Gears break from flutter and from overloading--sometimes just accidents on the ground If you make the plastic gears large enough to not break the servo gets too big for fitting in thin wings.Steve |
, (remember, an F5D should also explode at +220mph, hehe)......and there are a lot examples of having Dymond d60 in wings of F5D:s = no flutter...For me the titanium hitec servos are overkill... thats my opinion... Quote:
, trying to fit GOOD sloopfree 12mm heigh servos in my Viper, just to be 200% sure ... saving like 100 dollars and even get better servos, the cost is making custom servocovers, and maybee -1mph cost in speed due to the extra drag , but I can live with that...Sebbe |
For some a 1 mph difference IS enough to make the difference ![]() IMHO D60s are not that good for F5B or D--they are way to easy to strip gears and flex too much when under load. I have cut out quite a few from my F5B planes. Steve |
It will always be some not liking some stuff and the other way around..
I just want the space to put any normal small size servo up to 12mm inside, as there I have a HUGE option, Hitec, JR, Dymond and so on,,,, the price goes down also and also better stronger gears, no sloop, more power and so on much easier to choose now as the range increased from max 9mm to 12mm.. About the dymond D60, well there has been so many flying these long time in F5D:s, and no problem, but of course, you can always go up one step all the time, but Im sure even the D60 are good for the job in a normal powered F5D+ some more.. Sebbe |
![]() well if 1mph is worth so much, then the Hyp 09 servos will fit, they can take up to 300mph if done right with linkage.. --------------------------------------------------------------------------------------------- This is what we have to thank guys like Henke, Doug, DownUnder, Slowbarless, JJ and similar for testing stuff, now we can draw some conclusions of what does work and not + we get the limits when these guys are pushing things ...
While we're talking about servos. I have never, ever been satisfied with ANY of the servos currently available for use in F5D wings. They either have a sloppy gear train, weak center, terribble accuracy, bad precision, poor centering, fast wearing gears, poorly designed electronics (cant be run on 6v? seriously?) or a combination of all of the above. (Ofcourse im refering to the range of 9mm and thinner servos out there)
That is untill the 7115's came out. Sure yes, they are expensive. But its about time we moved on from the foamy servos hyperion, dymond and mks are supplying. Finally there's a servo available that I would consider 'adequate' to be installed into a 300+kmh racer. I am very picky when it comes to servos though and I never skimp on them. They are the most important part of the plane, followed closely by the reciever battery! Ben |
Ben, Im sure the new hitec ones are VERY good, never said anything about that..
BUT they are expensive AND pretty heavy, not sure everyone would buy them.. As Yuri said, we have to select servos, test them, then put them in plane.. everything has a best before date, Im sure if flying often you have to exchange servos more often, metalgear maybee develope slop over time, nylongears maybee can strip, like all other stuff inside our planes, it ages, and we have to look after it when time goes by.. Also props do need to exchange after time, depending on how much you fly, for me this is a normal situation, to check the setup you are flying all the time.. what I said, was that servos like Hyp09 in strength and precsion is OK up to 300mph if done correct, we have seen this, it is not scienfiction ![]() Im sure (maybee) te new hitecs are among the best, BUT also cost much more and are twice as heavy.. The porpuse of this thread was to get some covers for my viper, just so I can fit servos up to 12mm, this way I KNOW for sure I have many many to choose from, and Im sure a good 12mm servo is as good as the new slim hitec but much cheaper.. Then of course, not everyone wants to make mods to fit bigger servos, its up to each one.. Sebbe |
Yeah, the hitics are heavy, but from what ive seen alot of F5D airframes could do with the extra weight to get them over 1kg.
The 09's im sure could be made to work up to 300mph but not with standard linkages, having a stronger servo holding the surfaces means you can get away with a more 'normal' linkage setup. Hitec servos are known for a very tight gear train and these servos are no exeption. Anyway, back on topic. What are you going to do for covers? |
| Thread Tools | |
| Discussion Custome Made Multi Charge Leads | KenSue | Batteries and Chargers | 4 | Apr 14, 2012 07:52 AM |
| For Sale Custom Made 1/10 Brushless Monster Truck $165 | F27QFlyer | Cars - Trucks and Parts (FS/W) | 7 | Mar 23, 2012 06:24 AM |
| Wanted TRADE: Your glider for a NEW custom hand-made Acoustic Guitar | Scott Whitney | Aircraft - Sailplanes (FS/W) | 14 | Mar 20, 2012 04:22 PM |
| For Sale 3 custom made heavy duty charging cords- All 3 for $20.00 tyd. | 540RCflyer | Aircraft - General - Radio Equipment (FS/W) | 0 | Feb 25, 2012 11:12 AM |
