Old Oct 08, 2012, 09:09 AM
rdwoebke is offline
Find More Posts by rdwoebke
The Self Confuser
rdwoebke's Avatar
United States, IN, Indianapolis
Joined Feb 2004
Question
Care, Feeding, Maintenance, and imporvment of Ford Long Shaft Winches
Hey guys,
If there is already a thread for this, please point me to it and I will close this one.
I want to start a discussion on care and feeding of FLS winches. FLS winches are super common in the USA. But some are stronger than others. What are steps a person uses to improve/assess what is wrong with a winch? One obvious thing would be to switch to the battery that a "stronger" winch has to confirm it isn't the battery that is at fault. I know that adding "real balls" helps. Are there any diagnostic techniques/tools a person would use to evaluate a winch?
Ryan
rdwoebke is offline Find More Posts by rdwoebke
Old Oct 08, 2012, 09:37 AM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
If you have a 12v wind fls like I do, it's very weak on12v. On 24v, it's impressive. I just put the solenoid coils in series. Any warning circuitry will need adjusting, of course. With a 12v wind on 24v you only have half as much current but same power as 6v wind on 12v. So you only need half the capacity in each of the two 12v batteries in series. Lighter that way.
If you have 6v wind, I don't have any advice.
lincoln is offline Find More Posts by lincoln
Old Oct 08, 2012, 09:46 AM
rdwoebke is offline
The Self Confuser
rdwoebke's Avatar
Joined Feb 2004
Awesome point Lincoln, thanks for dropping in.
How do I confirm what wind a given motor has?
Ryan
Old Oct 08, 2012, 10:17 AM
Wazmo is online now
Find More Posts by Wazmo
Duane, LSF IV
Wazmo's Avatar
No. VA
Joined Nov 2004
If there's a part number stamped on the motor, I think 3110 is the 6V part, and 3115 is the 12V. Other than that, I think you have to open up the motor and look at the winding wire gauge. I'll check my box tonight. I ordered one with the 6V wind with heavy gauge field coils. I was told you need that for longevity running the 6V motor on 12V.
Wazmo is online now Find More Posts by Wazmo
Old Oct 08, 2012, 08:52 PM
lincoln is offline
Joined Dec 2001
If the motor is REALLY weak on a 12V battery, it may well be a 12V wind. Mine would launch 3 meter gliders, but only slowly. I know mine is 12V because I didn't know any better when I ordered it. Presumably, you'd get less rpm per volt on a 12V wind, but I don't know what that rpm should be. A 12V wind should have twice as many turns as a 6V wind, but again, I don't know how many turns that is. I'm not really a winch expert, so I've probably already told you most of what I know.
BTW, a neat trick for winding line onto the drum in a controllable way is to use a battery charger for power, instead of a battery. The low current means there won't be much of a pull.
Old Oct 08, 2012, 08:59 PM
Wazmo is online now
Duane, LSF IV
Wazmo's Avatar
No. VA
Joined Nov 2004
My 6V FLS came labelled with a sticker that says "3110N."
Old Oct 08, 2012, 09:28 PM
rdwoebke is offline
The Self Confuser
rdwoebke's Avatar
Joined Feb 2004
I'm pretty sure the winches I am investigating are 6 volt winds. They were bought used and some used to belong to the LSF. I'll try to verify though.
Thanks for the ideas guys.
Ryan
Old Oct 09, 2012, 07:47 AM
Fly2High is offline
Find More Posts by Fly2High
Chuck 'Em and Chase 'Em
Fly2High's Avatar
United States, NY, Plainview
Joined Aug 2005
when it comes to winches 2 things would come to mind
Winch Doc
Tim McCann
Not sure who is doing what these days but both use to make quality parts. Real Ball endplates, turnarounds, winch kits, etc. Both would only supply a sailplane pilot with the best.
If you find their stuff available, do not hessitate to buy it. Everyone witha set of real balls or winch drum or turnaround are super happy campers.
Frank
Fly2High is offline Find More Posts by Fly2High
Old Oct 09, 2012, 08:00 AM
tkallev is online now
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Ryan,
If you are looking at the old red painted LSF winches, those were built by Mike Wade in Michigan ... he can probably tell you the most about how they were put together and maintained.
Mostly, you want to keep them clean. Blow out the motors with compressed air, clean the stators and brushes, aerosol contact cleaner works well and replace the brushes when you see uneven wear or they don't fully contact the windings (or if they get "sparky"). The Real Balls require VERY LITTLE grease in the end cap and the grease fitting in the mounting collar was all marketing, the channel doesn't go anywhere in the early ones we had on the LSF winches ... I can't speak for the newer models but it's unlikely the Winch Doc has changed something that has worked so well over the years.
tkallev is online now Find More Posts by tkallev
Old Oct 09, 2012, 09:07 AM
rdwoebke is offline
The Self Confuser
rdwoebke's Avatar
Joined Feb 2004
Thanks, guys.
Tom, you are correct in that I personally have a red Nats winch that I bought from the sale of the old stuff and my club has a few of those as well.
The one I have was sold as is, it wasn't ever guaranteed to work. I have taken it apart and tried to use it to learn some things. I run it and it works but it is not even close to being contest quality. I would like to improve it and it does spark sometimes. It has bushings.
My club has a few of those red winches and a few other types some of which seem to work better than others. I was curious on tips and techniques for maintenance and evaluation of them to try to get all of the winches performing at top level. They are all used and purchased from other groups and individuals. For our club winches, the winches that don't have real balls adding real balls might be a good hop up. At the contest this past weekend we used 3 of my club's winches and 2 from LOFT and I did notice the LOFT winches were very strong (and had real balls).
Ryan
Old Oct 09, 2012, 12:18 PM
Fly2High is offline
Fly2High's Avatar
Joined Aug 2005
The nice thing about the real balls is that you can advance or retard the timing and get more/less power from them. Add the fact they have ball bearings instead of bushings and a major WOW factor.
Nice feature to have.
Old Oct 09, 2012, 01:50 PM
superskeg is offline
Find More Posts by superskeg
superskeg's Avatar
Joined Jul 2002
superskeg is offline Find More Posts by superskeg
Old Oct 09, 2012, 02:07 PM
rdwoebke is offline
The Self Confuser
rdwoebke's Avatar
Joined Feb 2004
Thanks, Tim. That is good info.
Any suggestions for folks on where to get replacement springs or brushes?
Ryan
Old Oct 09, 2012, 02:29 PM
superskeg's Avatar
Joined Jul 2002
Wanted Winches/ Enjoy/Ford Long Shaft Motors beach1 Aircraft - Sailplanes (FS/W) 2 Aug 29, 2012 05:25 PM
Sold Sailplane Winch ford long shaft Grandstand Aircraft - Sailplanes (FS/W) 2 Jul 30, 2012 02:23 PM
For Sale 12 volt Ford long shaft winch motor $100 shipped mdennis Aircraft - Sailplanes (FS/W) 0 Mar 16, 2007 10:27 AM
Fs Ford Long Shaft Starter Motor For Winch SkyKing RC Aircraft - Sailplanes (FS/W) 0 Sep 16, 2004 11:57 PM
