Old Oct 08, 2012, 07:15 AM
KJELL is offline
Find More Posts by KJELL
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
Man-Bat.
Man-Bat.
How about a Man-Bat ?
KJELL is offline Find More Posts by KJELL
Old Oct 09, 2012, 02:52 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
VWD-The Power pack.
This unit can do the following functions:
Variable wing flapping frequency.
Individual flap angle movement with active wing twist on each wing.
Individual sweep movement on each wing.
Mechanical support of the wings.
Part of the frame work.
Old Oct 10, 2012, 11:58 PM
Socalfusions is offline
Find More Posts by Socalfusions
Joined Aug 2011
Originally Posted by KJELL View Post
Man-Bat.
VWD-The Power pack.
Hey Kjell, avid reader of the flapping wings forum and the ornithopter forum here, I've followed a lot of your threads and frankly don't see too many people nowadays talking about manned ornithopter flight which is surprising especially after Jarnos whole show. As most people are probably aware that are into the orni scene, Jarno used your wiggle drive as a basis for his theoretical design. I remember you pointing out that his differed over yours in a certain way while it also appears that you feel the wiggle drive needs to be much larger in order to be effective. What is your opinion on the backpack styled setup? Many seem to think that it's not viable because of size limitations in regards to power output. Also I remember you stating that after performing tests on the viability of membrane vs. feather wings that membrane were superior in efficiency to which I'm assuming you stuck with for this design.
Socalfusions is offline Find More Posts by Socalfusions
Old Oct 11, 2012, 02:09 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
Hi Socalfusions.
I can see that you are well informed about my activity. I think the Jarno´s story made many people to thing it is not posible to make a manned ornithopter. I don’t think so.Using the right material and the VWD wing drive, it is possible. Jarno used one motor for each wing and controlled the wing movement by flapping his arms. In my Man-Bat, I am using one motor moving the wings. The controll of the VWD can alter the flapping angle individual on each wing. The controll system has to be operated by the pilot and an auto controll have to be incorporated. The membrane wings are the best solution.
Old Oct 11, 2012, 04:19 PM
Joined Aug 2011
Hi Socalfusions.
Good point, after showing his elaborate design wasn't capable of flight I'm sure that made many people believe that it was even less possible but like you I also feel it can be done. The VWD seems to have a lot of advantages over crank drives and with the variable aspect, seems to be a viable choice. The arm flapping operation seems to complicate things further and I feel your design is much simpler. Seeing as how all rc ornithopters operate by membrane wing it also appears to be the logical selection.
Old Oct 13, 2012, 03:55 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
Here is the differences between Jarno`s and My Wiggle -Drive
Old Oct 22, 2012, 11:09 AM
Patricia J B is offline
Find More Posts by Patricia J B
Patricia J B's Avatar
Joined Oct 2003
[QUOTE=Socalfusions;22969291......and frankly don't see too many people nowadays talking about manned ornithopter flight ..........[/QUOTE]
I'm still talking about manned ornithopter flight
Cheers,
Patricia
Patricia J B is offline Find More Posts by Patricia J B
Old Oct 23, 2012, 08:51 PM
therealthing691 is offline
Find More Posts by therealthing691
therealthing691's Avatar
australia
Joined Apr 2007
:d
therealthing691 is offline Find More Posts by therealthing691
Old Oct 24, 2012, 01:22 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
Cheers,
Patricia
Patricia.
Have you done something more on your Project?
Old Nov 23, 2012, 07:02 PM
Joined Oct 2003
Patricia.
Hi Kjell,
Yes, I've been working on the flapping mechanism and the
engine speed reduction unit. The frame is finished and
the sprocket hubs are almost finished - will soon be mounting
the chain - hope it all works !
The fuselage took much longer than I thought it would but
everything always does !
I'm using graphlite microcarbon rods in the wing spars - has
anyone else used them ?
Cheers,
Patricia
Old Nov 24, 2012, 12:50 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
I have been using this material in my WING-DRIVE Wings. In combination with thin Carbon fiber sheets they are light and strong. I like to see any pictures from your project.
Old Apr 18, 2013, 06:03 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
You have not had experience with manned ornithopters Kjell and
do not know how they should be designed, built and tested.
Patricia
I wonder how many has experience with manned ornithopters. I have very clear how to make one manned ornithopters.
Old Apr 18, 2013, 06:21 AM
Joined Oct 2003
Patricia
Why have you changed to this thread Kjell ?
The wing sail was not invented by you.
I will reply in the flapping mechanisms thread since that was
what we were talking about originally.
Patricia
Old Apr 18, 2013, 06:42 AM
KJELL is offline
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
I changed to this thread to talk about a manned flight,
The other thread is to discus flapping mechanisms
I know exactly how not to make a manned ornithopter.
Old Apr 18, 2013, 06:48 AM
Joined Oct 2003
I will start a manned orni thread
Patricia
Discussion One last step for a man, one great loss for all man kind bgnome Dock Talk 23 Sep 07, 2012 02:03 PM
Discussion One mans junk is another mans nautical decor Robert Pulse Dock Talk 29 Aug 29, 2012 10:01 PM
Discussion The (BAT-WING) like a bat out of HELL.Scratch built. crispy1074 Scratchbuilt EDFs 4 Aug 29, 2012 02:58 PM
Discussion One man's flood is another man's treasure aerogel Life, The Universe, and Politics 0 Mar 13, 2012 01:19 PM
Discussion Holly high-tension wires, Bat Man!!! Gary Warner Sailplane Talk 4 Oct 15, 2006 08:55 AM
