Old Oct 08, 2012, 08:58 AM
metap0Pe is offline
Find More Posts by metap0Pe
Joined Oct 2012
Help!
Help with a kk2.0 quadcopter build (check my shoplist thread)
So, I found out i have rushed things and ordered premeturely as always, so i cancelled the order (it wasnt sent yet luckyli) and am now starting again, and taking it a tad more easy.
The quad will be made for fun flight, and later on, i will try out some FPV flying. I have ordered parts so i can build it to a hex later on, if i want to try that out.
What i would like to end out with, is a quad/hex that has a nice battery time (15 min, 20 would be awsome, but hard to do as far as i can read), a long range (1-1.5 KM ? Doable?)
The shoppinglist:
The quad ( I have bought so i later on can advance to a hex)
http://www.hobbyking.com/hobbyking/s...ion_Board.html
http://www.hobbyking.com/hobbyking/s...IRS_20PC_.html
http://www.hobbyking.com/hobbyking/s...0pcs_set_.html
http://www.hobbyking.com/hobbyking/s...occessors.html
http://www.hobbyking.com/hobbyking/s...C_3A_UBEC.html
http://www.hobbyking.com/hobbyking/s...ner_750kv.html
http://www.hobbyking.com/hobbyking/s...rol_Board.html
http://www.hobbyking.com/hobbyking/s...ame_600mm.html
http://www.hobbyking.com/hobbyking/s...ming_Card.html
http://www.hobbyking.com/hobbyking/s...7SF_4_pc_.html
http://www.hobbyking.com/hobbyking/s...ion_4_pc_.html
http://www.hobbyking.com/hobbyking/s...rm_2s_4s_.html
http://www.hobbyking.com/hobbyking/s...po_users_.html
http://www.hobbyking.com/hobbyking/s...t_collet_.html
http://www.hobbyking.com/hobbyking/s...trol_Unit.html
Radio
http://www.hobbyking.com/hobbyking/s...Firmware_.html
http://www.hobbyking.com/hobbyking/s...Blue_DIY_.html
http://www.hobbyking.com/hobbyking/s...8FR_II_RX.html
Battery and charger
http://www.hobbyking.com/hobbyking/s...cessories.html
http://www.hobbyking.com/hobbyking/s...er_Supply.html
http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
Random stuff I might need
http://www.hobbyking.com/hobbyking/s...out_Cable.html
http://www.hobbyking.com/hobbyking/s...5SF_4_pc_.html
http://www.hobbyking.com/hobbyking/s..._SF_4_pc_.html
Total: 440$ + shipping, taxes and stuff.
Total budget: 550$, and this will most likely be broken when taxes and shipping gets in the hat, but hey, starting out is expensive.
I would be greatly thankfull if you could see your time to go it trough and see if i have made any beginner errors.
metap0Pe is offline Find More Posts by metap0Pe
Old Oct 08, 2012, 01:48 PM
metap0Pe is offline
Joined Oct 2012
Sorry for bumping, but I am really looking forward to ordering this so I can get started:P
I got 3 questions:
What telemetry would be fun to get,
Can i get a good GPS module to make a "return to home" function on the parts i have choosen.
Is there a good battery for the TX thats in stock you would reccomend?
Edit:
Thinking about these two parts:
http://www.hobbyking.com/hobbyking/s...nsor_Hub_.html
http://www.hobbyking.com/hobbyking/s...PS_Module.html
But will that make the vessel able to get a usable return to home function?
Edit2
Oh well, think i need to get this one too, to get altitude too... And it is in backorder.
http://www.hobbyking.com/hobbyking/s...er_Sensor.html
Any other GPS systems you can reccomend, or do they all come together with the flight controller? (thinking of the nasa)
Old Oct 09, 2012, 01:31 AM
metap0Pe is offline
Joined Oct 2012
Sorry for bumping again, but I would really like some feedback on this.
If none comes, i will just think everything is fine and dandy, and order the parts in a few hours
Old Oct 09, 2012, 03:23 AM
gitit20 is offline
Find More Posts by gitit20
gitit20's Avatar
Joined May 2012
your motors you have in the list are way to small you need something bigger a 2212 is a good size for the x525 kit
this one would also work ok http://www.hobbyking.com/hobbyking/s...ess_Motor.html
Here is a full kit and you would get it a lot faster http://rctimer.com/index.php?gOo=goo...7&productname=
gitit20 is offline Find More Posts by gitit20
Old Oct 09, 2012, 04:02 AM
metap0Pe is offline
Joined Oct 2012
Hmm, in another thread, people where saying they would be fine.
