2012 01:06 PM
Discussion world largest foamy build? it's big ! scottdearinger Foamies (Scratchbuilt) 2 Mar 06, 2012 06:37 PM
Yippee! RCGroups is the world's largest and most active web forum in the world! Miami Mike Site Chat 7 Mar 12, 2011 08:22 AM
Discussion Video of possibly one of the world's largest electric RC planes recently flying David A Electric Plane Talk 20 Apr 27, 2009 09:41 AM
