Old Oct 08, 2012, 11:47 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
servocovers ? custom made ?
Hi, is there a place where I can buy servocovers fitting my Viper F5D, BUT only3mm higher so I can fit a 12mm servo and still get the servocover on looking good.
Im not trying to buy something exactly for the Viper and my requests, but maybee there is some that could be cut down and fit ?
OR, if someone could make me a pair custom for a reasonable cost ?
the covers are 43 x 36mm to fit inside the small lip, but they can be larger on outside also, I can tape them against the wing,,
sebbe
sebbe is offline Find More Posts by sebbe
Old Oct 08, 2012, 11:58 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
They need to be 3mm higher "bulb" sticking up then the original ones, making room for 12mm servos...
Old Oct 08, 2012, 12:40 PM
VooDoo Child is offline
Find More Posts by VooDoo Child
Drinks Day Old Expired Milk
VooDoo Child's Avatar
United States, OR, Portland
Joined Aug 2010
Sounds like a job for Tim aka KRProton
VooDoo Child is offline Find More Posts by VooDoo Child
Old Oct 08, 2012, 01:17 PM
vespa is online now
Find More Posts by vespa
First pull up, then pull down
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
12mm servo in F5D? Why?
vespa is online now Find More Posts by vespa
Old Oct 08, 2012, 01:32 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
I hope so , and he also have a Viper, so should be easy testing them...
Old Oct 08, 2012, 01:33 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
GOOD reliable sloopfree servos in that range 10.5 to 12mm, easy to find..
I will go for that, you should do what you believe in....
Old Oct 08, 2012, 04:32 PM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Try the new 8mm hitec 7115TH--with nice strong titanium gears.
Steve Neu
sneu is offline Find More Posts by sneu
Old Oct 09, 2012, 03:51 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Steve Neu
Ive seen them, but the cost is astronomical
Old Oct 09, 2012, 04:33 AM
henke is offline
Find More Posts by henke
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Lšn, Ljungby
Joined Jan 2001
I can make in the 3D printer, about €20 for a pair 100% custom. + shipping in Sweden.
Not super cheap but atleast an option.
for my application they turned out like this. The black is epoxi paint which did't work well. Better just color them with a magic marker pen.
henke is offline Find More Posts by henke
Old Oct 09, 2012, 05:51 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Sound ok Henke,, Have a few options/ideas making them myself also, I will let you know if my own works goes bad
Thanks..
Old Oct 09, 2012, 05:52 AM
KRProton is offline
Find More Posts by KRProton
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
Mm, uh, well, here are the taller servo covers I made for my Viper. Suspecting aileron flutter a while back, I thought the culprit was the thin, flexible wing skin to which the servos were glued. So I then removed the aileron servos and glued 1/64" plywood to the inside of the wing skins to reinforce them before gluing the servos back into position. This, then required taller aileron servo covers which I vacuum-formed from ABS over molds I made from basswood. The covers are taller than required and I intended to shave the molds down a little and pull new, lower covers, but haven't gotten around to it yet. In the mean time the covers have performed perfectly.
Since taking the photos I've painted the covers to match my wing.
I suppose I could pull you a set sebbe, but how to send to Sweeden? I don't need any payment except to cover the cost. Maybe I could send, then you can pay me later after I get the shipping bill.
Tim
KRProton is offline Find More Posts by KRProton
Old Oct 09, 2012, 06:06 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Tim
EXCELLENT , just what I want, exact that shape and size... Im sure they will be perfect, YES, make a pair please, tell me how much when done, choose shippingoption so they reach in normal time, (not the cheapest way, and not the most expensive either), something affordable and reliable...
THANKS man...just let me know via PM what the optins for shipping are.. this wil help me alot..
Sebbe
Old Oct 09, 2012, 06:08 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
OH, how heigh was the wodd you put in between ? just good to know how heigh servos can be fitted....
edit: never mind, saw it now, 1/64 " but this is just like 0.4mm,,,, hmm, I would need the covers to be 3mm heigher then the original ones,,,,so a 12mm servo can be fit inside.. normally the original ones only take 9mm, right ?
Going to train now, will be back in 2 hours, I will check in then,,
Old Oct 09, 2012, 06:16 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I've found tape works nicely.
..a
Old Oct 09, 2012, 06:19 AM
SB7 is offline
SB7
Find More Posts by SB7
SB7
I am actually really slow
Brisbane
Joined Jun 2008
If you have drawings and approximate sizes I could carve a plug and make a mould for them.
You're better off though just using the covers you have, getting some 3mm balsa, cutting to the right shape and using it to lift the covers a little bit.
SB7 is offline Find More Posts by SB7
Discussion Custome Made Multi Charge Leads KenSue Batteries and Chargers 4 Apr 14, 2012 07:52 AM
For Sale Custom Made 1/10 Brushless Monster Truck $165 F27QFlyer Cars - Trucks and Parts (FS/W) 7 Mar 23, 2012 06:24 AM
Wanted TRADE: Your glider for a NEW custom hand-made Acoustic Guitar War is Peace Aircraft - Sailplanes (FS/W) 14 Mar 20, 2012 04:22 PM
For Sale 3 custom made heavy duty charging cords- All 3 for $20.00 tyd. 540RCflyer Aircraft - General - Radio Equipment (FS/W) 0 Feb 25, 2012 11:12 AM