Any other oppinions on the motors? from what i can read they generate 3600G of thrust, and the total weight of the vessel will be 2200 grams.
Are they really to small?
Edit:
And bying a kit will learn me nothing That is why i prefer to build it from scratch.
Old Oct 09, 2012, 01:21 PM
metap0Pe is offline
Joined Oct 2012
Will this picture of a cat get you to the keyboards?
Old Oct 13, 2012, 06:32 AM
gitit20 is offline
gitit20's Avatar
Joined May 2012
A kit that you have to assemble lol not one pre made
Edit:
Old Oct 13, 2012, 07:05 AM
ElectroDie is offline
Find More Posts by ElectroDie
Joined Oct 2012
Motors should be good. I would get 11 + 10 inch props instead of 11 + 8. Don't get low voltage alarm, KK2 has it built in. Get THIS programming card, the Turnigy is wrong. Get THIS and THIS so you can flash your ESCs.
ElectroDie is offline Find More Posts by ElectroDie
Old Oct 13, 2012, 08:56 AM
Gavinxman is offline
Find More Posts by Gavinxman
Gavinxman's Avatar
Joined Aug 2011
Looks like you want a few features that IMHO only The naza fc & gps can do RIGHT!! With a budget of $550 you can get Will from " the quad man" to build you a 450 with naza and for $650 naza fc and naza gps set up perfect . Send your 9x to him and when you get the quad it will be RTF and it will be perfect !!!! I'm not sure if he even makes any money off that if he does it can't be much . I'm into sport flying and I'll be Lucy enough to get a Armatten 409 and it's just super clean build and fast and extremely strong almost unbreakableName: ImageUploadedByTapatalk1350136422.141275.jpg
Description: and for $185 shipped built bnf can't go wrong . Lots of R&D and that's the end result . But for what it looks like you want with your budget I'd go see the quad man . There are many great builders here and all build great quad etc but I've noticed it's got everything to do with what you're trying to achieve with your quad and that's how I base my decisions on who or what I get built thanks and good luck
Gavinxman is offline Find More Posts by Gavinxman
Old Oct 13, 2012, 02:37 PM
metap0Pe is offline
Joined Oct 2012
how can he do that when the naza alone costs like 300€ ?
Anyway, I find half of the fun in researching what components i should get, and how to put them proberly together. Getting a kit another person made is in my mind "boring". I fully understand the people that does it, but I just dont learn anything else than flying a premade quad by that
I already ordered the parts, so the ESC programming card will have to do, or i will have to order another one. Why does it not work?
Old Oct 14, 2012, 05:07 AM
Joined Oct 2012
If you read the page it has in bold underlined text "For use with Turnigy Plush ESCs". Have a try anyway and if it doesn't work you can always program your ESCs with your radio but it ain't fun
Old Oct 14, 2012, 05:48 AM
metap0Pe is offline
Joined Oct 2012
ahh well, if it does not work, i will have to order another programming board There must be a place in the EU that can sell those:P
Old Oct 14, 2012, 06:23 AM
CH33ZEBURG3R is offline
Find More Posts by CH33ZEBURG3R
Australia, VIC, Frankston
Joined Jul 2012
The KK2 board has a built in Voltage alarm so you don't need another one, don't forget extra wire,heat shrink and battery straps and the blue velcro from HK is very strong and will hold your batteries in place.
CH33ZEBURG3R is offline Find More Posts by CH33ZEBURG3R
Discussion ... Redemptioner Scratchbuilt Multirotors 4 Aug 12, 2012 08:18 PM
Discussion HOBBYKING KK2.0 QUADCOPTER combat rrcman1 Multirotor Talk 4 Aug 12, 2012 01:03 AM
Discussion HOBBYKING KK2.0 QUADCOPTER combat rrcman1 Scratchbuilt Multirotors 0 Aug 09, 2012 12:57 PM
Discussion Hobbyking kk2.0 quadcopter rrcman1 Multirotor Talk 0 Aug 04, 2012 06:27 PM
Discussion Need Help Seeing if my Quadcopter Build is Good! discusfish99 Multirotor Talk 4 May 21, 2012 12:24 PM
