David,
In the conditions you have described a design with the attributes of the Aspire will do well. It is a clean airframe with great penetration, excellent handling, and it loves ballast. When it comes to competition one has to separate pilot skills and glider capability. Meaning a high performance glider design will always be capable, and will always perform better in a skilled pilots hands. The combination of a good glider, a pilot that has come with a good skillset, and the strategy and will to win is a tough combination. LJ |
Your launch height is defined by the highest altitude reached from launch until 10 seconds after motor shut off. Spiraling down under power would not be advantageous. Lenny |
Tampere, Finland
Joined Oct 2009
I understood the rules as Roy did.
The 10 seconds after shutting off is to prevent high speed zooming. If you come lower with the motor running, within the allowed motor run time, your starting height is the lower height where you start your gliding. That height is measured when 10 seconds have elapsed after motor shut off. Tommy |
Steve Neu |
Steve |
The whole topic of wing loading for the various flight tasks is complicated, but interesting. Steve ps: btw, Steve, for next years ALES season I am going to pack one of your 1506 2.5D 6.7 motors into a Nan Orion. RFM 17x13, 2200 4S 45-90C... not exactly a floater. Will it be the optimum ALES sailplane? No. Will it be fun? Hell yes. |
Happy Landings, Don |
United States, IL, New Lenox
Joined Feb 2005
E-spire
Larry,
Now that you have some time on your E-spire, is there anything that you would do differently the next time around? Are there any changes that you would recommend for those of us waiting for the E-fuse? Thanks, Ron |
Hey Ron,
If you build it exactly as I suggested,it is a very competitive machine. I recently flew the last ALES comp up at SVSS. Honestly the Aspire's perfomance left nothing to be desired. Mine is a little light at sub 68 ounces but I was able to move with standard reflex settings. I will set up a second model with a heavier wing and ballast tube. The firewall-fender washer is strong enough for competitive landings. In 5 landings I was able to post 4-50pointers and 1-40 pointer when I bounced off the metal center which looked like it was the tongue end of a seat belt. By the way on one flight I went horizontal for 12 seconds then when I saw the bounce went vertical for 15 when the Aspire reached 200 m... If I am still building your fuse out get your components together..LJ |
re: Motor Question???
Hi Guys,
I've got a question that I'm hoping this group can answer for me. Last winter I purchased an Aspire Disser and converted it to electric for ALES. I've flown it for an entire year now and have had great luck with it and really love the plane. I'm running a Hacker inrunner B40 w/gearbox and did not have to add any weight to get the correct 118 - 119 CG. The Disser floats wonderfully with this setup and still penetrates well in normal to med. wind conditions. With the inrunner I can run a 3S battery for normal conditions at around 600 watts, or put in a 4S and the B40 will crank out just over 1,000 watts if I need it. My question is; What is the advantage to running an outrunner like the Hacker A20-6XL??? Am I missing something??? ![]() Any input would be welcome. Thanks, Murph |
| Thread Tools | |
| Build Log Lubos Pazderka F3J Aspire X-Tail | fnnwizard | Multi Task F3X | 351 | Feb 19, 2013 02:56 PM |
| Alert Pazderka Electric Aspires Available in September | Larry Jolly | Electric Sailplanes | 2 | Jun 28, 2012 05:25 PM |
| Discussion More Aspires from Lubos | Larry Jolly | Multi Task F3X | 8 | Apr 27, 2009 02:11 PM |
| Sold Victor F3J from Lubos Pazderka | dougalert | Aircraft - Sailplanes (FS/W) | 8 | May 26, 2008 11:02 AM |
| Discussion Now anything about the Aspire by Lubo's? | truestorys | Sailplane Talk | 4 | Aug 15, 2006 04:14 PM |
