Old Oct 08, 2012, 04:55 PM
A1CpuntacanaDr is offline
Find More Posts by A1CpuntacanaDr
A1CpuntacanaDr's Avatar
United States, CT, Plainville
Joined Jan 2012
What went wroooong!!!!!!!!!!!!
I been flying on this set up all sumer recently i order a turnugy nano tech 1000mah 25-50 c 4s whent out to the field and this happend dont know why Did the battery was to much for the esc ?
A1CpuntacanaDr is offline Find More Posts by A1CpuntacanaDr
Old Oct 08, 2012, 04:58 PM
Underthetire is offline
Find More Posts by Underthetire
Underthetire's Avatar
United States, CA, Brentwood
Joined Jun 2012
Is that esc rated for 4 cell? Don't think my hobbywing is.
Underthetire is offline Find More Posts by Underthetire
Old Oct 08, 2012, 06:32 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
If you flew all summer on 3 cell, and just tried 4 cell, that is what happened! Lucky you didn't start a brush fire.
I had an ESC did that too once. Saw smoke from the airplane as it was flying, brought it down through some trees because I was over dry brush, and the ESC was completely destroyed! I still thank the dear Lord that it stayed together long enough to get the plane out from over the brush area!
Freddie B is offline Find More Posts by Freddie B
Old Oct 11, 2012, 04:11 PM
kelberts is offline
Find More Posts by kelberts
Effumall
kelberts's Avatar
Joined Nov 2005
You have to check the ESC specs before you increase the voltage (number of cells). Same thing if you're going to be drawing more amps with a different power set-up...
kelberts is offline Find More Posts by kelberts
Old Oct 11, 2012, 04:14 PM
kelberts is offline
Effumall
kelberts's Avatar
Joined Nov 2005
Freddy, that's why I use a separate BEC - even if the ESC fries, you still have control. (Or if you can afford the weight, a separate RX battery is the safest).
Discussion Motor,ESC, or Battery?.. What went wrong? SirBadWolf Power Systems 32 Sep 18, 2012 06:37 PM
Discussion What went WRONG Ciruplas Power Systems 9 Sep 17, 2012 06:01 PM
Discussion Two LEDs in parallel - what went wrong? BravoOneZero Power Systems 15 Aug 06, 2012 05:16 AM
Discussion Crashed the plane. What went wrong?! kenzietech Beginner Training Area (Aircraft-Electric) 19 Apr 04, 2012 02:11 PM
9C screen went blank on me untill I reset, whats up? sizam Radios 3 Feb 08, 2003 11:22 PM
