Old Feb 17, 2013, 06:03 PM
dharban is online now
Find More Posts by dharban
Flying = Falling (Slowly)
dharban's Avatar
Tulsa, OK
Joined May 2004
Originally Posted by GotLift9369 View Post
Don...are your 3S & 4S 850 65C packs made by TP?
Yes. And while I am sure that there are many other good packs out there, but I have never had packs that lasted longer or performed better than TP's.
Happy Landings,
Don
dharban is online now Find More Posts by dharban
Old Feb 17, 2013, 06:41 PM
Paulbilbo91z9f is offline
Find More Posts by Paulbilbo91z9f
Fly It Like You Stole It !!
Paulbilbo91z9f's Avatar
United States, MA, Pittsfield
Joined Sep 2011
Skye,
You can build your ALES plane with one servo up front in it's intended position and one all the way back at the wing root in the farthest rearward cut-out. This opens up even more room for battery placement around the CG. I've seen pictures of it done that way, I just haven't done it. Before I started cutting up my Aspire Disser I hung all the components off the bottom of the fuse with masking tape and placed it on my balancing stand. That's how I knew where to place everything and it would work.
Hi Don,
I'll love to see your program when it's ready. In my "Trial & Error" method of experimentation over the past year or so I've come with the same Hi & Low power requirements that you are suggesting. At 3S 850mAh I'm inputting 365 watts with the prop setup and ESC I'm using. If I decide to go All-Out and power up to my max 4S 2500mAh pack, then I'm just shy of 1,100 watts using the same motor & ESC. I've not seen ANY conditions or reason to go for more power than that.
And I agree with you that too fast a climb in ALES is a disadvantage. The only time you truly need the extra power is when you're trying to range out farther because of strong winds or some other factor. Setting your planes rate-of-climb for ALES is almost like deciding how much ballast to carry for TD. It becomes a very personal thing and the better you know your own plane and it's capabilities the better you'll be at making that decision.
Happy Flying,
Murph
Paulbilbo91z9f is offline Find More Posts by Paulbilbo91z9f
Old Feb 17, 2013, 06:54 PM
GotLift9369 is offline
Find More Posts by GotLift9369
GotLift9369's Avatar
United States, CA, Hesperia
Joined Mar 2009
Originally Posted by dharban View Post
Yes, the P32 gearbox will fit on the 1107. I had a 1105 fitted with one once. But you will like the 1107 fitted with the P29 gearbox a lot better. It is lighter and much slimmer. The P32 may fit your current plane quite well, but many of the newer planes have noses which are simply too narrow to fit it. An 1107 with the P29 ought to be useful for a long time.
Happy Landings,
Don
Thanks for the info.
Rick
GotLift9369 is offline Find More Posts by GotLift9369
Old Mar 13, 2013, 06:36 PM
s2000 is online now
Find More Posts by s2000
so. cal.
Joined Jan 2006
Got er done! This set of wings are my C68 pure sailplane, will be putting the servos in the ST wings in the next few weeks. Nice setup by Larry, it all fits like he laid out and CG is spot on! Might try a few flights tomorrow, freedom from a winch and bungee at last! And it's RED!
s2000 is online now Find More Posts by s2000
Old Jul 14, 2013, 04:36 PM
aliraminghe is offline
Find More Posts by aliraminghe
Italy, Veneto, Vicenza
Joined Aug 2012
Aspire for OFF category
Here is my two cent contribution to Aspire setup for OFF category i.e. Only For Fun
sorry but there are enough rules on everyday life so on free time I like just to enjoy flights catching thermals
Thanks to the previous posts I have setup fuse servos, receiver and telemetry under the wing bay leaving free space for battery on the canopy bay.
In the attached pics configuration for windy days with a 2400 mAh 3S lipo and 2350 grams
Hope competion pilots could pardon me for taking away this great saiplane
Carlo
aliraminghe is offline Find More Posts by aliraminghe
Old Jul 15, 2013, 01:42 PM
pmccleave is offline
Find More Posts by pmccleave
USA, KS, Wichita
Joined Sep 2002
Hey Carlo,
Fun is what it is all about whether just playing around or competing. I find myself pursuing the fun factor more and more all the time.
Ciao,
Pat
S
Carlo
pmccleave is offline Find More Posts by pmccleave
Old Jul 19, 2013, 07:43 AM
Tuomo is online now
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Originally Posted by pmccleave View Post
Hey Carlo,
I agree. Nobody would go to competitions year after year without considering it as fun. Personal preferences. Competitions are not only about flying and excitement. I like also travelling, meeting friends etc.
Tuomo is online now Find More Posts by Tuomo
Old Oct 08, 2014, 04:38 PM
ttoomm is offline
Find More Posts by ttoomm
(LITTLE TOM)....
ttoomm's Avatar
United States, CA, Huntington Beach
Joined Jan 2005
body? have an E Fuse ready to go
ttoomm is offline Find More Posts by ttoomm
Old Oct 09, 2014, 09:08 AM
Larry Jolly is offline
Find More Posts by Larry Jolly
Larry Jolly's Avatar
Joined Oct 2003
I have Aspire E Fuses in stock. Contact me ljolly@aol.com
Larry Jolly is offline Find More Posts by Larry Jolly
Old Oct 11, 2014, 10:34 PM
Airman74 is offline
Find More Posts by Airman74
E sailplane thermal hack
USA, CA, Chico
Joined Feb 2011
Happy Landings,
Don
+ 1 here
Airman74 is offline Find More Posts by Airman74
Old Mar 27, 2015, 01:25 PM
mgroves is online now
Find More Posts by mgroves
Klutzsquatch
mgroves's Avatar
Columbus, Ohio
Joined Oct 2006
Flap servo
Anyone know if the airtronics 94761 will fit th Aspire wing? Considering them for the flaps if they will fit
mgroves is online now Find More Posts by mgroves
Old Mar 29, 2015, 09:42 PM
s2000 is online now
so. cal.
Joined Jan 2006
Plenty of room for the 761 servo, you have room to spare. The JR 3421 fits easily and it is fatter.
Build Log Lubos Pazderka F3J Aspire X-Tail fnnwizard Multi Task F3X 355 Oct 13, 2014 10:29 AM
Alert Pazderka Electric Aspires Available in September Larry Jolly Electric Sailplanes 2 Jun 28, 2012 05:25 PM
Discussion More Aspires from Lubos Larry Jolly Multi Task F3X 8 Apr 27, 2009 02:11 PM
Sold Victor F3J from Lubos Pazderka dougalert Aircraft - Sailplanes (FS/W) 8 May 26, 2008 11:02 AM
Discussion Now anything about the Aspire by Lubo's? truestorys Sailplane Talk 4 Aug 15, 2006 04:14 PM
