Espritmodel.com Heli Air
This thread is privately moderated by GeetarJoe, who may elect to delete unwanted replies.
Old Oct 08, 2012, 03:47 PM
Who Dat!
GeetarJoe's Avatar
United States, LA, New Orleans
Joined Sep 2011
Trader Rating: 48
Lots and Lots of Carburetors!
All are for sale. $50 Each for the Walbros and $40 for the Zamas.
Warlbo F8/WA 144 Carb: 11.11mm
http://www.rcgroups.com/forums/showthread.php?t=1650267
Walbro HDB6B Carbs new or like new
http://www.rcgroups.com/forums/showthread.php?t=1650266
Walbro Carbs WT610 new or like new 13mm
http://www.rcgroups.com/forums/showthread.php?t=1650264
Walbro Carbs WT529 New or like new 13mm
http://www.rcgroups.com/forums/showthread.php?t=1650263
Walboro HDA110 13.49mm
http://www.rcgroups.com/forums/showthread.php?t=1650195
Zama C1Q ~40cc 12.5mm
http://www.rcgroups.com/forums/showthread.php?t=1650258
Notice: The previous threads have been closed in order to keep all of the replies in one place. Please PM me if interested.
GeetarJoe is offline Find More Posts by GeetarJoe
Old Oct 09, 2012, 09:21 AM
What - Me Hurry?
redball8's Avatar
United States, IL, Naperville
Joined Jul 2004
Trader Rating: 116
GeeTar, ever run across a Del'lorto carb? I have a few OPS 30cc Maxi's that use them, and have heard that Walbro carbs are bolt-on replacements. I wondered which Walbro would fit? And can you run a Walbro carb on glow fuel?
Thanks, RB8
redball8 is offline Find More Posts by redball8
Old Oct 09, 2012, 02:21 PM
Who Dat!
GeetarJoe's Avatar
Joined Sep 2011
Trader Rating: 48
you can but you have to change the pump diaphragm to the teflon or acetate one that comes in the rebuild kit. what is the venturi diameter of the stock carb? im sure one of these carbs will work. probably the WT610.
Old Oct 09, 2012, 07:55 PM
What - Me Hurry?
redball8's Avatar
Joined Jul 2004
Trader Rating: 116
The Del'Lorto carb has a 10 mm venturi diameter.
It also has this port on the carb mounting base for crankcase pressure, to operate the diaphragm. Is that pretty standard on pumper carbs?
Old Oct 09, 2012, 11:14 PM
Who Dat!
GeetarJoe's Avatar
Joined Sep 2011
Trader Rating: 48
Yes. The crankcase pulse is required to get these carbs to work. If the walbro is a bolt on then the pressure port is likely to be in the right place. Even if its not you can tap the case and run the pressure line externally. The pressure port is in the same place on all standard walbro carbs.
Im about to hit the bed, early day tomorrow. But if you can hang tight until tomorrow evening i will break out the calipers and measure out these carbs. Im certain i have one with a 10mm venturi.
Old Oct 12, 2012, 07:26 PM
High & Mighty's Avatar
NW Ohio
Joined Mar 2009
Trader Rating: 9
13.49 MM is the venturi diameter or .531" which equals 17/32".
The OPS Maxi 30 is a beast and I'm sure a 10mm venturi is not enough to feed it.
High & Mighty is offline Find More Posts by High & Mighty
Old Oct 13, 2012, 01:06 AM
brown2x2's Avatar
United States, KS, Newton
Joined Feb 2006
Trader Rating: 3
hii
brown2x2 is offline Find More Posts by brown2x2
Discussion Small Engine/Carburetor Cleaner PyroMan Beginner Training Area (Fuel) 7 May 06, 2012 01:39 PM
Sold Royal .40 Carburetor N925WB Aircraft - Fuel - Engines and Accessories (FS/W) 2 Apr 09, 2012 07:38 AM
Discussion No more carburetors kenh3497 Engines 28 Apr 06, 2012 07:26 PM
Sold Lighty used O.S. Carburetor 61E For 91HZ bbq4good Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 19, 2012 07:29 PM
Found New or used Carburetor needed J.A.Bairos Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 09, 2012 05:45 PM
