Old Nov 14, 2012, 02:01 AM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
LOL your bro must be living in the stone age like me. My jvc is from back in the early 80's I guess JVC got there A$$'es sued off over the camcorder I bought. Don't laugh too hard im still using a flip phone.
unclecrash is offline Find More Posts by unclecrash
Old Nov 19, 2012, 07:42 AM
D_FAST is online now
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
good news , bad news.
Getting real close, and the closer i got the more i realized my estimated AUW has been blown by 10oz!!!!
The fiber glassing added 6oz to the air frame alone.
Current weight: 47oz 21oz sqft for wing loading and counting
That's with no paint, no landing gear and its gonna need them!
Did a quick power test, 460 watts isnt flying this pig!!!
Now i seen these dectrum units fly 3.5lb planes respectfully, but not these two units.
Balancing is a chore,
the hole is not big enough for either top flight mag ballencer or the great planes thumb ballencer. All i could do was get them close, then use the rotate and spin up method.
Still no love.I surprised i didn't blow them.
going to run them up out of the duct work take measurements.
Still need to figure out the cog of the my pig as well.
D_FAST is online now Find More Posts by D_FAST
Old Nov 19, 2012, 12:10 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
The COG looks good as long as the line dimensioned 10.738in is the centerline of the airframe.
Eric B.
AirX is offline Find More Posts by AirX
Old Nov 19, 2012, 09:08 PM
LuvEvolution7 is offline
Find More Posts by LuvEvolution7
LuvEvolution7's Avatar
St.Catharines, Ontario
Joined Jan 2009
^^^^^ +1. if you've used the root chord, the CG calc will be slightly off. as Eric recommended, you must use the centerline of the airplane and allow the natural lines of the wing outline to extend to the centerline. then take your measurements. 15-25% should be a good starting point. I'm guessing you'll find that 15% might be a tad nose heavy, but that's good too for the first few flights.
LuvEvolution7 is offline Find More Posts by LuvEvolution7
Old Nov 20, 2012, 04:12 AM
jumpy is offline
Find More Posts by jumpy
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
D, that c of g looks fine, mine came out 5.5'' from leading edge root, but it is bigger. She's looking real good, nice progress mate. Btw, you think yours is heavy, mine feels like a 'brick'.
Phil
jumpy is offline Find More Posts by jumpy
Old Nov 20, 2012, 08:43 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
Thats better!
Discovered a bent motor shaft, and slipping edf blades.
straighten the shaft the best we could, replaced the collect with some that had knurls on them no more slippage.
System still needs fine tuning.
Currently seeing a peak of 1050 watts @72 amps,settles in at 960-900 watts with a 40c 2650 zippy
Landing gear in place as well, my bro hooked me up on some simple wire struts no retracts.
AUW now is up to 50oz!!!
Old Nov 22, 2012, 11:14 AM
pencon is offline
Find More Posts by pencon
Joined Dec 2008
A little heavier flys more realistically
pencon is offline Find More Posts by pencon
Old Nov 23, 2012, 04:43 AM
D_FAST's Avatar
Denver CO
Joined Apr 2008
Waiting for the weather.
I must have done something right with my duct work.
The a-10 has the exact same system and is producing 760 watts with 2lb 14oz thrust with a 56 mm exhaust
the frogfoot is settling in round 950 watts with 2lb 11oz thrust with 53 mm exhaust
Old Nov 23, 2012, 05:47 AM
F86_sabre is offline
Find More Posts by F86_sabre
Joined Jul 2004
It looks very nice....has the same mean look as the original...Congrats!
F86_sabre is offline Find More Posts by F86_sabre
Old Nov 23, 2012, 07:36 AM
jumpy is offline
smithy
jumpy's Avatar
Cornwall, UK
Joined Dec 2004
Excellent work D, she looks great. I think she'll be a great flyer. I need to pull my finger out and get mine sorted.
Phil
Old Nov 23, 2012, 11:14 AM
Joined Jan 2009
that makes sense with the smaller diameter exhaust. she'll pick that back up with dynamic thrust at speed and will be much faster than the A-10 with similar power levels. it should fly really well and looks amazing. very well done.
Rich
Old Nov 23, 2012, 02:18 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Looks great, good luck on the maiden.
Eric B.
Old Nov 23, 2012, 07:52 PM
BillO is online now
Find More Posts by BillO
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
Won't be long now -- this build has gone so quick, I'm impressed!
BillO is online now Find More Posts by BillO
Old Nov 23, 2012, 09:25 PM
D_FAST's Avatar
Denver CO
Joined Apr 2008
Thanks all,
Weather man better not be lying to me, says 68 and calm.
Old Nov 24, 2012, 09:35 AM
unclecrash's Avatar
white lake michigan
Looks Great D, good luck on the Maiden.
Build Log EPP SU-39 (modernized SU-25 Frogfoot) formerly: lets play "guess the plane" Mr. UD Foamy EDFs 42 Sep 07, 2015 10:01 AM
Question Ducting for EPP SUKHOI SU-39 (~SU-25 Frogfoot) Mr. UD Scratchbuilt EDFs 8 Oct 15, 2011 12:26 PM
Question Su-25 Frogfoot.... got any plans? birdlives1955 Foamies (Scratchbuilt) 7 Feb 28, 2011 07:28 AM
su-25 frogfoot Robbie d Electric Ducted Fan Jet Talk 7 Dec 03, 2009 10:02 AM
