Old Oct 08, 2012, 03:27 PM
Hoss87 is offline
Find More Posts by Hoss87
Joined Oct 2012
Help!
Engine frozen up
Greetings, I have an old Enya fuel engine that I bought in the 80's but never used. I want to revive it. I soaked it in kerosene for 2 weeks but it's still frozen. I'm hesitant to take it apart. Worried that I might damage some seals or not be able to get it back together properly. Does anyone have any suggestions or is taking it apart my only recourse?
Thanks in advance for any assistance!
Hoss87 is offline Find More Posts by Hoss87
Old Oct 08, 2012, 04:08 PM
tpasztor is offline
Find More Posts by tpasztor
tpasztor's Avatar
United States, TX, Lake Jackson
Joined Aug 2011
Paint thinner in carb and muffler. Work it slowly back and forth until it breaks loose.
tpasztor is offline Find More Posts by tpasztor
Old Oct 08, 2012, 04:40 PM
GeetarJoe is offline
Find More Posts by GeetarJoe
Who Dat!
GeetarJoe's Avatar
United States, LA, New Orleans
Joined Sep 2011
NOOOOOOOOOOO!
plastic parts and some rubber o-rings and seals will not like this.
most likely the engine is frozen due to the oil that was stored in it gumming up the work. heat is your friend. stick it in the oven on about 125 or use a hair dryer or a heat gun on low and see if you can get it to move.
you may also remove the backplate and check the bearings for any rust or corrosion. if the engine sat up in storage for that long i would be surprised if the bearings arent rusted stuck.
GeetarJoe is offline Find More Posts by GeetarJoe
Old Oct 08, 2012, 06:17 PM
JohnsPop is offline
Find More Posts by JohnsPop
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
+1 on heat. Be willing to bet it's just castor gummed up in there.
JohnsPop is offline Find More Posts by JohnsPop
Old Oct 08, 2012, 06:33 PM
Hoss87 is offline
Joined Oct 2012
Yes! Heat did the trick. Heated it up with my heat gun and it came apart. Then cleaned all the gum out with carb and choke cleaner. Thanks so much!
Old Oct 09, 2012, 11:25 PM
Jason_WI is offline
Find More Posts by Jason_WI
Cox Engine Hoarder
Jason_WI's Avatar
Neenah, Wisconsin, United States
Joined Jun 2004
I would still pull the back plate off to check that the bearing is actually spinning and not the inner race slipping on the crankshaft. This can ruin a perfectly good engine in a short time.
Jason
Jason_WI is offline Find More Posts by Jason_WI
Wanted Frozen, Worn Out, Crashed Engines arnard Aircraft - Fuel - Engines and Accessories (FS/W) 2 Jul 30, 2009 01:59 PM
Question OS .40 engine is frozen after a couple years of sitting TyFlies Beginner Training Area (Fuel) 2 Jan 17, 2009 09:04 AM
Discussion Frozen Engines KOBRA Engines 6 Jan 17, 2007 03:59 PM
.19 Engine frozen up cnc9130 Engines 4 Mar 17, 2005 08:03 PM
Frozen engines J R Purcell Fuel Plane Talk 4 Apr 10, 2002 03:20 PM
