Old Oct 15, 2012, 11:58 AM
liukku is online now
Find More Posts by liukku
mostly gliders
liukku's Avatar
Skellefteċ, Sweden
Joined Sep 2003
Originally Posted by Larry Jolly View Post
Thanks for the interest, get your equipment ordered, fuselages will be here before Christmas...It looks like Lubos has just made a great Sailplane even better! Can't help but be smiling with so many competent glider flyers lining up to kick my butt in ALES
Hello Larry
I must ask if you sell the Aspire, for what firm if so?
/Ville
liukku is online now Find More Posts by liukku
Old Oct 15, 2012, 03:23 PM
Larry Jolly is offline
Find More Posts by Larry Jolly
Larry Jolly's Avatar
Joined Oct 2003
Ville,
I do represent Lubos in the US. You can reach me privately at ljolly@aol.com.
LJ
Larry Jolly is offline Find More Posts by Larry Jolly
Old Oct 16, 2012, 06:30 AM
mostly gliders
liukku's Avatar
Skellefteċ, Sweden
Joined Sep 2003
Ville,
LJ
Thank you Larry for the info, good to know if we meet sometime and I need help or replacement parts. Have seen that you have offered your settings for Aspire, do you think I can get them?
My email adress is viljo56(at)gmail.com
regards
/Ville
Old Oct 16, 2012, 04:08 PM
fly-up85 is offline
Find More Posts by fly-up85
Slovakia
Joined Nov 2009
Hello Larry
This is my ballast solution for Aspire , this is my heavy plane for windy conditions 2,2kg . Each tube have 10 x 340mm in dural have 60g each , in brass 150g each tube . Power unit Mega 16/35/3 direct drive for heavy plane 2,2 kg and Mega 16/25/4 direct drive for light plane 1,85k kg .
BM
fly-up85 is offline Find More Posts by fly-up85
Old Oct 16, 2012, 05:02 PM
Joined Oct 2003
Thanks BM,
Sweet setups in your Aspires. This one was for ALES since this has the most interest in the US now. My next one will be for F5J.. This will have a different setup and definitely be set up for ballast. I will look you up when I move into J.. Thanks for sharing
LJ
Old Oct 16, 2012, 07:27 PM
mostly gliders
liukku's Avatar
Skellefteċ, Sweden
Joined Sep 2003
Originally Posted by fly-up85 View Post
Hello Larry
BM
Hello fly-up85
Looking good. Can you give some more data about your setup? Do you have any numbers of the climbing performance on your Aspire?
I will post my setup as soon as I can although it is in the testing stage yet.
/Ville
Old Oct 17, 2012, 01:02 PM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
I will have my electric Aspire flying in a week or so---but I am going for a bit more power No wimpy drive systems for me---1800 watts and a 20/15 prop. I have a 5S 1600 pack--yes it fits just fine---and a 1110/1.5Y/6.7 motor and gear drive with a ICE 100 controller. Full power current should be just north of 130 amps. Static thrust will be over 300 oz--just enough for good fun. Weight will be a few oz more than the floater setups--but a few oz on a plane with that much area is not going to have a major impact.
Steve
sneu is offline Find More Posts by sneu
Old Oct 17, 2012, 02:51 PM
soholingo is offline
Find More Posts by soholingo
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
What took you so long to show up Steve??? And those 1600 cells sound perfect for the 7 cell/2s 1506/1D motor...
soholingo is offline Find More Posts by soholingo
Old Oct 17, 2012, 03:29 PM
IBWALT is offline
Find More Posts by IBWALT
W0X0F
IBWALT's Avatar
Joined Nov 2005
Steve
Thanks Steve, now I don't feel bad about squeezing 1000 watts out of my 1110/2.5D/6.7 18X13 on a 65C 4S 1300ma with a CC Ice Lite 75 (80a static).
IBWALT is offline Find More Posts by IBWALT
Old Oct 17, 2012, 03:31 PM
tewatson is offline
Find More Posts by tewatson
Tut, Tut...
tewatson's Avatar
United States, CA, Orange
Joined Oct 2006
I wonder if the design has changed? The RFM spinner I just received looks quite sturdy...the actual spinner cone has four large molded carbon fillets that engage the yoke and it looks like plenty of epoxy is used.
Tom
Originally Posted by IBWALT View Post
Larry, nice job. I would only add one comment about your choice of spinner. The RFM spinners look great but they are attached to the yoke with a skim of epoxy. With the bumps and bounces involved in landing the spinner is prone to separate from the yoke.
tewatson is offline Find More Posts by tewatson
Old Oct 17, 2012, 03:53 PM
dharban is online now
Find More Posts by dharban
Flying = Falling (Slowly)
dharban's Avatar
Tulsa, OK
Joined May 2004
Tom
The mode of failure is typically that the epoxy breaks away clean from the aluminum hub. I have never broken a spinner per se. But I have had the spinner break loose from the hub on several occasions.
Happy Landings,
Don
dharban is online now Find More Posts by dharban
Old Oct 17, 2012, 04:21 PM
Joined Oct 2003
Great Job Steve,
Please let me know when I can pick up that motor box combination. Let me know when you are going to fly I will go out with you.
Don are you coming down to the TNT???
Good luck with your model Tom.
By the way in my build I cut the Red wire on the ICE ESC because I ran a separate RX pack. I now advise you to leave the ESC intact so that you can program the ESC from a computer. So cut the wire on the CAM side of the junction. LJ
Old Oct 17, 2012, 04:25 PM
dharban's Avatar
Tulsa, OK
Joined May 2004
Great Job Steve,
Larry,
I'll be at TNT.
DON
Old Oct 17, 2012, 05:13 PM
IBWALT is offline
W0X0F
IBWALT's Avatar
Joined Nov 2005
Tom
The design has not changed Tom. The spinner is attached to the smooth sides of the aluminum yoke with epoxy. There are no holes, dimples nor does the surface of the yoke where the bonding takes place appear to be roughed up. I'm not so worried about the spinner separating from the yoke on landing but should it become partially detached on a landing and then get slung off during power up. I'm sure you would agree that a cf spinner losing its bond to the yoke and being struck by a prop turning somewhere near 6k rpm could hurt someone.
Old Oct 17, 2012, 05:30 PM
roydor is offline
Find More Posts by roydor
In F3J size does matter!
roydor's Avatar
Israel
Joined Nov 2006
Hello Larry
BM
I'm really interested in your setups for F5J.
I have narrow fuses in my F3J models which I want to electrify.
For this reason an outrunner is not a good option for me and geared setups are expensive. I'm looking for good inrunner solutions and these two motors are very interesting since they must be working and working well if you are using them.
What props and batteries are you using for both of these motors?
How much power are you getting out of these setups?
What climb rates?
Can you also give some information about the spinner, It's unknown to me.
Roy
roydor is offline Find More Posts by roydor
Build Log Lubos Pazderka F3J Aspire X-Tail fnnwizard Multi Task F3X 355 Oct 13, 2014 11:29 AM
Alert Pazderka Electric Aspires Available in September Larry Jolly Electric Sailplanes 2 Jun 28, 2012 06:25 PM
Discussion More Aspires from Lubos Larry Jolly Multi Task F3X 8 Apr 27, 2009 03:11 PM
Sold Victor F3J from Lubos Pazderka dougalert Aircraft - Sailplanes (FS/W) 8 May 26, 2008 12:02 PM
Discussion Now anything about the Aspire by Lubo's? truestorys Sailplane Talk 4 Aug 15, 2006 05:14 PM
